WA4320X怎么设置反制区域内其他AP,AC型号WX3508H
2020-05-06提问
  • 1收藏,1124浏览
如题
粉丝:111人 关注:1人
WIPS分类与反制配置举例
图1-3所示,AP通过交换机与AC相连,AP1和AP2为Client提供无线服务,SSID为“abc”,在Sensor上开启WIPS功能,配置分类策略,将非法客户端的MAC地址(000f-1c35-12a5)添加到静态禁用列表中,将SSID“abc”添加到静态信任列表中,要求对检测到的潜在外部AP和未授权客户端进行反制。
图1-3 WIPS分类与反制组网图
在AC上完成无线服务的相关配置,具体配置步骤可参见“WLAN配置指导”中的“WLAN接入”,此处不再重复。
# 配置虚拟安全域vsd1。
<AC> system-view
[AC] wips
[AC-wips] virtual-security-domain vsd1
[AP-wips-vsd-vsd1] quit
[AC-wips] quit
# 创建AP名称为Sensor,开启WIPS功能。
[AC] wlan ap Sensor model WA4320i-ACN
[AC-wlan-ap-Sensor] serial-id 210235A1GQB139000435
[AC-wlan-ap-Sensor] radio 1
[AC-wlan-ap-Sensor-radio-1] radio enable
[AC-wlan-ap-Sensor-radio-1] wips enable
[AC-wlan-ap-Sensor-radio-1] quit
# 配置Sensor加入虚拟安全域vsd1。
[AC-wlan-ap-Sensor] wips virtual-security-domain vsd1
[AC-wlan-ap-Sensor] quit
# 配置分类策略class1,将Client 2的MAC地址配置禁用MAC地址,并且将名为“abc”的SSID配置为信任SSID。
[AC] wips
[AC-wips] classification policy class1
[AC-wips-cls-class1] block mac-address 000f-1c35-12a5
[AC-wips-cls-class1] trust ssid abc
[AC-wips-cls-class1] quit
# 虚拟安全域vsd1应用分类策略class1。
[AC-wips-vsd-vsd1] apply classification policy class1
[AC-wips-vsd-vsd1] quit
# 配置反制策略protect,反制未授权客户端和潜在外部AP。
[AC-wips] countermeasure policy protect
[AC-wips-cms-protect] countermeasure unauthorized-client
[AC-wips-cms-protect] countermeasure potential-external-ap
[AC-wips-cms-protect] quit
# 虚拟安全域vsd1应用反制策略protect。
[AC-wips-vsd-vsd1] apply countermeasure policy protect
[AC-wips] quit
(1)     通过display wips virtual-security-domain命令查看无线设备的分类结果。
[AC] display wips virtual-security-domain vsd1 device
Total 3 detected devices in virtual-security-domain vsd1
Class: Auth - authorization; Ext - extern; Mis - mistake;
       Unauth - unauthorized; Uncate - uncategorized;
       (A) - associate; (C) - config; (P) - potential
MAC address    Type   Class    Duration    Sensors Channel Status
00e0-fc00-5829 AP     Auth     00h 10m 24s 1       149     Active
000f-e228-2528 AP     Auth     00h 10m 04s 1       149     Active
000f-e223-1616 AP     Ext(P)   00h 10m 46s 1       149     Active
000f-1c35-12a5 Client Unauth   00h 10m 02s 1       149     Active
000f-e201-0102 Client Auth     00h 10m 02s 1       149     Active
在虚拟安全域vsd1,MAC地址为000f-e223-1616的AP被分类成潜在外部AP,MAC地址为000f-1c35-12a5的客户端被分类为未授权的客户端。
(2)     通过命令行display wips virtual-security-domain vsd1 countermeasure record命令查看反制过的设备记录信息。
[AC] display wips virtual-security-domain vsd1 countermeasure record
Total 2 times countermeasure, current 2 countermeasure record in virtual-security-domain vsd1
Reason: Attack; Ass - associated; Black - blacklist;
        Class - classification; Manu - manual;
MAC address    Type   Reason   Countermeasure AP      Radio ID   Time
000f-e223-1616 AP     Class    Sensor                 1          2014-06-03/10:30:36
000f-1c35-12a5 Client Class    Sensor                 1          2014-06-03/09:13:26
在虚拟安全域vsd1,MAC地址为000f-1c35-12a5的未授权客户端和MAC地址为000f-e223-1616的潜在外部AP被反制。
1.15.2  WIPS畸形报文检测和泛洪攻击检测配置举例
图1-4所示,AP通过交换机与AC相连,将两台AP分别配置为Sensor,配置虚拟安全域VSD_1,并配置两台Sensor属于这个虚拟安全域,当检测到攻击者对无线网络进行IE重复的畸形报文或Beacon帧泛洪攻击时,AP向AC发送告警信息。
图1-4 畸形报文检测和泛洪攻击检测组网图
# 创建AP名称为sensor1,开启WIPS功能。
<AC> system-view
