已经设置了Telnet密码但telnet还是提示没有设密码
2020-04-07提问
  • 1收藏,1387浏览
[H3C-ui-vty0-4]disp cur # version 5.20.99, Release 1109 # sysname H3C # domain default enable system # ipv6 # telnet server enable # port-group-vlan 1 # password-recovery enable # vlan 1 # vlan 2 # domain system access-limit disable state active idle-cut disable self-service-url disable # user-group system group-attribute allow-guest # local-user admin password cipher $c$3$EkhzOhFEh59+WPOOlD32QaWsr0DwDZyU authorization-attribute level 3 service-type telnet service-type web local-user gpec password cipher $c$3$gbrHqfKPlqdr5s6BHjb8ygZRUTsHUA== authorization-attribute level 3 service-type ssh telnet terminal # interface Bridge-Aggregation1 # interface NULL0 # interface Vlan-interface1 ip address 192.168.100.234 255.255.255.0 # interface Vlan-interface2 ipv6 address auto link-local ip address 192.168.101.234 255.255.255.0 # interface Ethernet1/0/1 port access vlan 2 #user-interface aux 0 user-interface vty 0 4 user privilege level 3 set authentication password cipher $c$3$xnlPtrHTAwLM1isoQ2w7Iq+Desrcfw== idle-timeout 3 0 user-interface vty 5 13 authentication-mode scheme user privilege level 3 set authentication password cipher $c$3$94pdU/JUt/8Hzhs2pOyrgblTh1j/rg== idle-timeout 3 0 user-interface vty 14 user-interface vty 15 protocol inbound telnet #
电脑com一段连接console,一段电脑网口连接交换机以太口1 0 1
欣欣 九段
粉丝:18人 关注:7人
从配置看,应该是配置了的,可以尝试重新配置下看下。
zhiliao_pvDiPv 知了小白
可以了
zhiliao_pvDiPv 知了小白
# user-interface aux 0 user-interface vty 0 4 user privilege level 3 set authentication password cipher $c$3$xnlPtrHTAwLM1isoQ2w7Iq+Desrcfw== idle-timeout 3 0 protocol inbound telnet user-interface vty 5 13 authentication-mode scheme user privilege level 3 set authentication password cipher $c$3$94pdU/JUt/8Hzhs2pOyrgblTh1j/rg== idle-timeout 3 0 user-interface vty 14 user-interface vty 15 protocol inbound telnet #
粉丝:124人 关注:6人
看配置是没有问题的,可尝试重新登录试下。
