MSR800路由器配置DVPN,VAM Client当前认证状态反复DUMB
2020-04-17提问
  • 1收藏,1437浏览
MSR800路由器配置DVPN,VAM Client当前认证状态反复DUMB状态。OFFLINE状态大约持续10分钟左后就变为DUMB状态,然后再过几分钟后又变成DUMB状态。对比过其它正常路由器的配置,配置没有差别。
*Apr 17 17:59:27:445 2020 205984 VAM/7/EVENT: VAM_Client: Deleted DUMB timer successfully.
*Apr 17 17:59:27:447 2020 205984 VAM/7/EVENT: VAM_Client: Received client FSM event of type 12.
 *Apr 17 17:59:27:448 2020 205984 VAM/7/EVENT: VAM_Client: The state of client 205984 changed from DUMB to INIT.
*Apr 17 17:59:27:449 2020 205984 VAM/7/EVENT: VAM_Client: Created state aging timer successfully.
*Apr 17 17:59:27:450 2020 205984 VAM/7/PACKET: VAM_Client: Sent a packet (146 bytes) to IP yyy.yyy.yyy.yyy port 18000 successfully.
*Apr 17 17:59:27:451 2020 205984 VAM/7/EVENT: VAM_Client: Created packet resend timer successfully.
*Apr 17 17:59:27:452 2020 205984 VAM/7/EVENT: VAM_Client: Sent connect request successfully.
*Apr 17 17:59:27:462 2020 205984 VAM/7/PACKET: VAM_Client: Received a packet (108 bytes) from IP yyy.yyy.yyy.yyy port 18000.
*Apr 17 17:59:27:464 2020 205984 VAM/7/EVENT: VAM_Client: Received a packet of type 2.
 *Apr 17 17:59:27:465 2020 205984 VAM/7/EVENT: VAM_Client: Deleted packet resend timer successfully.
*Apr 17 17:59:27:466 2020 205984 VAM/7/EVENT: VAM_Client: Received connect response successfully.
*Apr 17 17:59:27:467 2020 205984 VAM/7/EVENT: VAM_Client: Received client FSM event of type 3.
 *Apr 17 17:59:27:468 2020 205984 VAM/7/PACKET: VAM_Client: Sent a packet (38 bytes) to IP yyy.yyy.yyy.yyy port 18000 successfully.
 *Apr 17 17:59:27:469 2020 205984 VAM/7/EVENT: VAM_Client: Created packet resend timer successfully.
*Apr 17 17:59:27:470 2020 205984 VAM/7/EVENT: VAM_Client: Sent connect finish request successfully.
*Apr 17 17:59:33:445 2020 205984 VAM/7/EVENT: VAM_Client: Deleted packet resend timer successfully.
*Apr 17 17:59:33:446 2020 205984 VAM/7/PACKET: VAM_Client: Sent a packet (38 bytes) to IP yyy.yyy.yyy.yyy port 18000 successfully.
*Apr 17 17:59:33:447 2020 205984 VAM/7/EVENT: VAM_Client: Created packet resend timer successfully.
*Apr 17 17:59:33:448 2020 205984 VAM/7/EVENT: VAM_Client: Resent packet 3 successfully. Resent times 1.
*Apr 17 17:59:38:445 2020 205984 VAM/7/EVENT: VAM_Client: Deleted packet resend timer successfully.
*Apr 17 17:59:38:446 2020 205984 VAM/7/PACKET: VAM_Client: Sent a packet (38 bytes) to IP yyy.yyy.yyy.yyy port 18000 successfully.
 *Apr 17 17:59:38:447 2020 205984 VAM/7/EVENT: VAM_Client: Created packet resend timer successfully.
 *Apr 17 17:59:38:448 2020 205984 VAM/7/EVENT: VAM_Client: Resent packet 3 successfully. Resent times 2.
 *Apr 17 17:59:43:445 2020 205984 VAM/7/EVENT: VAM_Client: Deleted packet resend timer successfully.
*Apr 17 17:59:43:446 2020 205984 VAM/7/EVENT: VAM_Client: Received client FSM event of type 9.
*Apr 17 17:59:43:447 2020 205984 VAM/7/EVENT: VAM_Client: The state of client 205984 changed from INIT to DUMB.
 *Apr 17 17:59:43:448 2020 205984 VAM/7/EVENT: VAM_Client: Deleted state aging timer successfully.
 *Apr 17 17:59:43:449 2020 205984 VAM/7/EVENT: VAM_Client: Created DUMB timer successfully.
 *Apr 17 17:59:43:450 2020 205984 VAM/7/EVENT: VAM_Client: Created client 205984"s DUMB timer successfully.
*Apr 17 17:59:50:445 2020 205984 VAM/7/PACKET: VAM_Client: Sent a packet (38 bytes) to IP xxx.xxx.xxx.xxx port 18000 successfully.
*Apr 17 17:59:50:446 2020 205984 VAM/7/EVENT: VAM_Client: Sent Keepalive request successfully.
 *Apr 17 18:01:26:446 2020 205984 VAM/7/EVENT: VAM_Client: Deleted DUMB timer successfully.
*Apr 17 18:01:26:447 2020 205984 VAM/7/EVENT: VAM_Client: Received client FSM event of type 12.
*Apr 17 18:01:26:448 2020 205984 VAM/7/EVENT: VAM_Client: The state of client 205984 changed from DUMB to INIT.
 *Apr 17 18:01:26:449 2020 205984 VAM/7/EVENT: VAM_Client: Created state aging timer successfully.
*Apr 17 18:01:26:450 2020 205984 VAM/7/PACKET: VAM_Client: Sent a packet (146 bytes) to IP yyy.yyy.yyy.yyy port 18000 successfully.
