msg360-10
2020-05-04提问
  • 1收藏,1459浏览
请问这个AC控制器,我准备软件升级一下,但是通过console口连接进入 到下面的界面,我该怎么操作,请指导一下,谢谢!
粉丝:6人 关注:5人
软件丢失了,重新下载个上传上去吧,升级文档和软件下载地址:
https://www.h3c.com/cn/Service/Document_Software/Software_Download/IP_Wlan/MSG/MSG360_10/
用户名:yx800   密码:01230123
粉丝:57人 关注:0人
参考案例轻轻松松配无线:https://zhiliao.h3c.com/topic/huati/1249
zhiliao_OloNd 知了小白
这些版本都可以用吗?
粉丝:111人 关注:1人
ysname> save
Please input the file name(*.cfg)[cfa0:/startup.cfg]
cfa0:/startup.cfg exists, overwrite? [Y/N]:y
(2)       将配置文件备份到PCIP地址:192.168.0.1)上。
<Sysname> tftp 192.168.0.1 put startup.cfg
  File will be transferred in binary mode
  Sending file to remote TFTP server. Please wait... \
  TFTP: 1914 bytes sent in 0 second(s).
  File uploaded successfully.
B.5.2 进入BootWare菜单
1. BootWare主菜单
设备上电和重新启动的过程中,在配置终端的屏幕上首先将显示:
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Press Ctrl+T to start heavy memory test
Booting Normal Extended BootWare
The Extended BootWare is self-decompressing....Done.
*                   H3C WX3520H BootWare, Version 1.10                     *
Copyright (c) 2004-2018 New H3C Technologies Co., Ltd.
Compiled Date       : Apr 23 2018
CPU Type            : XLP416
CPU Clock Speed     : 1000MHz
Memory Type         : DDR3 SDRAM
Memory Size         : 4096MB
Memory Speed        : 1333MHz
BootWare Size       : 768KB
Flash Size          : 16MB
cfa0 Size           : 4002MB
CPLD1 Version       : 004
CPLD2 Version       : 000
PCB Version         : Ver.A
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
·         为了阅读和便于理解,如果不做特殊说明,本菜单都将称为BootWare主菜单。
·         以上显示信息与设备实际情况相关,可能会略有差别。
当出现“Press Ctrl+B to access EXTENDED-BOOTWARE MENU...”时,键入<Ctrl+B>,系统进入BootWare主菜单:
Password recovery capability is enabled.
Note: The current operating device is cfa0
Enter < Storage Device Operation > to select device.
===========================<EXTENDED-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Skip Authentication for Console Login                                 |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Enter your choice(0-9):
该菜单含义如下:
表21 BootWare主菜单
菜单项
<1> Boot System
引导启动文件
进入串口子菜单。子菜单详细描述请参见B.5.31.
进入以太网操作子菜单。子菜单详细描述请参见2.
<4> File Control
文件控制子菜单。子菜单详细描述请参见3.
恢复设备的出厂配置
跳过当前配置进行启动,只是本次生效。该功能一般在用户丢失口令之后使用
BootWare操作子菜单。
BootWare程序会随设备启动文件的升级而同步升级,不推荐用户单独升级BootWare程序
清除Console口登录密码
存储设备控制菜单,用于存储设备的选择
<0> Reboot
重新启动设备
B.5.3 BootWare子菜单
1. 进入串口子菜单;
通过该子菜单可以实现升级启动文件,修改串口速率等操作。
BootWare主菜单下选择<2>可以进入串口子菜单:
===========================<Enter Serial SubMenu>===========================
|Note:the operating device is cfa0                                         |
|<1> Download Image Program To SDRAM And Run                               |
|<2> Update Main Image File                                                |
|<3> Update Backup Image File                                              |
|<4> Download Files(*.*)                                                   |
|<5> Modify Serial Interface Parameter                                     |
|<0> Exit To Main Menu                                                     |
Enter your choice(0-5):
各选项含义如下:
表22 BootWare串口子菜单
菜单项
<1> Download Application Program To SDRAM And Run
通过串口下载启动文件到内存并启动
升级主启动文件
升级备份启动文件
下载启动文件到存储
修改串口参数
返回BootWare主菜单
2. 进入以太网操作子菜单;
BootWare菜单下键入<3>,可以进入以太网操作子菜单,系统显示如下:
==========================<Enter Ethernet SubMenu>==========================
|<5> Modify Ethernet Parameter                                             |
