l2tp over ipsec在hcl搞了无数次,始终不通
2020-06-21提问
  • 1收藏,1608浏览
粉丝:6人 关注:0人
不使用ipsec加密时,l2tp 隧道能起来,能正常访问内网,使用ipsec加密后,就不能正常拔号,IKE SA协商不起来,打开DEBUG后,发现报如下错误:
粉丝:111人 关注:0人
一般都是设置的问题,尤其是ipsec数据流看下是否异常,封装的是否是L2TP的流量
建议参考下面案例比对下:
轻轻松松配上网(路由):https://zhiliao.h3c.com/topic/huati/1247
粉丝:6人 关注:0人
详细配置如下,另外说明一下,我是照到手册搞的,那种发手册来回答问题,就不用费心了,毕竟我是想解决问题,这个实验搞了几十次都不能成功,有点不心干
<H3C>dis cur
version 7.1.075, Alpha 7571
sysname H3C
ip pool 1 192.168.66.2 192.168.66.200
system-working-mode standard
xbar load-single
password-recovery enable
lpu-type f-series
vlan 1
interface Serial1/0
interface Serial2/0
interface Serial3/0
interface Serial4/0
interface Virtual-Template1
ppp authentication-mode ms-chap ms-chap-v2 chap
remote address pool 1
ip address 192.168.66.1 255.255.255.0
interface Virtual-Ethernet1
interface NULL0
interface GigabitEthernet0/0
port link-mode route
combo enable copper
ip address 200.1.1.2 255.255.255.0
ipsec apply policy 1
interface GigabitEthernet0/1
combo enable copper
interface GigabitEthernet0/2
combo enable copper
interface GigabitEthernet5/0
combo enable copper
interface GigabitEthernet5/1
combo enable copper
interface GigabitEthernet6/0
combo enable copper
interface GigabitEthernet6/1
combo enable copper
scheduler logfile size 16
line class aux
user-role network-operator
line class console
user-role network-admin
line class tty
line class vty
line aux 0
line con 0
line vty 0 63
domain name system
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
local-user h3c class network
password cipher $c$3$j1JebFHtNGqgtYf2ZpWC+BGvxYYopA==
service-type ppp
ipsec transform-set 1
encapsulation-mode transport
esp encryption-algorithm 3des-cbc
esp authentication-algorithm md5
ipsec transform-set 2
esp encryption-algorithm aes-cbc-128
esp authentication-algorithm sha1
ipsec transform-set 3
esp encryption-algorithm aes-cbc-256
ipsec transform-set 4
esp encryption-algorithm des-cbc
ipsec transform-set 5
ipsec transform-set 6
esp encryption-algorithm aes-cbc-192
ipsec policy-template 1 1
transform-set 1 2 3 4 5 6
ike-profile 1
ipsec policy 1 1 isakmp template 1
l2tp-group 1 mode lns
allow l2tp virtual-template 1
undo tunnel authentication
tunnel name h3c
l2tp enable
ike profile 1
keychain 1
local-identity address 200.1.1.2
match remote identity address 0.0.0.0 0.0.0.0
proposal 1 2 3 4 5 6
ike proposal 1
dh group2
ike proposal 2
dh group2
ike proposal 3
dh group2
ike proposal 4
dh group2
ike proposal 5
dh group2
ike proposal 6
dh group2
ike keychain 1
pre-shared-key address 0.0.0.0 0.0.0.0 key cipher $c$3$M7SEDFcrSUgraLQRrABjeW0fWrXi2c3jDw==
return
粉丝:10人 关注:7人
检查两侧的加密/验证算法,是否一致,key值是否正确
key值怎么检查呢?
小白白 发表时间:2020-06-21
就是共享密钥,你设备的第二阶段定义的加密和验证,与客户端不匹配的,客户端修改下,保持与设备一致
一页书 发表时间:2020-06-21