 *Apr 17 18:01:26:451 2020 205984 VAM/7/EVENT: VAM_Client: Created packet resend timer successfully.
*Apr 17 18:01:26:452 2020 205984 VAM/7/EVENT: VAM_Client: Sent connect request successfully.
 *Apr 17 18:01:26:463 2020 205984 VAM/7/PACKET: VAM_Client: Received a packet (108 bytes) from IP yyy.yyy.yyy.yyy port 18000.
*Apr 17 18:01:26:465 2020 205984 VAM/7/EVENT: VAM_Client: Received a packet of type 2.
 *Apr 17 18:01:26:466 2020 205984 VAM/7/EVENT: VAM_Client: Deleted packet resend timer successfully.
 *Apr 17 18:01:26:467 2020 205984 VAM/7/EVENT: VAM_Client: Received connect response successfully.
*Apr 17 18:01:26:468 2020 205984 VAM/7/EVENT: VAM_Client: Received client FSM event of type 3.
*Apr 17 18:01:26:469 2020 205984 VAM/7/PACKET: VAM_Client: Sent a packet (38 bytes) to IP yyy.yyy.yyy.yyy port 18000 successfully.
*Apr 17 18:01:26:470 2020 205984 VAM/7/EVENT: VAM_Client: Created packet resend timer successfully.
 *Apr 17 18:01:26:471 2020 205984 VAM/7/EVENT: VAM_Client: Sent connect finish request successfully.
*Apr 17 18:01:26:484 2020 205984 VAM/7/PACKET: VAM_Client: Received a packet (38 bytes) from IP yyy.yyy.yyy.yyy port 18000.
*Apr 17 18:01:26:485 2020 205984 VAM/7/EVENT: VAM_Client: Received a packet of type 3.
*Apr 17 18:01:26:486 2020 205984 VAM/7/EVENT: VAM_Client: Deleted packet resend timer successfully.
*Apr 17 18:01:26:488 2020 205984 VAM/7/EVENT: VAM_Client: Received connect finish response.
 *Apr 17 18:01:26:489 2020 205984 VAM/7/EVENT: VAM_Client: Received client FSM event of type 4.
*Apr 17 18:01:26:490 2020 205984 VAM/7/EVENT: VAM_Client: The state of client 205984 changed from INIT to REG.
*Apr 17 18:01:26:491 2020 205984 VAM/7/EVENT: VAM_Client: Refreshed state aging timer successfully.
 *Apr 17 18:01:26:492 2020 205984 VAM/7/PACKET: VAM_Client: Sent a packet (92 bytes) to IP yyy.yyy.yyy.yyy port 18000 successfully.
*Apr 17 18:01:26:493 2020 205984 VAM/7/EVENT: VAM_Client: Created packet resend timer successfully.
 *Apr 17 18:01:26:494 2020 205984 VAM/7/EVENT: VAM_Client: Sent register request successfully.
*Apr 17 18:01:26:505 2020 205984 VAM/7/PACKET: VAM_Client: Received a packet (76 bytes) from IP yyy.yyy.yyy.yyy port 18000.
*Apr 17 18:01:26:506 2020 205984 VAM/7/EVENT: VAM_Client: Received a packet of type 6.
 *Apr 17 18:01:26:507 2020 205984 VAM/7/EVENT: VAM_Client: Deleted packet resend timer successfully.
*Apr 17 18:01:26:508 2020 205984 VAM/7/EVENT: VAM_Client: Receive register response successfully.
*Apr 17 18:01:26:510 2020 205984 VAM/7/EVENT: VAM_Client: Received client FSM event of type 6.
*Apr 17 18:01:26:511 2020 205984 VAM/7/EVENT: VAM_Client: The state of client 205984 changed from REG to ONLINE.
 *Apr 17 18:01:26:512 2020 205984 VAM/7/EVENT: VAM_Client: Deleted state aging timer successfully.
*Apr 17 18:01:26:513 2020 205984 VAM/7/PACKET: VAM_Client: Sent a packet (38 bytes) to IP yyy.yyy.yyy.yyy port 18000 successfully.
*Apr 17 18:01:26:514 2020 205984 VAM/7/EVENT: VAM_Client: Sent first Keepalive request successfully.
*Apr 17 18:01:26:515 2020 205984 VAM/7/EVENT: VAM_Client: Created Keepalive timer successfully.
*Apr 17 18:01:26:528 2020 205984 VAM/7/PACKET: VAM_Client: Received a packet (124 bytes) from IP yyy.yyy.yyy.yyy port 18000.
 *Apr 17 18:01:26:529 2020 205984 VAM/7/EVENT: VAM_Client: Received a packet of type 13.
*Apr 17 18:01:26:530 2020 205984 VAM/7/EVENT: VAM_Client: Received Keepalive response.
 *Apr 17 18:01:26:531 2020 205984 VAM/7/EVENT: VAM_Client: Received hub info.
*Apr 17 18:01:26:532 2020 205984 VAM/7/EVENT: VAM_Client: Added hub info successfully.
 *Apr 17 18:01:26:533 2020 205984 VAM/7/EVENT: VAM_Client: Added hub info successfully.
*Apr 17 18:02:50:445 2020 205984 VAM/7/PACKET: VAM_Client: Sent a packet (38 bytes) to IP xxx.xxx.xxx.xxx port 18000 successfully.
粉丝:7人 关注:3人
client到sever的网络不稳定吧
问题是server这不是一个点的接入,几十个client的汇聚点,其它的没有问题。我看了ike及ipsec的sa,没有出现这种超时的情况,就只有dis vam client fsm的时间不起过1几分种
网工老菜鸟 发表时间:2020-04-20
如何解决的?
