S5500V2-EI下接旁挂路由
2020-06-01提问
  • 1收藏,1034浏览
我这边有个三层交换机,创建好各VLAN之后,根据各wlan划分DHCP上网,vlan10下的网关是192.168.99.1,DHCP池是192.168.99.2-192.168.99.250;我现在想在wlan10下接一个旁挂路由,这个路由器的管理IP地址是192.168.99.55,但现在我把电脑网关改成192.168.99.55后不能上网了;路由器配置没问题,以前用二层傻瓜的时候是可以的;
三层交换机还需要设置什么的吗?
配置如下:
  1. #
  2. version 7.1.070, Release 1119P11
  3. #
  4. sysname H3C
  5. #
  6. telnet server enable
  7. #
  8. irf mac-address persistent timer
  9. irf auto-update enable
  10. undo irf link-delay
  11. irf member 1 priority 1
  12. #
  13. dhcp enable
  14. dhcp server forbidden-ip 192.168.6.240 192.168.6.250
  15. dhcp server forbidden-ip 192.168.99.240 192.168.99.250
  16. #
  17. lldp global enable
  18. #
  19. password-recovery enable
  20. #
  21. vlan 1
  22. #
  23. vlan 10
  24. #
  25. vlan 20
  26. #
  27. vlan 100
  28. #
  29. stp global enable
  30. #
  31. dhcp server ip-pool vlan10
  32. gateway-list 192.168.99.1
  33. network 192.168.98.0 mask 255.255.254.0
  34. dns-list 114.114.114.114 8.8.8.8
  35. static-bind ip-address 192.168.98.2 mask 255.255.254.0 hardware-address 309c-237d-e37c
  36. static-bind ip-address 192.168.98.59 mask 255.255.254.0 hardware-address 309c-23b8-8244
  37. static-bind ip-address 192.168.98.95 mask 255.255.254.0 hardware-address 8ca6-dfcc-7e87
  38. static-bind ip-address 192.168.98.155 mask 255.255.254.0 hardware-address 8825-939d-3f68
  39. static-bind ip-address 192.168.99.33 mask 255.255.254.0 hardware-address 00d8-6154-b61a
  40. static-bind ip-address 192.168.99.58 mask 255.255.254.0 hardware-address d094-662a-3a3e
  41. static-bind ip-address 192.168.99.111 mask 255.255.254.0 hardware-address 309c-23b0-fd65
  42. static-bind ip-address 192.168.99.141 mask 255.255.254.0 hardware-address f439-09f3-1efa
  43. static-bind ip-address 192.168.99.188 mask 255.255.254.0 hardware-address b4b6-8633-57f9
  44. static-bind ip-address 192.168.99.198 mask 255.255.254.0 hardware-address 1062-e55c-c521
  45. static-bind ip-address 192.168.99.199 mask 255.255.254.0 hardware-address b4a3-82b1-cc27
  46. static-bind ip-address 192.168.99.224 mask 255.255.254.0 hardware-address 040e-3ce9-df6f
  47. #
  48. dhcp server ip-pool vlan20
  49. gateway-list 192.168.6.1
  50. network 192.168.6.0 mask 255.255.254.0
  51. dns-list 114.114.114.114 8.8.8.8
  52. #
  53. interface NULL0
  54. #
  55. interface Vlan-interface1
  56. #
  57. interface Vlan-interface10
  58. ip address 192.168.99.1 255.255.254.0
  59. #
  60. interface Vlan-interface20
  61. ip address 192.168.6.1 255.255.254.0
  62. #
  63. interface Vlan-interface100
  64. ip address 192.168.2.2 255.255.255.0
  65. #
  66. interface FortyGigE1/0/33
  67. port link-mode bridge
  68. #
  69. interface FortyGigE1/0/34
  70. port link-mode bridge
  71. #
  72. interface GigabitEthernet1/0/1
  73. port link-mode bridge
  74. port access vlan 10
  75. #
  76. interface GigabitEthernet1/0/2
  77. port link-mode bridge
  78. port access vlan 10
  79. #
  80. interface GigabitEthernet1/0/3
  81. port link-mode bridge
  82. port access vlan 10
  83. #
  84. interface GigabitEthernet1/0/4
  85. port link-mode bridge
  86. port access vlan 10
  87. #
  88. interface GigabitEthernet1/0/5
  89. port link-mode bridge
  90. port access vlan 10
  91. #
  92. interface GigabitEthernet1/0/6
  93. port link-mode bridge
  94. port access vlan 10
  95. #
  96. interface GigabitEthernet1/0/7
  97. port link-mode bridge
  98. port access vlan 10
  99. #
  100. interface GigabitEthernet1/0/8
  101. port link-mode bridge
  102. port access vlan 10
  103. #
  104. interface GigabitEthernet1/0/9
  105. port link-mode bridge
  106. port access vlan 10
  107. #
  108. interface GigabitEthernet1/0/10
  109. port link-mode bridge
  110. port access vlan 10
  111. #
  112. interface GigabitEthernet1/0/11
  113. port link-mode bridge
  114. port access vlan 10
  115. #
  116. interface GigabitEthernet1/0/12
  117. port link-mode bridge
  118. port access vlan 10
  119. #
  120. interface GigabitEthernet1/0/13
  121. port link-mode bridge
  122. port access vlan 10
  123. #
  124. interface GigabitEthernet1/0/14
  125. port link-mode bridge
  126. port access vlan 10
  127. #
  128. interface GigabitEthernet1/0/15
  129. port link-mode bridge
  130. port access vlan 10
  131. #