[AC] wlan ap sensor1 model WA4320i-ACN
[AC-wlan-ap-sensor1] serial-id 210235A1GQB139000435
[AC-wlan-ap-sensor1] radio 1
[AC-wlan-ap-sensor1-radio-1] radio enable
[AC-wlan-ap-sensor1-radio-1] wips enable
[AC-wlan-ap-sensor1-radio-1] return
# 创建AP名称为sensor2,开启WIPS功能。
<AC> system-view
[AC] wlan ap sensor2 model WA4320i-ACN
[AC-wlan-ap-sensor2] serial-id 210235A1GQB139000436
[AC-wlan-ap-sensor2] radio 1
[AC-wlan-ap-sensor2-radio-1] radio enable
[AC-wlan-ap-sensor2-radio-1] wips enable
[AC-wlan-ap-sensor2-radio-1] quit
[AC-wlan-ap-sensor2] quit
# 配置虚拟安全域VSD_1。
[AC] wips
[AC-wips] virtual-security-domain VSD_1
[AP-wips-vsd-VSD_1] quit
# 创建攻击检测策略,当检测到IE重复的畸形报文和Beacon帧泛洪攻击时,向AC发送日志信息或告警信息。检测IE重复的畸形报文的静默时间为50秒,检测Beacon帧的统计周期为100秒,触发阈值为200,静默时间为50秒。
[AC-wips] detect policy dtc1
[AC-wips-dtc-dtc1] malformed duplicated-ie quiet 50
[AC-wips-dtc-dtc1] flood beacon interval 100 quiet 50 threshold 200
[AC-wips-dtc-dtc1] quit
# 在虚拟安全域VSD_1上应用攻击检测策略。
[AC-wips-vsd-VSD_1] apply detect policy dtc1
[AC-wips-vsd-VSD_1] quit
[AC-wips] quit
# 配置sensor1加入虚拟安全域VSD_1。
[AC-wlan-ap-sensor1] wips virtual-security-domain VSD_1
[AC-wlan-ap-sensor1] quit
# 配置sensor2加入虚拟安全域VSD_1。
[AC-wlan-ap-sensor2] wips virtual-security-domain VSD_1
[AC-wlan-ap-sensor2] return
4.  验证结果
(1)     当网络中没有攻击者时,在AC上通过命令行display wips statistics receive命令查看收到报文的统计信息,畸形报文和泛洪报文的统计个数为0。
<AC> display wips statistics receive
Information from sensor 1
Information about attack statistics:
Detected association-request flood messages: 0
Detected authentication flood messages: 0
Detected beacon flood messages: 0
Detected block-ack flood messages: 0
Detected cts flood messages: 0
Detected deauthentication flood messages: 0
Detected disassociation flood messages: 0
Detected eapol-start flood messages: 0
Detected null-data flood messages: 0
Detected probe-request flood messages: 0
Detected reassociation-request flood messages: 0
Detected rts flood messages: 0
Detected duplicated-ie messages: 0
Detected fata-jack messages: 0
Detected illegal-ibss-ess messages: 0
Detected invalid-address-combination messages: 0
Detected invalid-assoc-req messages: 0
Detected invalid-auth messages: 0
Detected invalid-deauth-code messages: 0
Detected invalid-disassoc-code messages: 0
Detected invalid-ht-ie messages: 0
Detected invalid-ie-length messages: 0
Detected invalid-pkt-length messages: 0
Detected large-duration messages: 0
Detected null-probe-resp messages: 0
Detected overflow-eapol-key messages: 0
Detected overflow-ssid messages: 0
Detected redundant-ie messages: 0
Detected AP spoof AP messages: 0
Detected AP spoof client messages: 0
Detected AP spoof ad-hoc messages: 0
Detected ad-hoc spoof AP messages: 0
Detected client spoof AP messages: 0
Detected weak IV messages: 0
Detected excess AP messages: 0
Detected excess client messages: 0
Detected sig rule messages: 0
Information from sensor 2
(2)     当检测到IE重复的畸形报文和Beacon帧泛洪攻击时,在AC上通过命令行display wips statistics receive查看收到报文的统计信息,IE重复的畸形报文的统计个数为28和Beacon帧泛洪攻击的统计个数为18。
Detected beacon flood messages: 18
Detected duplicated-ie messages: 28
粉丝:39人 关注:3人
在Ac上配置即可,http://www.h3c.com/cn/d_202004/1282820_30005_0.htm
看下这个配置指导,不能反制关联在同一个AC上的AP
