WX3010E 无法上线AP
2020-04-10提问
  • 1收藏,1451浏览
Fcloud 二段
WAP4320-ACN 不上线到WX3010E  版本都换过了,DHCP Sever开在AC还是AC自带的LSW上 AP都可以正常获取IP地址,从AC可以Telnet到AP,在AC上开启wlan auto-ap enable AC上没任何提示,一点反应都没有,AC有12个授权,因为目前还没有一个AP上线占用。从AC上Telnet AP开启  t m
日志如下:
%Apr 26 12:06:26:547 2000 WA4320-ACN LWPC/4/LWPC_UDISC_NO_AC_RESPOND: No AC has responded to the Unicast Discovery request. %Apr 26 12:06:32:287 2000 WA4320-ACN LWPC/4/LWPC_UDISC_NO_AC_RESPOND: No AC has responded to the Unicast Discovery request. %Apr 26 12:07:00:230 2000 WA4320-ACN WMSH/6/WMESH_EXIT_ZERO_CFG_STATE: The devi ce has exited zero configuration state. %Apr 26 12:07:05:220 2000 WA4320-ACN WMSH/6/WMESH_ENTER_ZERO_CFG_STATE: The dev ice has entered zero configuration state. %Apr 26 12:07:06:575 2000 WA4320-ACN LWPC/4/LWPC_UDISC_NO_AC_RESPOND: No AC has responded to the Unicast Discovery request. %Apr 26 12:07:12:259 2000 WA4320-ACN LWPC/4/LWPC_UDISC_NO_AC_RESPOND: No AC has responded to the Unicast Discovery request. %Apr 26 12:07:45:344 2000 WA4320-ACN WMSH/6/WMESH_EXIT_ZERO_CFG_STATE: The devi ce has exited zero configuration state. %Apr 26 12:07:46:454 2000 WA4320-ACN LWPC/4/LWPC_UDISC_NO_AC_RESPOND: No AC has responded to the Unicast Discovery request. %Apr 26 12:07:50:343 2000 WA4320-ACN WMSH/6/WMESH_ENTER_ZERO_CFG_STATE: The dev ice has entered zero configuration state. %Apr 26 12:07:52:340 2000 WA4320-ACN LWPC/4/LWPC_UDISC_NO_AC_RESPOND: No AC has responded to the Unicast Discovery request.
AC上面Flash也上传了AP的Fit文件包,AC功能失效一样,还有什么原呢
AC>dis wl ap all Total Number of APs configured : 2 Total Number of configured APs connected : 0 Total Number of auto APs connected : 0 Total Number of APs connected : 0 Maximum AP capacity : 12 Remaining AP capacity : 12 AP Profiles State : I = Idle, J = Join, JA = JoinAck, IL = ImageLoad C = Config, R = Run, KU = KeyUpdate, KC = KeyCfm M = Master, B = Backup -------------------------------------------------------------------------------- AP Name State Model Serial-ID -------------------------------------------------------------------------------- ap1 I WA4320-ACN auto ap2 I WA4320i-ACN auto ------------------------------------------------------------------------------- <AC>
粉丝:111人 关注:1人
第一 确保该控制器下有4300系列的版本
第二 在Ap上用他拿到的地址ping ac的管理地址能否通
第三 确认AC 与AP是否在同网段,如果不在需要采用三层注册,下发ac的地址给AP
4 个回答
fywr 九段
粉丝:49人 关注:3人
确保ap为v5 ac v5授权注册需要重启生效
Fcloud 二段
<AC>display version
H3C Comware Platform Software
Comware Software, Version 5.20, Release 3509P58
Copyright (c) 2004-2016 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C WX3010E uptime is 0 week, 0 day, 1 hour, 25 minutes
H3C WX3010E with 1 RMI XLS 208 750MHz Processor
512M bytes DDR2
16M bytes Flash Memory
999M bytes CFCard Memory
3010E默认授权 12个
<WA4320i-ACN>dis version
Comware Software, Version 5.20, Release 1510
Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved.
H3C WA4320i-ACN uptime is 0 week, 0 day, 0 hour, 0 minute
<WA4320-ACN>dis version
Comware Software, Version 5.20, Release 1508P08
H3C WA4320-ACN uptime is 0 week, 0 day, 0 hour, 3 minutes
各种版本AP都不行。
第一个   AP将请求发送到了家用路由器导致注册失败
  解决方法:建议客户现场关闭家用路由器,改其它型号路由器作为出口,然后AP成功注册   第二可能是ap射频卡损坏所造成的
粉丝:10人 关注:7人
从debug 看,怀疑你AC开启了单播发现策略