|<Ensure The Parameter Be Modified Before Downloading!>                    |
以太网操作子菜单中各选项解释如下:
表23 以太网口子菜单
菜单项
下载启动文件到内存并启动
升级主启动文件
升级备份启动文件
下载启动文件到存储
修改以太网口参数
返回BootWare主菜单
3. 文件控制子菜单;
BootWare主菜单中键入<4>,系统将进入文件控制子菜单。通过这个菜单可以实现对存储器中保存的启动文件显示类型、修改文件名、删除文件等操作,提示信息如下:
===============================<File CONTROL>===============================
|<1> Display All File(s)                                                   |
|<2> Set Image File type                                                   |
|<3> Set Bin File type                                                     |
|<4> Set Configuration File type                                           |
|<5> Delete File                                                           |
各选项含义如下:
表24 文件控制子菜单
菜单项
显示所有文件
设置IPE文件类型
设置Bin文件类型
设置配置文件类型
<5> Delete File
删除文件
返回BootWare主菜单
B.5.4 通过以太网口利用TFTP/FTP升级启动文件
(1)       以太网口参数配置:在BootWare主菜单下键入<3>可以进入以太网操作子菜单,然后键入<5>就可以进入以太网参数设置菜单:
=========================<ETHERNET PARAMETER SET>=========================
|Note:       '.' = Clear field.                                           |
|            '-' = Go to previous field.                                  |
|          Ctrl+D = Quit.                                                 |
Protocol (FTP or TFTP) :ftp
Load File Name         :wx3520h.ipe
Target File Name       :wx3520h.ipe
Server IP Address      :192.168.0.1
Local IP Address       :192.168.0.100
Subnet Mask            :255.255.255.0
Gateway IP Address     :0.0.0.0
FTP User Name          :user001
FTP User Password      :********
表25 以太网参数设置说明
显示
'.' = Clear field
快捷键:“.”表示清除当前输入
快捷键:“-”表示返回到前一个参数域
Ctrl+D = Quit
快捷键:表示退出参数配置界面
使用的传输协议,可以为FTP或者TFTP
Load File Name
下载文件名,要与下载的实际文件名一致
Target File Name
存储的目标文件名。缺省情况下与服务器端文件名一致
Server IP Address
TFTP/FTP服务器的IP地址。需要设置掩码请使用冒号“:”格开,如:192.168.80.10:24
Local IP Address
本地IP地址,为TFTP/FTP客户端设置的IP地址
Subnet Mask
本地IP地址的子网掩码
Gateway IP Address
网关IP地址。当与服务器不在同一网段时需要配置网关地址。
FTP User Name
FTP用户名,传输协议为TFTP时,无此选项
FTP User Password
FTP用户密码,传输协议为TFTP时,无此选项
(2)       以升级主启动文件为例,键入<2>为升级主启动文件:
Loading.....................................................................
.........................................Done.
168620032 bytes downloaded!
The file is exist,will you overwrite it? [Y/N]Y
Image file boot.bin is self-decompressing...
Saving file cfa0:/boot.bin ...........................Done.
Image file system.bin is self-decompressing...
Saving file cfa0:/system.bin .........................Done.
(3)       选择<0>,返回BootWare主菜单:
Enter your choice(0-5): 0
|<1> Boot System                                                            |
|<4> File Control                                                           |
|<5> Modify BootWare Password                                               |
|<0> Reboot        |
(4)       选择<1>,引导系统
Enter your choice(0-9): 1
Loading the main image files...
Loading file cfa0:/system.bin...........................Done.
Loading file cfa0:/boot.bin..............Done.
Image file cfa0:/boot.bin is self-decompressing..............Done.
System image is starting...
Press Ctrl+I to enter inter-initiate mode...  0 s
Cryptographic Algorithms Known-Answer Tests are running ...
CPU 0 of slot 1:
Starting Known-Answer tests in the user space.
Known-answer test for SHA1 passed.
Known-answer test for SHA224 passed.
Known-answer test for SHA256 passed.
Known-answer test for SHA384 passed.
Known-answer test for SHA512 passed.
Known-answer test for HMAC-SHA1 passed.
