怎么查看链路拥塞,丢包
2020-06-17提问
  • 1收藏,2265浏览
网速不给力,但是测试网速很快,根本达不到,也就能达到测试网速的百分之十,这是什么问题
粉丝:19人 关注:0人
交换机的话直接dis interface查看对应接口last 300 sec的值,也可以在接口下通过flow-interval 5更改查看周期为5S,如果查看到Last 5 seconds input到了带宽值或者接近了,则可能发生了拥塞。查看丢包的话也可以通过在设备上流统来确认
[2032-S10500]dis int Ten-GigabitEthernet 1/2/0/1
Ten-GigabitEthernet1/2/0/1
Current state: DOWN
Line protocol state: DOWN
IP packet frame type: Ethernet II, hardware address: 84d9-3123-b800
Description: Ten-GigabitEthernet1/2/0/1 Interface
Bandwidth: 10000000 kbps
Loopback is not set
Media type is not sure, port hardware type is no connector
Flow-control is not enabled
Maximum frame length: 9216
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
PVID: 1
MDI type: Automdix
Port link-type: Access
 Tagged VLANs:   None
 Untagged VLANs: 1
Port priority: 0
Last link flapping: Never
Current system time:2023-06-18 09:12:50
Last time when physical state changed to up:-
Last time when physical state changed to down:2023-06-12 09:42:49
 Peak input rate: 0 bytes/sec, at 2023-06-12 09:43:27
 Peak output rate: 0 bytes/sec, at 2023-06-12 09:43:27
 Last 5 seconds input: 0 packets/sec 0 bytes/sec -%
 Last 5 seconds output: 0 packets/sec 0 bytes/sec -%
 Input (total):  0 packets, 0 bytes
 Input (normal):  0 packets, - bytes
         0 CRC, 0 frame, - overruns, 0 aborts
         - ignored, - parity errors
 Output (normal): 0 packets, - bytes
         0 lost carrier, - no carrier
