交换机
2020-05-22提问
  • 1收藏,760浏览
粉丝:0人 关注:5人
各位大师,帮忙看下这个交换机25   26端口无法和核心交换机连接,是那里不对。
<H3C>dis cu
# version 5.20.99, Release 1104
# sysname H3C
# domain default enable system
# ipv6 # telnet server enable
# password-recovery enable
# vlan 1
# vlan 20
# domain system access-limit disable state active idle-cut disable self-service-url disable
# user-group system group-attribute allow-guest
# local-user admin password cipher $c$3$axN6f8tLKk6Z8PS1UMlbOpGTu2elE67jUA== authorization-attribute level 3 service-type telnet service-type web
# interface NULL0 # interface Vlan-interface1 ip address 192.168.20.210 255.255.255.0
# interface Ethernet1/0/1 port access vlan 20
# interface Ethernet1/0/2
# interface Ethernet1/0/3 port access vlan 20
# interface Ethernet1/0/4
# interface Ethernet1/0/5 port access vlan 20
# interface Ethernet1/0/6
# interface Ethernet1/0/7 port access vlan 20
# interface Ethernet1/0/8
# interface Ethernet1/0/9 port access vlan 20
# interface Ethernet1/0/10
# interface Ethernet1/0/11
# interface Ethernet1/0/12
# interface Ethernet1/0/13
# interface Ethernet1/0/14
# interface Ethernet1/0/15
# interface Ethernet1/0/16
# interface Ethernet1/0/17
# interface Ethernet1/0/18
# interface Ethernet1/0/19
# interface Ethernet1/0/20
# interface Ethernet1/0/21
# interface Ethernet1/0/22
# interface Ethernet1/0/23
# interface Ethernet1/0/24
# interface GigabitEthernet1/0/25
 port link-type trunk
 port trunk permit vlan all
# interface GigabitEthernet1/0/26
# ip https enable # load xml-configuration # user-interface aux 0 user-interface vty 0 4 authentication-mode scheme user privilege level 3 set authentication password cipher $c$3$wvmr9Pt78DnRDxF1SxEZedEyMA2FjNoaxA== user-interface vty 5 15
# return
下面这个交换机就可以连接。但web在局域网无法连接,帮忙看看是什么原因。
<H3C>
#Apr 26 12:04:24:782 2000 H3C SHELL/4/LOGIN: Trap 1.3.6.1.4.1.25506.2.2.1.1.3.0.1<hh3cLogIn>: login from Console %Apr 26 12:04:24:916 2000 H3C SHELL/5/SHELL_LOGIN: Console logged in from aux0.
<H3C>dis cu
# sysname H3C
# vlan 1
# vlan 20
# local-user admin password cipher $c$3$FDnCRphB06JI3N5CgG9airkunV3mtI0Ajw== authorization-attribute level 3 service-type telnet service-type web local-user axkj password cipher $c$3$Cf4TXFLs7FOKrLEQ8O8jRjVRr2tsp947jA== authorization-attribute level 3 service-type telnet service-type web
# interface NULL0
 # interface Vlan-interface1 ip address 192.168.20.211 255.255.255.0
# interface Ethernet1/0/2 port access vlan 20
# interface Ethernet1/0/4 port access vlan 20
 # interface Ethernet1/0/6 port access vlan 20
# interface Ethernet1/0/8 port access vlan 20
# interface Ethernet1/0/10 port access vlan 20
# interface Ethernet1/0/11 port access vlan 20
# interface Ethernet1/0/12 port access vlan 20
# interface Ethernet1/0/13 port access vlan 20
# interface Ethernet1/0/14 port access vlan 20
# interface Ethernet1/0/15 port access vlan 20
# interface Ethernet1/0/16 port access vlan 20
# interface Ethernet1/0/17 port access vlan 20
# interface Ethernet1/0/18 port access vlan 20
# interface Ethernet1/0/19 port access vlan 20
# interface Ethernet1/0/20 port access vlan 20
# interface Ethernet1/0/21 port access vlan 20
# interface Ethernet1/0/22 port access vlan 20
# interface Ethernet1/0/23 port access vlan 20
# interface Ethernet1/0/24 port access vlan 20
 combo enable copper
 combo enable copper
 # ip route-static 0.0.0.0 0.0.0.0 192.168.0.1
# undo info-center logfile enable # load xml-configuration # user-interface aux 0 authentication-mode password set authentication password cipher $c$3$uXW4VyhXykGIcwz71YBVUeZUTHnDkkFVcw== idle-timeout 0 0 user-interface vty 0 4 authentication-mode scheme user privilege level 3 set authentication password cipher $c$3$1RcmqmzBO/Tdkj4STicZ6gaiUGb2kFsVXg== idle-timeout 0 0 user-interface vty 5 15 user privilege level 3 set authentication password cipher $c$3$1RcmqmzBO/Tdkj4STicZ6gaiUGb2kFsVXg== idle-timeout 0 0 # return
QAZWSX 九段
粉丝:21人 关注:4人
1、确认下接口STP状态;
2、理论上,ping没问题的话,局域网内互访就没问题,现场确认下ping是否OK
就是ping不通
zhiliao_vDKyxG 发表时间:2020-05-22
下面的交换机多了这项就可以连接combo enable copper
那个是光电复用接口,通过对应命令使能电口,关闭光口
QAZWSX 发表时间:2020-05-22
主线插入25或26口,灯都不亮
一样的设备么?如果一样,那应该也和下面那台,应该是光电复用的口,你在对应接口下使能下combo enable copper看看
怎么把这项combo enable copper加上
粉丝:3人 关注:0人
先ping 192.168.0.1是否通,因并不知道你核心交换机连本交换机的25和26是否也是trunk。如果不是trunk,那你应该在本交换机上配有192.168.0.x的地址。否则此交换机都找不到网关在那里。
