H3C S7506E-S交换机故障
2020-04-28提问
  • 1收藏,3403浏览
两台H3C S7506E-S的交换机启用了stp+vrrp ,其中一台交换机报如下错误(dis log有且仅有如下日志信息),在报错下面的客户端出现随机的掉包现象,手动切换到另外一台业务就恢复正常,求问故障原因.
%Apr 27 14:05:46:521 2020 OP-2P2F-IDC2-S7506E-S IC/6/SYS_RESTART: System restarted -- H3C Comware Software.
%Apr 27 14:06:32:630 2020 OP-2P2F-IDC2-S7506E-S LICENSE/4/LICENSE_WARNING: Format LICENSE storage!
%Apr 27 14:06:33:163 2020 OP-2P2F-IDC2-S7506E-S DEVM/2/BOARD_STATE_FAULT: Board state changes to FAULT on Chassis 0 Slot 1, type is unknown.
%Apr 27 14:06:33:163 2020 OP-2P2F-IDC2-S7506E-S DEVM/2/BOARD_STATE_FAULT: Board state changes to FAULT on Chassis 0 Slot 3, type is unknown.
%Apr 27 14:06:33:164 2020 OP-2P2F-IDC2-S7506E-S DEVM/2/BOARD_STATE_FAULT: Board state changes to FAULT on Chassis 0 Slot 5, type is unknown.
%Apr 27 14:06:33:164 2020 OP-2P2F-IDC2-S7506E-S DEVM/2/BOARD_STATE_FAULT: Board state changes to FAULT on Chassis 0 Slot 7, type is unknown.
%Apr 27 22:06:52:390 2020 OP-2P2F-IDC2-S7506E-S STP/6/STP_ENABLE: STP is now enabled on the device.
粉丝:50人 关注:5人
设备整机异常重启了,收集下诊断,找400分析下重启原因。
