5320-d刷绿洲版本失败提示文件错误
2020-04-03提问
  • 1收藏,861浏览
==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Image Program To SDRAM And Run | |<2> Update Main Image File | |<3> Update Backup Image File | |<4> Download Files(*.*) | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 5 ==========================<ETHERNET PARAMETER SET>========================== |Note: '.' = Clear field. | | '-' = Go to previous field. | | Ctrl+D = Quit. | ============================================================================ Protocol (FTP or TFTP) :tftp Load File Name :WA4300H-OASIS.bin :WA4300H-WPT330-E1107-OASIS.bin Target File Name :WA4300H-OASIS.bin :WA4300H-WPT330-E1107-OASIS.bin Server IP Address :192.168.0.100 Local IP Address :192.168.0.1 Subnet Mask :0.0.0.0 Gateway IP Address :0.0.0.0 ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Image Program To SDRAM And Run | |<2> Update Main Image File | |<3> Update Backup Image File | |<4> Download Files(*.*) | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 Loading..................................................................... ............................................................................ ............................................................................ .............................................Done. 13501440 bytes downloaded! Something wrong with the file.
文件名应该是什么
WA4300H-OASIS.bin 不对吗?
粉丝:17人 关注:18人
可能是版本下载上传中有损坏,建议按照下面的案例重新刷一次:
https://zhiliao.h3c.com/Theme/details/71191
粉丝:7人 关注:0人
版本下载错了
http://www.h3c.com/cn/d_202002/1272805_30005_40.htm
有什么问题吗?
