H3C。ADSL的配置命令 和IPsec VPN配置
2020-06-16提问
  • 1收藏,1400浏览
配置命令及原理
粉丝:111人 关注:1人
北京某客户需要F1060配置vpn-instance并跨公网与对端防火墙对接IPSEC VPN
图一:组网拓扑
相关设备的接口ip地址和路由配置略。
F1060-1重要配置:
ip vpn-instance dx100
 route-distinguisher 400:1
 vpn-target 400:1 import-extcommunity
 vpn-target 400:1 export-extcommunity
nat address-group 4
 address 61.134.x.x 61.134.x.x
interface LoopBack0
 ip binding vpn-instance dx100
 ip address 10.32.51.10 255.255.255.255
interface GigabitEthernet1/0/19
 port link-mode route
 description dx100
 combo enable copper
 duplex full
 speed 1000
 ip address 61.134.x.x 255.255.255.224
 nat outbound 3004 address-group 4 vpn-instance dx100
 ipsec apply policy ntt
object-policy ip Trust-Untrust
 rule 0 pass vrf dx
 rule 1 pass vrf lt
 rule 2 pass vrf vpn
 rule 3 pass vrf dx100
 rule 4 pass vrf management
object-policy ip Untrust-trust
 rule 0 pass vrf dx
 rule 1 pass vrf lt
 rule 2 pass vrf vpn
security-zone name Trust
 import interface LoopBack0
security-zone name DMZ
security-zone name Untrust
 import interface GigabitEthernet1/0/19
zone-pair security source Trust destination Untrust
 object-policy apply ip Trust-Untrust
zone-pair security source Untrust destination Trust
 object-policy apply ip Untrust-trust
 ip route-static vpn-instance dx100 0.0.0.0 0 61.134.x.x
acl advanced 3004
 description dx100
 rule 0 deny ip vpn-instance dx100 source 10.32.5.0 0.0.0.255
 rule 1 deny ip vpn-instance dx100 source 10.32.6.0 0.0.0.255
 rule 2 deny ip vpn-instance dx100 source 10.32.7.0 0.0.0.255
 rule 3 deny ip vpn-instance dx100 source 10.32.1.41 0
 rule 4 deny ip vpn-instance dx100 source 10.32.51.10 0 destination 10.0.109.251 0
 rule 5 permit ip vpn-instance dx100 source 192.168.29.10 0
 rule 6 permit ip vpn-instance dx100 source 192.168.29.11 0
 rule 7 permit ip vpn-instance dx100 source 1.1.1.0 0.0.0.255
 rule 9 permit ip vpn-instance dx100 source 10.100.0.0 0.0.255.255
 rule 15 permit ip vpn-instance dx100 source 172.21.252.0 0.0.0.255
 rule 20 permit ip vpn-instance dx100 source 172.21.253.0 0.0.0.255
 rule 25 permit ip vpn-instance dx100 source 192.168.253.0 0.0.0.255
 rule 30 permit ip vpn-instance dx100 source 172.21.1.24 0
 rule 35 permit ip vpn-instance dx100 source 10.32.0.0 0.0.255.255
 rule 40 permit ip vpn-instance dx100 source 172.21.1.250 0
 rule 45 permit ip vpn-instance dx100 source 172.21.1.248 0
 rule 50 permit ip vpn-instance dx100 source 192.168.0.0 0.0.0.255
acl advanced 3020
 description to ipsec
 rule 20 permit ip vpn-instance dx100 source 10.32.51.10 0 destination 10.0.109.251 0
ipsec transform-set ntt
 esp encryption-algorithm 3des-cbc
 esp authentication-algorithm md5
ipsec policy ntt 1 isakmp
 transform-set ntt
 security acl 3020
 local-address 61.134.x.x
 remote-address 111.20.x.x
 ike-profile ntt
ike profile ntt
 keychain ntt
 dpd interval 5 on-demand
 local-identity address 61.134.x.x
 match remote identity address 111.20.x.x 255.255.255.248 vpn-instance dx100
 proposal 2
ike proposal 2
ike keychain ntt vpn-instance dx100
 pre-shared-key address 111.20.x.x 255.255.255.255 key cipher $c$3$7X4X7l8XgC90/R3l1zUac0pcTsjW4g==
F1060-2配置:
interface LoopBack0
 ip address 10.0.109.251 255.255.255.255
interface GigabitEthernet1/0/9
 description to LT
 combo enable copper
 ip address 111.20.x.x 255.255.255.248
 nat outbound 3000 address-group 1
 rule 0 pass
object-policy ip Untrust-Trust
 rule 0 pass
 import interface GigabitEthernet1/0/9
 object-policy apply ip Untrust-Trust
 ip route-static 0.0.0.0 0 111.20.x.x
acl advanced 3000
 rule 2 deny ip source 10.0.109.251 0 destination 10.32.51.0 0.0.0.255
 rule 4 deny ip source 10.0.109.251 0 destination 10.21.100.32 0
 rule 6 deny ip source 10.0.109.251 0 destination 10.21.100.95 0
 rule 8 deny ip source 10.0.109.251 0 destination 10.21.100.91 0
 rule 20 permit ip
acl advanced 3010
 rule 10 permit ip source 10.0.109.251 0 destination 10.32.51.10 0
 rule 20 permit ip source 10.0.109.251 0 destination 10.21.100.32 0
