求 H3C WA2610E WA2620 这两款AP 瘦转胖的最新刷机FAT程序文件,邮箱:nchsz@***.***
(0)
1、以下是具体的下载,可打开下载:
http://www.h3c.com/cn/Service/Document_Software/Software_Download/IP_Wlan/AP/WA2610E-GNP_WA1208E-GNP_WA2610i-GN_WA2620i-AGN_WA2
2、需要登录后方可下载,以下是具体的用户名、密码,请悉知:
用户名:yx800
密码:01230123
(1)
直接在官网下载即可,如下链接
http://www.h3c.com/cn/Service/Document_Software/Software_Download/IP_Wlan/AP/WA2610E-GNP_WA1208E-GNP_WA2610i-GN_WA2620i-AGN_WA2/
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
升级完后不能通过WEB页面访问。VLAN1 没有配管理地址和账户密码。
[WA2610E]dis cu # version 5.20, Release 1303P06 # sysname WA2610E # domain default enable system # ipv6 # telnet server enable # vlan 1 # domain system access-limit disable state active idle-cut disable self-service-url disable # user-group system group-attribute allow-guest # wlan rrm dot11b mandatory-rate 1 2 dot11b supported-rate 5.5 11 dot11g mandatory-rate 1 2 5.5 11 dot11g supported-rate 6 9 12 18 24 36 48 54 # interface NULL0 # interface Vlan-interface1 ipv6 address auto ip address dhcp-alloc # interface GigabitEthernet1/0/1 # interface WLAN-Radio1/0/1 # undo gratuitous-arp-learning enable # load xml-configuration # load tr069-configuration # user-interface con 0 user-interface vty 0 4 user privilege level 3 set authentication password cipher $c$3$54tbw5xVXOt3bbnL/RYBb5bj+Ib4S6c1jqg636A= # return [WA2610E]
