SecPath F1000-A-EI
2018-03-30提问
  • 1收藏,1492浏览
  PING 11.131.248.9: 3000 data bytes, press CTRL_C to break
 Reply from 11.131.248.9: bytes=2040 Sequence=0 ttl=30 time=20 ms
 Wrong data byte #2040 should be 0xf0 but was 0x0
 Reply from 11.131.248.9: bytes=2040 Sequence=1 ttl=30 time=22 ms
 Reply from 11.131.248.9: bytes=2040 Sequence=2 ttl=30 time=21 ms
这个现象为防火墙哪里限制了大包么
不是大包吧,看着像校验或者其他错误,联系下400吧
