这个建立不起来的原因是什么?原本是可以建立的
*Jan 2 05:05:31:425 2011 810 IKE/7/EVENT: IKE thread 1097143584 processes a job.
*Jan 2 05:05:31:425 2011 810 IKE/7/EVENT: Info packet process started.
*Jan 2 05:05:31:425 2011 810 IKE/7/PACKET: vrf = 0, local = 192.168.168.80, remote = 113.119.71.239/4500
Decrypt the packet.
Received ISAKMP Hash Payload.
*Jan 2 05:05:31:426 2011 810 IKE/7/PACKET: vrf = 0, local = 192.168.168.80, remote = 113.119.71.239/4500
Received ISAKMP Notification Payload.
Parse informational exchange packet successfully.
*Jan 2 05:05:31:426 2011 810 IKE/7/EVENT: vrf = 0, local = 192.168.168.80, remote = 113.119.71.239/4500
Notification INVALID_ID_INFORMATION is received.
*Jan 2 05:05:31:427 2011 810 IKE/7/EVENT: Delete IPsec SA.
*Jan 2 05:05:31:427 2011 810 IPSEC/7/EVENT:
Sent delete SA message to all nodes, message type is 0x16.
The SA doesn't exist in kernel.
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
配置没修改过,就是加了个策略。因为之前是4G和有线的两个都是用同一个ipsec的策略所以现在把它区分开。不过之前就是比如用4G的时候可以建立。然后切换成有线又可以。然后再切换成4G就建立不起来了。除非重启。不然一直起不来