 rule 30 permit ip source 10.0.109.251 0 destination 10.21.100.91 0
 rule 40 permit ip source 10.0.109.251 0 destination 10.21.100.95 0
ipsec transform-set zjm
ipsec policy 1 10 isakmp template ipsec
 transform-set ntt
 security acl 3010
 local-address 111.20.x.x
 remote-address 61.134.x.x
 ike-profile ntt
ike profile ntt
 keychain ntt
 local-identity address 111.20.x.x
 match remote identity address 61.134.x.x 255.255.255.224
 proposal 2
ike keychain ntt
 pre-shared-key address 61.134.x.x 255.255.255.255 key cipher $c$3$7REqNgpfKN60YGuJwReO4LykA00UMw==
验证结果:
<H3C>ping -a 10.32.51.10 -vpn-instance dx100 10.0.109.251
Ping 10.0.109.251 (10.0.109.251) from 10.32.51.10: 56 data bytes, press CTRL_C to break
56 bytes from 10.0.109.251: icmp_seq=0 ttl=255 time=9.000 ms
56 bytes from 10.0.109.251: icmp_seq=1 ttl=255 time=3.000 ms
56 bytes from 10.0.109.251: icmp_seq=2 ttl=255 time=2.000 ms
56 bytes from 10.0.109.251: icmp_seq=3 ttl=255 time=3.000 ms
56 bytes from 10.0.109.251: icmp_seq=4 ttl=255 time=2.000 ms
--- Ping statistics for 10.0.109.251 in VPN instance dx100 ---
round-trip min/avg/max/std-dev = 2.000/3.800/9.000/2.638 ms
<H3C> dis ipsec sa
Interface: GigabitEthernet1/0/19
  IPsec policy: ntt
  Sequence number: 1
  Mode: ISAKMP
    Tunnel id: 0
    Encapsulation mode: tunnel
    Perfect Forward Secrecy:
    Inside VPN: dx100
    Extended Sequence Numbers enable: N
    Traffic Flow Confidentiality enable: N
    Path MTU: 1444
    Tunnel:
        local  address: 61.134.x.x
        remote address: 111.20.x.x
    Flow:
        sour addr: 10.32.51.10/255.255.255.255  port: 0  protocol: ip
        dest addr: 10.0.109.251/255.255.255.255  port: 0  protocol: ip
    [Inbound ESP SAs]
      SPI: 246074279 (0x0eaacba7)
      Connection ID: 4294967296
      Transform set: ESP-ENCRYPT-3DES-CBC ESP-AUTH-MD5
      SA duration (kilobytes/sec): 1843200/3600
      SA remaining duration (kilobytes/sec): 1843199/3527
      Max received sequence-number: 9
      Anti-replay check enable: Y
      Anti-replay window size: 64
      UDP encapsulation used for NAT traversal: N
      Status: Active
    [Outbound ESP SAs]
      SPI: 2249709047 (0x8617d5f7)
      Connection ID: 4294967297
      Max sent sequence-number: 9
      Status: Active
<H3C> dis ike sa
    Connection-ID   Remote            Flag         DOI
    1            111.20.x.x        RD           IPsec
Flags:
RD--READY RL--REPLACED FD-FADING RK-REKEY
1、ike profile中 match remote address 要绑定vpn-instance
2、ike keychain也要绑定vpn
准备问什么呢
粉丝:124人 关注:6人
1、可参考如下PPPOE的配置命令:
[H3C]sysname PPPOE
[PPPOE]acl basic 2000
[PPPOE-acl-ipv4-basic-2000]rule 0 permit source any
[PPPOE-acl-ipv4-basic-2000]quit
[PPPOE]int gi 0/1
[PPPOE-GigabitEthernet0/1]des
[PPPOE-GigabitEthernet0/1]ip address 202.1.100.2 30
[PPPOE-GigabitEthernet0/1]nat outbound 2000
[PPPOE-GigabitEthernet0/1]quit
[PPPOE]ip route-static 0.0.0.0 0.0.0.0 202.1.100.1
[PPPOE]
PPPOE拨号关键配置点:
[PPPOE]local-user weijianing class network  //创建用户名、密码,赋予PPP登陆的权限
New local user added.
[PPPOE-luser-network-weijianing]password simple weijianing
[PPPOE-luser-network-weijianing]service-type ppp
[PPPOE-luser-network-weijianing]quit
[PPPOE]domain name system  //配置域,验证方式为本地PPP认证
[PPPOE-isp-system]authentication ppp local
[PPPOE-isp-system]quit
[PPPOE]ip pool weijianing 192.168.10.2 192.168.10.100  //创建地址池,用于PPPOE客户端拨号的IP地址分配
[PPPOE]int Virtual-Template 1  //创建虚拟模板,调用域和地址池
[PPPOE-Virtual-Template1]ip address 192.168.10.1 255.255.255.0
[PPPOE-Virtual-Template1]ppp authentication-mode pap domain system
[PPPOE-Virtual-Template1]remote address pool weijianing
[PPPOE-Virtual-Template1]quit
[PPPOE]int gi 0/0
[PPPOE-GigabitEthernet0/0]pppoe-server bind virtual-template 1  //将PPPOE与虚拟模板绑定到物理接口
[PPPOE-GigabitEthernet0/0]quit
2、以下是具体的案例连接,里面包含详细的配置过程及测试效果:
https://zhiliao.h3c.com/theme/details/101879
3、以下是Ipsec的典型组网配置案例,请参考:
如下是ipsec + IKE预共享密钥:
https://zhiliao.h3c.com/theme/details/102865
 如下是Ipsec+IKE野蛮模式:
https://zhiliao.h3c.com/theme/details/102893
粉丝:111人 关注:1人
