想把这个fit AP 刷成胖AP来用,试了官网指定的前三个版都报错!不支持。求大哥们指点下。boot-loader file flash:/WA4300-CMW520-R1508P04-FAT.bin main This command will set the main startup software images. Please do not reboot the device during the upgrade. Continue? [Y/N]:y flash:/WA4300-CMW520-R1508P04-FAT.bin is not supported by the device.
有没有 v5的FIT版本。
文件你就用fat那个就可以
操作步骤一样
