msr360-4-pwr
2020-06-17提问
  • 1收藏,1559浏览
无线网有以下警告,乍怎么处理 -VSD=level-global-307b-acb0-aec0; BlockAck flood detected. 2016-01-13 11:58:32 通知 -VSD=level-global-307b-acb0-bd00; Beacon flood detected. 2016-01-13 11:58:21 通知 -VSD=level-global-307b-acb0-bd00; Probe request flood detected. 2016-01-13 11:57:57 通知 -VSD=level-global-307b-acb0-bd00-SrcMAC=0a74-9c97-3f25; AP impersonation attack detected. 2016-01-13 11:57:32 通知 -VSD=level-global-307b-acb0-bd00-SrcMAC=0674-9c97-3f25; AP impersonation attack detected. 2016-01-13 11:57:32 通知 -VSD=level-global-dcda-8099-29a0; Probe request flood detected. 2016-01-13 11:57:26 通知 -VSD=level-global-307b-acb0-bd00; Null data flood detected. 2016-01-13 11:56:19 通知 -VSD=level-global-307b-acb0-aec0; Probe request flood detected. 2016-01-13 11:56:15 通知 -VSD=level-global-307b-acb0-aec0; Null data flood detected. 2016-01-13 11:56:12 通知 admin logged out from 10.10.10.9 2016-01-13 11:55:53 通知 -VSD=level-global-dcda-8099-29a0; RTS flood detected. 2016-01-13 11:54:56 通知 -VSD=level-global-dcda-8099-29a0; BlockAck flood detected. 2016-01-13 11:54:23 通知 -VSD=level-global-307b-acb0-aec0; CTS flood detected. 2016-01-13 11:54:17 通知 -VSD=level-global-dcda-8099-29a0; Null data flood detected. 2016-01-13 11:53:20 通知 -VSD=level-global-dcda-8099-29a0; Beacon flood detected. 2016-01-13 11:53:20 通知 -VSD=level-global-dcda-8099-29a0; CTS flood detected. 2016-01-13 11:53:14 通知 -VSD=level-global-307b-acb0-bd00; Authentication flood detected. 2016-01-13 11:53:10 通知 -VSD=level-global-307b-acb0-bd00; Association request flood detected. 2016-01-13 11:53:10 通知 -VSD=level-global-307b-acb0-aec0; Beacon flood detected. 2016-01-13 11:52:57 通知 -VSD=level-global-307b-acb0-aec0; Association request flood detected. 2016-01-13 11:52:48 通知 -VSD=level-global-307b-acb0-aec0; Authentication flood detected. 2016-01-13 11:52:48 通知 -VSD=level-global-307b-acb0-aec0-SrcMAC=40f4-20d1-7812; AP spoofing client detected. 2016-01-13 11:52:36 通知 -VSD=level-global-307b-acb0-bd00-SrcMAC=307b-acb0-aec1; AP impersonation attack detected. 2016-01-13 11:52:15 通知 -VSD=level-global-307b-acb0-bd00-SrcMAC=307b-acb0-aec0; AP impersonation attack detected. 2016-01-13 11:52:15 通知 -VSD=level-global-307b-acb0-bd00; RTS flood detected. 2016-01-13 11:52:06 通知 -VSD=level-global-307b-acb0-bd00-SrcMAC=0a74-9c67-f400; AP impersonation attack detected. 2016-01-13 11:52:05 通知 -VSD=level-global-307b-acb0-bd00-SrcMAC=0674-9c67-f400; AP impersonation attack detected. 2016-01-13 11:52:05 通知 -VSD=level-global-307b-acb0-bd00; CTS flood detected. 2016-01-13 11:51:49 通知 -VSD=level-global-307b-acb0-aec0; RTS flood detected. 2016-01-13 11:49:51 通知 -VSD=level-global-307b-acb0-bd00; BlockAck flood detected. 2016-01-13 11:49:44 通知 -VSD=level-global-dcda-8099-29a0-SrcMAC=4459-e322-566c; AP spoofing client detected. 2016-01-13 11:49:42 通知 -VSD=level-global-307b-acb0-aec0; BlockAck flood detected. 2016-01-13 11:48:16 通知 -VSD=level-global-307b-acb0-bd00; Beacon flood detected. 2016-01-13 11:48:05 通知 -VSD=level-global-307b-acb0-bd00; Probe request flood detected. 2016-01-13 11:47:54 通知 -VSD=level-global-dcda-8099-29a0; Probe request flood detected.
