imc
2020-04-29提问
  • 1收藏,1381浏览
水水 一段
imc port 和ac结合的实际案列,求详细配置
粉丝:111人 关注:1人
WX系列AC与iMC配合实现无线Portal认证典型配置
一、组网需求:
WX系列ACWA系列FIT AP(如WA2620-AGN)、便携机
二、组网图:
三、配置步骤:
1.配置信息
1AC配置
[WX3010-AC]dis cu
 version 5.20, Release 3111P11
 Sysname WX3010-AC
 domain default enable portal
 telnet server enable
 port-security enable
 portal server imc ip 192.168.1.254 url http://192.168.1.254/portal/logon.htm
 portal free-rule 0 source interface GigabitEthernet1/0/1 destination any
 portal local-server http
 portal trap server-down
 oap management-ip 192.168.0.101 slot 0
vlan 1
vlan 2
vlan 100
radius scheme portal
 server-type extended
 primary authentication 172.16.100.200
 primary accounting 172.16.100.200
 key authentication h3c
 key accounting h3c
 user-name-format without-domain
 nas-ip 192.168.1.254
domain portal
 authentication portal radius-scheme portal
 authorization portal radius-scheme portal
 accounting portal radius-scheme portal
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
domain system
 state active
 idle-cut disable
dhcp server ip-pool ap_add
 network 192.168.1.0 mask 255.255.255.0
 gateway-list 192.168.1.254
dhcp server ip-pool sta_add
 network 192.168.2.0 mask 255.255.255.0
 gateway-list 192.168.2.254
user-group system
local-user admin
 password simple admin
 authorization-attribute level 3
 service-type telnet
wlan rrm
 dot11a mandatory-rate 6 12 24
 dot11a supported-rate 9 18 36 48 54
 dot11b mandatory-rate 1 2
 dot11b supported-rate 5.5 11
 dot11g mandatory-rate 1 2 5.5 11
 dot11g supported-rate 6 9 12 18 24 36 48 54
wlan service-template 1 crypto
 ssid H3C-PORTAL
 bind WLAN-ESS 1
 cipher-suite ccmp
 security-ie rsn
 service-template enable
interface NULL0
interface Vlan-interface1
 ip address 192.168.1.254 255.255.255.0
interface Vlan-interface2
 ip address 192.168.2.254 255.255.255.0
 portal server imc method direct
interface Vlan-interface100
 ip address 172.16.100.201 255.255.255.0
 port link-type trunk
 port trunk permit vlan all
interface WLAN-ESS1
 port access vlan 2
 port-security port-mode psk
 port-security tx-key-type 11key
 port-security preshared-key pass-phrase cipher 4rRxTMRshjevHnWJFnodbA==
wlan ap ap1 model WA2620-AGN id 1
 serial-id 219801A0A79101G05128
 radio 1
  radio enable
 radio 2
  max-power 5
  service-template 1
  radio enable
 ip route-static 172.16.100.0 255.255.255.0 192.168.1.253
 ip route-static 172.16.100.0 255.255.255.0 192.168.2.253
 dhcp enable
 load xml-configuration
user-interface aux 0
user-interface vty 0 4
 authentication-mode scheme
 user privilege level 3
Return
o c s 0
Press CTRL+K to quit.
Connected to OAP!
%Sep 18 16:46:11:607 2011 WX3010-SW SHELL/5/LOGIN:- 1 - Console(aux0) in unit1 login
dis cu
 sysname WX3010-SW
 oap management-ip 192.168.0.100 slot 0
radius scheme system
domain system
local-user admin
 service-type telnet
 level 3
vlan 1 to 2
vlan 100
 ip address 192.168.0.101 255.255.255.0
interface Aux1/0/0
 poe enable
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
 stp disable
interface NULL0
Return
2)主要配置步骤
(1)        创建RADIUS方案。
创建RADIUS方案portal并进入其视图。
[WX3010-AC] radius scheme portal
设置主认证RADIUS服务器的IP地址172.16.100.122
[WX3010-AC-radius-h3c] primary authentication 172.16.100.122
设置主计费RADIUS服务器的IP地址172.16.100.122
[WX3010-WX3010-AC-radius-h3c] primary accounting 172.16.100.122
设置系统与认证RADIUS服务器交互报文时的共享密钥为h3c
[WX3010-AC-radius-h3c] key authentication h3c
设置系统与计费RADIUS服务器交互报文时的共享密钥为h3c
[WX3010-AC-radius-h3c] key accounting h3c
RADIUS方案h3cRADIUS服务器类型设置为extended
[WX3010-AC-radius-h3c] server-type extended
RADIUS方案中用户认证设置为不带域认证。
[WX3010-AC-radius-h3c] user-name-format without-domain
(2)        创建domain域。
创建portal域并进入其视图。
[WX3010-AC] domain portal
lan-access用户配置认证方案为RADIUS方案,方案名为portal
[WX3010-AC-isp-system] authentication portal radius-scheme portal
lan-access用户配置授权方案为RADIUS方案,方案名为portal
[WX3010-AC-isp-system] authorization portal radius-scheme portal
lan-access用户配置计费方案为RADIUS方案,方案名为portal
[WX3010-AC-isp-system]accounting portal radius-scheme portal
(3)        全局使能端口安全。
[WX3010-AC] port-security enable
(4)        设置Portal用户的认证域默认为portal
[WX3010-AC] domain default enable portal
(5)        配置接口WLAN-ESS 1
创建接口WLAN-ESS1并进入其视图。
[WX3010-AC] interface WLAN-ESS 1
 (6)        无线服务集设置。
创建clear类型的服务模板1并进入其视图。
[WX3010-AC] wlan service-template 1 clear
设置当前服务模板的SSID(服务模板的标识)为H3C-PORTAL
[WX3010-AC-wlan-st-1] ssid  H3C-PORTAL
WLAN-ESS1接口绑定到服务模板1
[WX3010-AC-wlan-st-1] bind WLAN-ESS 1
设置无线客户端接入该无线服务(SSID)的认证方式为开放式系统认证。
[WX3010-AC-wlan-st-1] authentication-method open-system
使能服务模板。
[WX3010-AC-wlan-st-1] service-template enable
2、配置iMC
1)接入设备配置
iMC控制界面,点击菜单栏中[业务]->[接入业务] ->[接入设备管理] ->[接入设备配置]增加接入设备
进入接入设备配置,选择手工增加”->“手工增加接入设备后,进入接入设备配置页面。根据设备上的RADIUS属性配置,对参数进行设置,然后点击确定
2)服务配置
iMC控制界面,首先进入“业务”、“接入业务”。然后进入“服务配置管理”、“增加服务配置”,在服务配置列表中,选择“增加”,添加服务名,在计费策略中选中配置好的计费策略(计费策略配置方法,此处略),这里选择不计费。
3)用户配置
iMC控制界面,进入“用户,选择“增加用户输入用户名和密码。此处需要注意将刚才配置的服务选上。
4、验证结果
l在未通过Portal认证的情况下使用PC1访问internetPC不能访问Internet上的资源。
l PC1上打开浏览器,输入IP地址或域名访问InternetPortal服务器会将用户请求的页面强制重定向到Portal认证页面,并要求用户输入用户名、密码。用户输入正确的用户名和密码后可以正常访问Internet上的资源。
(1) 关联SSID
   (2) 打开浏览器,输入IP地址或域名进行认证,Portal服务器会将用户请求的页面强制重定向到Portal认证页面,并要求用户输入用户名、密码。
(3)用户通过认证。
(4)点击“Logoff”按钮,PC1下线。