Known-answer test for HMAC-SHA224 passed.
Known-answer test for HMAC-SHA256 passed.
Known-answer test for HMAC-SHA384 passed.
Known-answer test for HMAC-SHA512 passed.
Known-answer test for AES passed.
Known-answer test for RSA(signature/verification) passed.
Known-answer test for RSA(encrypt/decrypt) passed.
Known-answer test for DSA(signature/verification) passed.
Known-answer test for random number generator passed.
Known-Answer tests in the user space passed.
Starting Known-Answer tests in the kernel.
Known-answer test for GCM passed.
Known-answer test for GMAC passed.
Known-Answer tests in the kernel passed.
Cryptographic Algorithms Known-Answer Tests passed.
Line con0 is available.
Press ENTER to get started.
B.6 通过BootWare菜单进行文件管理
对文件类型的修改、显示等可以在文件控制子菜单下完成:
BootWare主菜单下键入<4>,系统会进入文件控制子菜单。系统显示如下:
|<5> Delete File                                                         |
1. 显示所有文件
键入<1>进入该选项,系统提示:
Display all file(s) in cfa0:
 'M' = MAIN      'B' = BACKUP      'N/A' = NOT ASSIGNED
|NO. Size(B)   Time                 Type   Name                            |
|1   2048      Jan/01/1980 00:00:00 N/A    cfa0:/logfile/logfile1.log      |
|2   1027      Jan/01/1980 00:00:00 N/A    cfa0:/license/210235a1jnc14b9000|
|31.did        |
|3   2406      Jan/01/1980 00:00:00 N/A    cfa0:/pki/https-server.p12      |
|4   393       Jan/01/1980 00:00:00 N/A    cfa0:/ifindex.dat               |
|5   9388      Jan/01/1980 00:00:00 M      cfa0:/startup.cfg               |
|6   137234    Jan/01/1980 00:00:00 N/A    cfa0:/startup.mdb               |
|7   309       Jan/01/1980 00:00:00 N/A    cfa0:/test.py                   |
|8  735        Jan/01/1980 00:00:00 N/A     cfa0:/hostkey                  |
|9  591        Jan/01/1980 00:00:00 N/A     cfa0:/serverkey                |
|10  0         Jan/01/1980 00:00:00 N/A    cfa0:/lauth.dat                 |
|11  87160     Jan/01/1980 00:00:00 N/A    cfa0:/dpi/apr/predefined/apr_sig|
|pack_curr.dat                                                             |
|12  103904256 Dec/15/2011 09:00:00 M      cfa0:/boot.bin                  |
|13  64708608  Dec/15/2011 09:00:00 M      cfa0:/system.bin                |
2. 设置文件类型
启动文件属性包括主用启动文件(M)和备用启动文件(B)。设备中同一属性的启动文件只能有一个。同一个启动文件的属性可以是MB两种文件属性的任意组合。当某种属性被指定到一个新的启动文件后,该属性对应的原启动文件将不在具有该属性,如果原启动文件只具有一种属性,则原启动文件的属性将变更为N/A
在文件控制子菜单下键入<2>,进入设置启动文件类型菜单:
|1   168620032 Jun/01/2018 00:00:00 N/A    cfa0:/wx3520h.ipe               |
|0   Exit        |
Enter file No.:1
输入要修改的文件的编号,按<ENTER>,系统提示对文件类型进行更改:
Modify the file attribute:
|<1> +Main                                                               |
|<2> +Backup                                                             |
|<0> Exit        |
Enter your choice(0-2):
键入12可以指定主用启动文件和指定为备用启动文件。当用户成功设置文件类型后,终端显示如下信息:
This operation may take several minutes. Please wait....
Saving file cfa0:/boot.bin ................Done.
Saving file cfa0:/system.bin ..........Done.
Set the file attribute success!
3. 删除文件
在文件控制子菜单下键入<5>,可进入删除文件选项:
Deleting the file in cfa0:
|31.did        |
|pack_curr.dat                                                             |
|0   Exit        |
Enter file No.:
输入要删除文件的编号,按<ENTER>,系统提示如下,表示删除成功:
The file you selected is cfa0:/boot.bin,Delete it?
[Y/N]Y
Deleting...Done.
附录 C Console口登录认证密码丢失的处理
