H3C 路由器忘记账号密码如何重置?
2020-04-02提问
  • 1收藏,3375浏览
H3C MSR 36-40路由器忘记了账号密码,现在如何才能重置!求解答!
粉丝:7人 关注:1人
1.或者设备上是否有一个reset 的地方,进行恢复出厂配置
2,如果采用上面的方法,恢复出厂配置影响了之前的配置,可以在上面的基础上 |<8> Clear Super Password         清空密码即可
AVAYA 九段
粉丝:32人 关注:0人
V7交换机Console密码忘记处理方法
通过conlse线crt软件连接并登陆设备,然后把设备断电重启。控制台上会打印如下信息,当出现“press Ctrl+B”时候快速按住“Ctrl+B” 进入botroom菜单
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing.......................Done!
BootWare Validating...
Press Ctrl+B to enter extended boot menu...
BotWare password: Not required. Please press Enter to continue.
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
      按住“Ctrl+B”进入如下菜单。选择 <5> Restore to Factory Default Configuration    可以恢复出厂
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Clear Super Password                                                  |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTEND-ASSISTANT MENU
Ctrl+F: Format File System
Enter your choice(0-9): 5
Flag Set Success.
然后输入0重启设备