  132. interface GigabitEthernet1/0/16
  133. port link-mode bridge
  134. port access vlan 10
  135. #
  136. interface GigabitEthernet1/0/17
  137. port link-mode bridge
  138. port access vlan 10
  139. #
  140. interface GigabitEthernet1/0/18
  141. port link-mode bridge
  142. port access vlan 10
  143. #
  144. interface GigabitEthernet1/0/19
  145. port link-mode bridge
  146. port access vlan 10
  147. #
  148. interface GigabitEthernet1/0/20
  149. port link-mode bridge
  150. port access vlan 10
  151. #
  152. interface GigabitEthernet1/0/21
  153. port link-mode bridge
  154. port access vlan 20
  155. #
  156. interface GigabitEthernet1/0/22
  157. port link-mode bridge
  158. port access vlan 20
  159. #
  160. interface GigabitEthernet1/0/23
  161. port link-mode bridge
  162. port access vlan 20
  163. #
  164. interface GigabitEthernet1/0/24
  165. port link-mode bridge
  166. port access vlan 20
  167. #
  168. interface GigabitEthernet1/0/25
  169. port link-mode bridge
  170. combo enable copper
  171. #
  172. interface GigabitEthernet1/0/26
  173. port link-mode bridge
  174. combo enable copper
  175. #
  176. interface GigabitEthernet1/0/27
  177. port link-mode bridge
  178. combo enable copper
  179. #
  180. interface GigabitEthernet1/0/28
  181. port link-mode bridge
  182. port access vlan 100
  183. combo enable copper
  184. #
  185. interface GigabitEthernet1/0/29
  186. port link-mode bridge
  187. #
  188. interface GigabitEthernet1/0/30
  189. port link-mode bridge
  190. #
  191. interface M-GigabitEthernet0/0/0
  192. #
  193. interface Ten-GigabitEthernet1/0/31
  194. port link-mode bridge
  195. #
  196. interface Ten-GigabitEthernet1/0/32
  197. port link-mode bridge
  198. #
  199. scheduler logfile size 16
  200. #
  201. line class aux
  202. user-role network-admin
  203. #
  204. line class usb
  205. user-role network-admin
  206. #
  207. line class vty
  208. user-role network-operator
  209. #
  210. line aux 0
  211. user-role network-admin
  212. #
  213. line vty 0 4
  214. user-role level-15
  215. user-role levle-15
  216. user-role network-operator
  217. #
  218. line vty 5 63
  219. user-role network-operator
  220. #
  221. ip route-static 0.0.0.0 0 192.168.2.1
  222. #
  223. radius scheme system
  224. user-name-format without-domain
  225. #
  226. domain system
  227. #
  228. domain default enable system
  229. #
  230. role name level-0
  231. description Predefined level-0 role
  232. #
  233. role name level-1
  234. description Predefined level-1 role
  235. #
  236. role name level-2
  237. description Predefined level-2 role
  238. #
  239. role name level-3
  240. description Predefined level-3 role
  241. #
  242. role name level-4
  243. description Predefined level-4 role
  244. #
  245. role name level-5
  246. description Predefined level-5 role
  247. #
  248. role name level-6
  249. description Predefined level-6 role
  250. #
  251. role name level-7
  252. description Predefined level-7 role
  253. #
  254. role name level-8
  255. description Predefined level-8 role
  256. #
  257. role name level-9
  258. description Predefined level-9 role
  259. #
  260. role name level-10
  261. description Predefined level-10 role
  262. #
  263. role name level-11
  264. description Predefined level-11 role
  265. #
  266. role name level-12
  267. description Predefined level-12 role
  268. #
  269. role name level-13
  270. description Predefined level-13 role
  271. #
  272. role name level-14
  273. description Predefined level-14 role
  274. #
  275. user-group system
  276. #
  277. local-user admin class manage
  278. password hash $h$6$PgCFWtk13BdvH2LM$iMAIONu1TLZXZxVxrNn6hJCphChJMInFp5QmDoTibBCK7LNyUdknp4AmzoSIcsu/1Q7xbrf+IJiK9K4+ShiFmw==
  279. service-type telnet http
  280. authorization-attribute user-role level-15
  281. authorization-attribute user-role network-operator
  282. #
  283. ip http enable
  284. #
  285. return
粉丝:14人 关注:4人
电脑的地址是dhcp获取的吗?试一下在交换机上,将该地址池的网关设置成路由器地址
粉丝:6人 关注:1人
1.您旁挂在路由器的lan口还是wan口?
2.若旁挂lan口,路由器wan口接外网的情况,网关配置为192.168.99.55,一般是没有问题的,可以测试下二层是否互通。
粉丝:124人 关注:6人
1、如果路由器使用的是WAN口连接的交换机,交换机的接口配置为access vlan 10。同时路由器的WAN口配置为DHCP自动获取,同时电脑的IP也修改为自动获取。
2、如果路由器使用的是LAN口连接交换机,首先为了防止DHCP混乱,路由器的DHCP需要关闭。电脑的IP设置为自动获取。
