5130交换机日志信息
2020-06-05提问
  • 1收藏,1037浏览
核心与5130二层互联,5130交换机级联端口频繁UP/Dwon .
%Feb 9 07:38:48:995 2013 access-0.28 IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/28 changed to up. %Feb 9 07:38:49:002 2013 access-0.28 IFNET/5/LINK_UPDOWN: Line protocol state o n the interface Ten-GigabitEthernet1/0/28 changed to up. %Feb 9 07:38:49:142 2013 access-0.28 STP/6/STP_DETECTED_TC: Instance 0's port T en-GigabitEthernet1/0/28 detected a topology change. %Feb 9 07:38:49:260 2013 access-0.28 STP/6/STP_NOTIFIED_TC: Instance 0's port T en-GigabitEthernet1/0/28 was notified a topology change. %Feb 9 07:38:49:341 2013 access-0.28 LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridg e agent neighbor created on port Ten-GigabitEthernet1/0/28 (IfIndex 28), neighbo r's chassis ID is 542b-deb3-2600, port ID is Ten-GigabitEthernet1/0/0/27. %Feb 9 07:38:49:419 2013 access-0.28 IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/28 changed to down. %Feb 9 07:38:49:422 2013 access-0.28 IFNET/5/LINK_UPDOWN: Line protocol state o n the interface Ten-GigabitEthernet1/0/28 changed to down. %Feb 9 07:38:51:590 2013 access-0.28 VCF/6/VCF_UP_LINK: In phase 2.0.9, device with MAC address f474-885f-78a8 discovered uplink interface Ten-GigabitEthernet1 /0/28. %Feb 9 07:38:52:085 2013 access-0.28 IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/28 changed to up.
QAZWSX 九段
粉丝:21人 关注:4人
这类问题一般都是链路问题导致,建议现场更换网线或光模块/光纤观察。
