ucenter在centos7.4下安装时提示无法连接到数据库
2020-03-31提问
  • 1收藏,935浏览
ucenter在CentOs7.4+mariadb5.5 下安装时一直报连接数据库失败。
在命令行下测试本地和远程都能正常登录数据库,
在/etc/iMC-Reserved/log中有以下报错内容,该如何解决?
2020-03-31 14:09:23 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor$DbConnectCheckingWorkingDialog::c(1696)] Execute 'mysql -V', return: 0 STDOUT: mysql Ver 15.1 Distrib 5.5.56-MariaDB, for Linux (x86_64) using readline 5.1
 STDERR:
 2020-03-31 14:09:24 [INFO ] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor$DbConnectCheckingWorkingDialog::b(1672)] Change LD_LIBRARY_PATH=./:/home/imc/linux/install/common/jre_linux64/lib/amd64/server:/home/imc/linux/install/common/jre_linux64/lib/amd64:/home/imc/linux/install/common/jre_linux64/../lib/amd64
2020-03-31 14:09:24 [ERROR] [SwingWorker-pool-1-thread-3] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor$DbConnectCheckingWorkingDialog::a(1642)] Execute 'conntest' failed java.io.IOException: Cannot run program "/tmp/1585634963012/common/lib/conntest_my_linux" (in directory "/tmp/1585634963012/common/lib"): java.io.IOException: error=2, No such file or directory
 at java.lang.ProcessBuilder.start(ProcessBuilder.java:470) at java.lang.Runtime.exec(Runtime.java:593)
 at com.h3c.imc.deploy.Util.executeCommand(Util.java:3575)
 at com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor$DbConnectCheckingWorkingDialog.a(DatabaseSelectPanelDescriptor.java:1620)
 at com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor$DbConnectCheckingWorkingDialog.doWork(DatabaseSelectPanelDescriptor.java:1497)
 at com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor$DbConnectCheckingWorkingDialog.doWork(DatabaseSelectPanelDescriptor.java:1320)
粉丝:14人 关注:4人
检查防火墙、依赖包、数据库服务、配置文件等
防火墙、selinux 已关,数据库服务正常,远程及本地都能正常连接数据库。
