进入uis的web界面后,点击超融合架构后,tomcat8异常退出。版本是H3C_UIS-E0712-AUTO,请问什么原因?
[root@cvknode ~]# systemctl status tomcat8
● tomcat8.service - Apache Tomcat Web Application Container
Loaded: loaded (/usr/lib/systemd/system/tomcat8.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Tue 2020-05-05 17:21:13 CST; 49s ago
Process: 22025 ExecStop=/var/lib/tomcat8/bin/shutdown.sh (code=exited, status=1/FAILURE)
Main PID: 4527 (code=killed, signal=KILL)
Tasks: 115
Memory: 78.7M
CGroup: /system.slice/tomcat8.service
├─14369 /usr/bin/atop -R -w /var/log/atop/atop_20200505 600
├─22768 /opt/h3c/bin/httpd -k graceful
├─22781 calamari-httpd -k graceful
├─22782 calamari-httpd -k graceful
├─22783 calamari-httpd -k graceful
├─22784 calamari-httpd -k graceful
├─22785 calamari-httpd -k graceful
├─22786 calamari-httpd -k graceful
├─22787 calamari-httpd -k graceful
├─22788 calamari-httpd -k graceful
├─22789 /opt/h3c/bin/httpd -k graceful
├─22790 /opt/h3c/bin/httpd -k graceful
└─22791 /opt/h3c/bin/httpd -k graceful
May 05 17:20:03 cvknode su[19113]: (to postgres) root on none
May 05 17:20:04 cvknode su[19138]: (to postgres) root on none
May 05 17:20:04 cvknode su[19163]: (to postgres) root on none
May 05 17:20:04 cvknode su[19188]: (to postgres) root on none
May 05 17:20:04 cvknode su[19217]: (to postgres) root on none
May 05 17:21:13 cvknode systemd[1]: tomcat8.service: main process exited, code=killed, status=9/KILL
May 05 17:21:13 cvknode shutdown.sh[22025]: PID file found but either no matching process was found or the current user does not have permission to stop the process. Stop aborted.
May 05 17:21:13 cvknode systemd[1]: tomcat8.service: control process exited, code=exited status=1
May 05 17:21:13 cvknode systemd[1]: Unit tomcat8.service entered failed state.
May 05 17:21:13 cvknode systemd[1]: tomcat8.service failed.
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
重装好几遍了,还是这样。 还没有到添加主机等后面几步,停留在配置网络页面,通过查看后台进程,点击超融合架构后就开始出现安装onestor等进程,安装完毕后,web页面显示无连接,tomcat8服务退出,重新启动等一会又退出。
规划网络的阶段一般不会下发配置,存储网要求2个万兆口,交换机侧配置聚合,对照开局指导书查查,是否符合要求 另外,换换chrome或者firefox试试
