三层交换机配置
2020-05-14提问
  • 1收藏,785浏览
s5120设置如下:
[H3C]dis cu
 version 5.20, Release 1513P62
 sysname H3C
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 domain default enable system
 telnet server enable
 password-recovery enable
vlan 1
vlan 2 to 4
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
dhcp server ip-pool vlan2
 network 192.168.2.0 mask 255.255.255.0
 gateway-list 192.168.2.1
dhcp server ip-pool vlan3
 network 192.168.3.0 mask 255.255.255.0
 gateway-list 192.168.3.1
dhcp server ip-pool vlan4
 network 192.168.4.0 mask 255.255.255.0
 gateway-list 192.168.4.1
user-group system
local-user admin
 password cipher $c$3$ZW+MwMEr5pp2y8OcxedQjJ3UGNKk0aRh
interface NULL0
interface Vlan-interface1
 ip address 192.168.0.253 255.255.254.0
interface Vlan-interface2
 ip address 192.168.2.1 255.255.255.0
interface Vlan-interface3
 ip address 192.168.3.1 255.255.255.0
interface Vlan-interface4
 ip address 192.168.4.1 255.255.255.0
 port access vlan 2
 port access vlan 2
 port access vlan 2
interface GigabitEthernet1/0/4
 port access vlan 2
interface GigabitEthernet1/0/5
 port access vlan 2
interface GigabitEthernet1/0/6
 port access vlan 2
interface GigabitEthernet1/0/7
 port access vlan 2
interface GigabitEthernet1/0/8
 port access vlan 2
interface GigabitEthernet1/0/9
 port access vlan 3
interface GigabitEthernet1/0/10
 port access vlan 3
interface GigabitEthernet1/0/11
 port access vlan 3
interface GigabitEthernet1/0/12
 port access vlan 3
interface GigabitEthernet1/0/13
 port access vlan 3
interface GigabitEthernet1/0/14
 port access vlan 3
interface GigabitEthernet1/0/15
 port access vlan 3
interface GigabitEthernet1/0/16
 port access vlan 3
interface GigabitEthernet1/0/17
 port access vlan 4
interface GigabitEthernet1/0/18
 port access vlan 4
interface GigabitEthernet1/0/19
 port access vlan 4
interface GigabitEthernet1/0/20
 port access vlan 4
interface GigabitEthernet1/0/21
 port access vlan 4
interface GigabitEthernet1/0/22
 port access vlan 4
interface GigabitEthernet1/0/23
 port access vlan 4
interface GigabitEthernet1/0/24
 port link-type trunk
 port trunk permit vlan all
interface GigabitEthernet1/0/25
 port trunk permit vlan 1
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
 ip route-static 0.0.0.0 0.0.0.0 192.168.0.1
 dhcp server forbidden-ip 192.168.2.1
 dhcp server forbidden-ip 192.168.3.1
 dhcp server forbidden-ip 192.168.4.1
 dhcp enable
 load tr069-configuration
user-interface aux 0
user-interface vty 0 4
 authentication-mode scheme
user-interface vty 5 15
Return
MSR3610静态路由配置如下:
现在上不了外网,显示如下:
请问该怎么修改配置
欣欣 九段
粉丝:18人 关注:7人
您好,交换机配制没有问题,看ping交换机丢包嘛
用192.168.2.2ping192.168.2.3,超时
zhiliao_eE4At4 发表时间:2020-05-14
Xcheng 九段
粉丝:122人 关注:3人
检查下MSR930的拨号口配置
tcp ms 1024
mtu 1492
然后检查下MSR 930的0口是否和交换机的24口连接
和NAT配置
或者在MSR上ping下测试看下 外网和内网是否通了
g0口是跟交换机g24连的,现在是不知道路由器上怎么设置了
那现在有2个思路 1.确认下MSR930的外线接在那个扣上的 是否和pppoe client绑定的端口一致 2.查看下pppoe拨号是否成功 3.msr930是否配置了NAT 或者说NAT配置是否正确 4.通过在MSR 930ping测试 比如ping 223.5.5.5测试公网连通性 ping 192.168.4.1 内网连通性
Xcheng 发表时间:2020-05-14
回复Xcheng:
外网通的,ping内网也能ping通,没有配置NAT
那把NAT配置加上在看看 如最简单的吧 [acl a 3000] [ru 100 per ip] [int di 0] [nat out 3000]
zhiliao_b2WqY 知了小白
是打不开网页,还是不能上网,再DHCP没分配DNS服务器
粉丝:6人 关注:0人
老弟,我分析你是90%没有在路由器上写2.0 3.0 4.0网段的回程路由
如果写了的话,就一级一级的检查,终端能不能ping通网关?能通就ping路由器地址,自己一级一级排查,不难的
