msr 30-11
2020-04-29提问
  • 1收藏,1113浏览
请问如何禁止某网段如192.168.100.X  访问218.2.X.X
David1 三段
先 permit 再 deny
acl advanced 3001
rule 10 permit ip
rule 20 deny ip source 192.168.100.0  0.0.0.255 destination 218.2.x.x 反掩码
访问的是外网,还是禁不了218.2.2.2仍能ping通218.2.2.2 acl number 3001 rule 10 permit ip rule 20 deny ip source 192.168.100.0 0.0.0.255 destination 218.2.0.0 0.0.255.255 # dhcp server ip-pool vlan100 network 192.168.100.0 mask 255.255.255.0 gateway-list 192.168.100.254 dns-list 218.2.2.2 interface Ethernet0/0 port link-mode route nat outbound 3001 ip address dhcp-alloc # interface Ethernet0/1 port link-mode route ip address 192.168.100.254 255.255.255.0 # ip route-static 0.0.0.0 0.0.0.0 Ethernet0/0 192.168.10.1 #
zhiliao_SzHMi 发表时间:2020-04-29
访问外网没有这么复杂 你哪些地址段需要上外网 你写条ACL把需要上外网的地址加上 在外网接口上NAT outbound 加上需要上外网的ACL就行
David1 发表时间:2020-04-29
粉丝:22人 关注:1人
[Device] acl advanced 3000
[Device-acl-ipv4-adv-3000] rule deny ip source 192.168.100.0 0.0.0.255 destination 218.2.0.0 0.0.255.255
# 应用IPv4高级ACL 3000对接口GigabitEthernet2/0/0出方向上的报文进行过滤。
[Device] interface gigabitethernet 2/0/0
[Device-GigabitEthernet2/0/0] packet-filter 3000 outbound
[Device-GigabitEthernet2/0/0] quit
粉丝:111人 关注:1人
如果是218.2.xxx在公网
在nat 调用的acl里面
acl ad 3000
rule 0 deny  ip source  192.168.100.X 反掩码  destion  ip  218.2.xxx
rule 10 permit ip source
interface  g 1/0/x
nat outbound  3000
如果是218.2.xxx内网:
acl ad 3000
在对应访问的接口下:
packet-fi   3000  inbound
packet-fi   3000  outbound    看访问方向来
rule 10 rule 20 需要换位置 你rule 10是放行了所有,就不会匹配rule 20了
漓离原上谱 发表时间:2020-04-29
acl number 3001 rule 20 deny ip source 192.168.100.0 0.0.0.255 destination 218.2.0.0 0.0.255.25 5换了还是不行呀 rule 30 permit ip
acl number 3001 rule 0 deny ip source 192.168.100.0 0.0.0.255 destination 218.2.0.0 0.0.255.255 rule 10 permit ip interface Ethernet0/0 nat outbound 3001 ip address dhcp-alloc interface Ethernet0/1 ip address 192.168.100.254 255.255.255.0 ip route-static 0.0.0.0 0.0.0.0 Ethernet0/0 192.168.10.1 请帮我看看问题出哪了?
你用哪个终端ping的? 你不要告诉我在设备上面ping
