*Mar 29 10:15:12:119 2020 H3C BGP/7/DEBUG: BGP.: 10.11.15.142 Receive ConnectRetryTimer_Expires event in CONNECT state. *Mar 29 10:15:12:119 2020 H3C BGP/7/DEBUG: BGP default.: 10.11.15.142 State is changed from CONNECT to CONNECT. *Mar 29 10:15:12:119 2020 H3C BGP/7/DEBUG: BGP.: 10.11.15.142 Session connect failed, error is Operation now in progress. *Mar 29 10:15:22:119 2020 H3C BGP/7/DEBUG: BGP_TIMER.: 10.11.10.14 CR Timer Expired. *Mar 29 10:15:22:119 2020 H3C BGP/7/DEBUG: BGP.: 10.11.10.14 Receive ConnectRetryTimer_Expires event in CONNECT state. *Mar 29 10:15:22:119 2020 H3C BGP/7/DEBUG: BGP default.: 10.11.10.14 State is changed from CONNECT to CONNECT. *Mar 29 10:15:22:119 2020 H3C BGP/7/DEBUG: BGP.: 10.11.10.14 Session connect failed, error is No route to host.
(0)
这是由于BGP邻居没有建立起来,需要检查如下几个要素,请悉知:
1、请确认两端的互联地址能够相互PING通。
2、请确认两端在指向BGP邻居时,地址已经指向正确。
3、请确认两端在指向BGP邻居时,AS号也指向正确。
4、如果有配置BGP MD5认证,请确认两端的密钥都一致。
5、如果是IBGP的组网,且没有互联,请确认IGP的路由已经可达。
(2)
建议参考如下链接配置查看:
http://www.h3c.com/cn/d_201612/964982_30005_0.htm
(0)
*Mar 29 10:36:23:119 2020 H3C BGP/7/DEBUG: BGP default.: 10.11.10.14 State is changed from CONNECT to CONNECT. *Mar 29 10:36:23:120 2020 H3C BGP/7/DEBUG: BGP.: 10.11.10.14 Session connect failed, error is Operation now in progress.
检查下基本配置,这是无法建立连接
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
