MSR3040 做的L2TP over IPSEC 超时
2020-03-20提问
  • 1收藏,1013浏览
No One 零段
LNS为MSR3040  做的L2TP over IPSEC
客户端为 安卓手机
windows10  安装的inode拨号
ike已经通过,有相关信息
就是不能建立隧道。手机和PC都会在建立隧道会话的时候提示超时。不知道为什么
去掉ipsec,普通登录是没问题的
*Mar 20 09:25:58:379 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Recv data Len = 69 *Mar 20 09:25:58:379 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 09:25:58:380 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Received a SCCRQ or StopCCN, sending it to the upper layer *Mar 20 09:25:58:380 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 1 *Mar 20 09:25:58:380 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Board 0 recv from SOCK call ID=0 tunnel ID=0 MsgType = 1 Length = 69 *Mar 20 09:25:58:381 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Proc a control message from the peer: type=1, len = 69 *Mar 20 09:25:58:382 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 1 recv SCCRQ when in state 1 from 100.100.100.100 *Mar 20 09:25:58:382 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Checked SCCRQ MSG TYPE = 1 *Mar 20 09:25:58:382 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Protocol version: 100 *Mar 20 09:25:58:383 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Host name, value: anonymous *Mar 20 09:25:58:383 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel password of the L2TP group: ****** *Mar 20 09:25:58:383 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Framing capability : 3 *Mar 20 09:25:58:383 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP Remote call number, value: 61297 *Mar 20 09:25:58:383 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Parse AVP receive window size, value: 1 *Mar 20 09:25:58:384 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: START_CONTROL_CONNECTION_REPLY *Mar 20 09:25:58:384 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Protocol version: 100 *Mar 20 09:25:58:384 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Framing capability :3 *Mar 20 09:25:58:384 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Host name: 3040_BJ *Mar 20 09:25:58:384 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 1 *Mar 20 09:25:58:384 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Bearer capability: 3 *Mar 20 09:25:58:385 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Receive window size: 1 *Mar 20 09:25:58:385 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 sent control (SendUp & RcvLow): Ns (0) Nr (1) *Mar 20 09:25:58:385 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 first ctrl in send window, started ack timer *Mar 20 09:25:58:385 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 1 sent SCCRP to Tunnel 61297 *Mar 20 09:25:58:385 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 1 started the Hello timer (60 seconds) *Mar 20 09:25:58:386 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Recv data Len = 36 *Mar 20 09:25:58:386 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 4 *Mar 20 09:25:58:386 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Received a SCCRQ or StopCCN, sending it to the upper layer *Mar 20 09:25:58:387 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Received message type: 4 *Mar 20 09:25:58:387 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Board 0 recv from SOCK call ID=0 tunnel ID=0 MsgType = 4 Length = 36 *Mar 20 09:25:58:387 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Proc a control message from the peer: type=4, len = 36 *Mar 20 09:25:59:441 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 09:25:59:442 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 resent the ctrl message: Ns (0) 1 times 2000 timeout *Mar 20 09:26:01:441 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 09:26:01:442 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 resent the ctrl message: Ns (0) 2 times 4000 timeout *Mar 20 09:26:05:441 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 09:26:05:442 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 resent the ctrl message: Ns (0) 3 times 8000 timeout *Mar 20 09:26:13:441 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 09:26:13:442 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 resent the ctrl message: Ns (0) 4 times 13000 timeout *Mar 20 09:26:26:441 2020 3040_BJ L2TP/7/L2TDBG: L2TP_PAYLOAD: Tunnel 1 proc ctrl ack timer expired, SendUp=1 SendLow=0 *Mar 20 09:26:26:442 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Calls on tunnel 1 cleared because 1 *Mar 20 09:26:26:442 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Tunnel 1 sent StopCCN to Tunnel 61297 *Mar 20 09:26:26:442 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Message Type: STOP_CONTROL_CONNECTION_NOTIFICATION *Mar 20 09:26:26:443 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Assigned Tunnel ID: 1 *Mar 20 09:26:26:443 2020 3040_BJ L2TP/7/L2TDBG: L2TP_CONTROL: Put AVP Result code: LOSS_OF_CARRIER *Mar 20 09:26:26:443 2020 3040_BJ L2TP/7/L2TDBG: L2TP_ERROR: Send window overflow *Mar 20 09:26:26:444 2020 3040_BJ L2TP/7/L2TDBG: L2TP_ERROR: Failed to send the ctrl msg *Mar 20 09:26:26:444 2020 3040_BJ L2TP/7/L2TDBG: L2TP_EVENT: Cleared Tunnel remote ID:61297, local ID:1
粉丝:110人 关注:0人
debug没有报错,会不会是终端参数写的有问题,其他终端是佛能正常建立连接
粉丝:10人 关注:1人
deb ipsec all看看ipsec协商哪里有问题了
