vxlan
2020-04-20提问
  • 1收藏,1245浏览
弱控方案中leaf和spine之间跑vxlan的情况下,由于报文封装了vxlan,为啥不修改MTU值。
粉丝:50人 关注:5人
交换机是硬件转发的,不涉及mtu,转发只看接口下的 Maximum frame length,一般都是10000。
Ten-GigabitEthernet1/0/4
Current state: DOWN
Line protocol state: DOWN
IP packet frame type: Ethernet II, hardware address: 9ce8-9574-2517
Description: Ten-GigabitEthernet1/0/4 Interface
Bandwidth: 10000000 kbps
Loopback is not set
Media type is twisted pair
port hardware type is 10G_BASE_T
Flow-control is not enabled
Maximum frame length: 10000
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
粉丝:14人 关注:4人
交换机转发的报文只看最大帧长,不会看MTU
