MSR56-60 v7.1.042R007p02 子接口drop
2018-04-01提问
  • 1收藏,1090浏览
yfj 零段
 572096015 packets output, 402488785477 bytes, 27271533 drops  ;
问题一、在子接口有应用出方向的qos(wred) ,怎么查看为什么有drop?
​interface GigabitEthernet2/5/3.506
 bandwidth 9500
ip address x.x.x.x
qos reserved-bandwidth pct 100
qos apply policy QoS_default outbound
vlan-type dot1q vid 506
GigabitEthernet2/5/3 Current state: UP
 Line protocol state: UP
 Interface Bandwidth: 1000000kbps
 Maximum Transmit Unit: 1500
1000Mb/s, Full-duplex, link type: autonegotiation,
  flow-control: disabled Output queue -
Urgent queuing: Size/Length/Discards 0/100/0 Output queue -
Protocol queuing: Size/Length/Discards 0/500/0 Output queue -
FIFO queuing: Size/Length/Discards 0/75/177861526
 Last clearing of counters: 12:12:49 Wed 09/06/2017
Last 300 seconds input rate: 3391976.00 bytes/sec, 27135808 bits/sec, 2850.45 packets/sec
Last 300 seconds output rate: 474452.46 bytes/sec, 3795619 bits/sec, 560.89 packets/sec
Input: 2379616170 packets, 4034688548 bytes 8821151 broadcasts, 17238424 multicasts, 0 pauses 0 errors, 0 runts, 0 giants 0 CRC, 0 overruns 0 drops, 0 no buffers
 Output: 109451113 packets, 4270296458 bytes 5634 broadcasts, 0 multicasts, 0 pauses 0 errors, 0 underruns, 0 collisions 0 deferred, 0 lost carriers
Current state: UP Line protocol state: UP
 Bandwidth: 9500kbps
Output queue - Class Based Queuing: Size/Discards 0/0
 Queue size: EF/AF/BE 0/0/0 BE
queues: Active/Max active/Total 0/0/256 AF queues:
 Allocated 6 Bandwidth(kbps): Available/Max reserve 2500/9500
 7775040664 packets input, 10136215095565 bytes, 0 drops
