SecPath F100-C-G2
2018-03-30提问
  • 1收藏,1239浏览
怎么做端口映射,具体一点
粉丝:12人 关注:0人
入系统视图
进入接口视图
interface interface-type interface-number
配置普通内部服务器
外网地址单一,未使用外网端口或外网端口单一
nat server [ protocol pro-type ] global { global-address | current-interface| interface interface-type interface-number } [ global-port ] [ vpn-instanceglobal-vpn-instance-name ] inside local-address [ local-port ] [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ reversible ] [ rule rule-name ] [ disable ]
四者至少选其一
缺省情况下,不存在内部服务器
一个接口下可以配置多个普通内部服务器
外网地址单一,外网端口连续
nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2 [ vpn-instance global-vpn-instance-name ] inside { { local-address | local-address1 local-address2 } local-port | local-address local-port1 local-port2 } [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | nameipv4-acl-name } ] [ rule rule-name ] [ disable ]
外网地址连续,未使用外网端口或外网端口单一
nat server protocol pro-type global global-address1 global-address2 [ global-port ] [ vpn-instance global-vpn-instance-name ] inside { local-address | local-address1 local-address2 } [ local-port ] [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ rulerule-name ] [ disable ]
外网地址连续,外网端口单一
nat server protocol pro-type global global-address1 global-address2  global-port [ vpn-instance global-vpn-instance-name ] inside local-address local-port1 local-port2 [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ rule rule-name ] [ disable ]
 官网配置指导上面都有
http://www.h3c.com/cn/d_201711/1044654_30005_0.htm#_Toc496801291