skylar 九段
粉丝:42人 关注:0人
flood authentication命令用来开启认证请求帧泛洪攻击检测功能。
undo flood authentication命令用来关闭认证请求帧泛洪攻击检测功能。
flood authentication [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
认证请求帧泛洪攻击检测功能处于关闭状态。
攻击检测策略视图
interval interval-value:检测认证请求帧的统计周期,取值范围为1~3600,单位为秒,缺省值为60秒。
quiet quiet-value:发送告警信息后的静默时间,取值范围为5~604800,单位为秒,缺省值为600秒。在静默期间,设备在统计周期内收到的认证请求帧即使达到触发告警阈值,设备也不会发送告警信息。
threshold threshold-value:检测认证请求帧达到触发阈值,取值范围为1~100000,缺省值为50。当设备在一个统计周期内检测到的认证请求帧达到触发阈值,即判定设备受到认证请求帧泛洪攻击,设备会发送告警信息。
# 开启认证请求帧泛洪攻击检测功能,统计周期为100秒,触发告警阈值为100,静默时间为360秒。
[Sysname] wips
[Sysname-wips] detect policy home
[Sysname-wips-dtc-home] flood authentication interval 100 threshold 100 quiet 360
flood deauthentication命令用来开启解除认证帧泛洪攻击检测功能。
undo flood deauthentication命令用来关闭解除认证帧泛洪攻击检测功能。
flood deauthentication [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
解除认证帧泛洪攻击检测功能处于关闭状态。
攻击检测策略视图
interval interval-value:检测解除认证帧的统计周期,取值范围为1~3600,单位为秒,缺省值为60。
quiet quiet-value:发送告警信息后的静默时间,取值范围为5~604800,单位为秒,缺省值为600。在静默期间,设备在统计周期内收到的解除认证帧即使达到触发告警阈值,设备也不会发送告警信息。
threshold threshold-value:检测解除认证帧达到触发阈值,取值范围为1~100000,缺省值为50。当设备在一个统计周期内检测到的解除认证帧达到触发阈值,即判定设备受到解除认证帧泛洪攻击,设备会发送告警信息。
#开启解除认证帧泛洪攻击检测功能,统计周期为100秒,触发告警阈值为100,静默时间为360秒。
[Sysname] wips
[Sysname-wips-dtc-home] flood deauthentication interval 100 threshold 100 quiet 360
flood beacon命令用来开启Beacon帧泛洪攻击检测功能。
undo flood beacon命令用来关闭Beacon帧泛洪攻击检测功能。
flood beacon [ interval interval-value | quiet quiet-value | threshold threshold-value ] *
undo flood beacon
Beacon帧泛洪攻击检测功能处于关闭状态。
攻击检测策略视图
interval interval-value:检测Beacon帧的统计周期,取值范围为1~3600,单位为秒,缺省值为60。
quiet quiet-value:发送告警信息后的静默时间,取值范围为5~604800,单位为秒,缺省值为600。在静默期间,设备在统计周期内收到的Beacon帧即使达到触发告警阈值,设备也不会发送告警信息。
threshold threshold-value:检测Beacon帧达到触发阈值,取值范围为1~100000,缺省值为50。当设备在一个统计周期内检测到的Beacon帧达到触发阈值,即判定设备受到Beacon帧泛洪攻击,设备会发送告警信息。
# 开启Beacon帧泛洪攻击检测功能,统计周期为100秒,触发告警阈值为100,静默时间为360秒。
[Sysname] wips
[Sysname-wips-dtc-home] flood beacon interval 100 threshold 100 quiet 360
