f1000-ak115 sslvpn
2020-07-13提问
  • 1收藏,1130浏览
连接上,但是不能访问其他在线ip段地址
配置如下
<H3C>dis cu
 version 7.1.064, Ess 9514P04
 sysname H3C
context Admin id 1
 telnet server enable
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 irf member 1 priority 1
nat address-group 11
 dhcp enable
 dhcp server forbidden-ip 10.1.1.1 10.1.1.9
 dhcp server forbidden-ip 10.1.1.21 10.1.1.254
 password-recovery enable
vlan 1
vlan 10
vlan 20
object-group ip address 内网审核
 0 network host address 10.1.1.101
object-group ip address 爬虫
 0 network range 10.1.1.200 10.1.1.210
object-group ip address 外网
object-group service 审核ssh
object-group service 数据库
 0 service tcp destination lt 14331
 10 service tcp destination lt 3307
 20 service tcp destination lt 3308
 30 service tcp destination lt 16380
 40 service tcp destination lt 1434
object-group service 应用
 0 service tcp destination lt 60002
 10 service tcp destination lt 60003
 20 service tcp destination lt 60005
 30 service tcp destination lt 60006
 40 service tcp destination lt 60007
 50 service tcp destination lt 5501
 60 service tcp destination lt 28081
 70 service tcp destination lt 22026
 80 service tcp destination lt 20001
 90 service tcp destination lt 5051
 100 service tcp destination lt 5001
 110 service tcp destination lt 40015
 120 service tcp destination lt 60008
 130 service tcp destination lt 60009
 140 service tcp destination lt 60010
 150 service tcp destination lt 51003
 160 service udp destination lt 1195
 170 service udp destination lt 11941
 180 service tcp destination lt 4431
object-group service 远程桌面
 0 service tcp destination lt 3390
dhcp server ip-pool vl10
 gateway-list 10.1.1.1
 network 10.1.1.0 mask 255.255.255.0
 dns-list 222.172.200.68 61.166.150.123
dhcp server ip-pool vl110
interface NULL0
interface Vlan-interface10
interface GigabitEthernet1/0/0
 port link-mode route
 combo enable copper
 ip address 192.168.0.1 255.255.255.0
 undo dhcp select server
 description GuideWan Interface
 combo enable copper
 ip address 1.1.1.66 255.255.255.252
 nat outbound 2000
 nat server protocol tcp global current-interface 5000 inside 10.1.1.100 5000
 nat server protocol tcp global current-interface 5050 inside 10.1.1.110 5050
 nat server protocol tcp global current-interface 5500 inside 10.1.1.201 5500
 nat server protocol tcp global current-interface 11011 inside 10.1.1.101 22
 nat server protocol tcp global current-interface 11022 inside 10.1.1.170 22
 nat server protocol tcp global current-interface 11023 inside 10.1.1.171 22
 nat server protocol tcp global current-interface 11433 inside 10.1.1.102 14330
 nat server protocol tcp global current-interface 11434 inside 10.1.1.120 1433
 nat server protocol tcp global current-interface 11435 inside 10.1.1.160 1433
 nat server protocol tcp global current-interface 16379 inside 10.1.1.110 16379
 nat server protocol tcp global current-interface 20000 inside 10.1.1.201 20000
 nat server protocol tcp global current-interface 21433 inside 10.1.1.210 14330
 nat server protocol tcp global current-interface 22022 inside 10.1.1.100 22
 nat server protocol tcp global current-interface 22025 inside 10.1.1.204 22
 nat server protocol tcp global current-interface 28080 inside 10.1.1.206 28080
 nat server protocol tcp global current-interface 32022 inside 10.1.1.110 22
 nat server protocol tcp global current-interface 33066 inside 10.1.1.111 3306
 nat server protocol tcp global current-interface 33077 inside 10.1.1.111 3307
 nat server protocol tcp global current-interface 33890 inside 10.1.1.150 3389
 nat server protocol tcp global current-interface 33899 inside 10.1.1.120 3389
 nat server protocol tcp global current-interface 40014 inside 10.1.1.110 40014
 nat server protocol tcp global current-interface 51001 inside 10.1.1.161 5000
 nat server protocol tcp global current-interface 51002 inside 10.1.1.101 5000
 nat server protocol tcp global current-interface 60001 inside 10.1.1.110 60001
 nat server protocol tcp global current-interface 60002 inside 10.1.1.110 60002
 nat server protocol tcp global current-interface 60003 inside 10.1.1.110 60003
 nat server protocol tcp global current-interface 60004 inside 10.1.1.110 60004
 nat server protocol tcp global current-interface 60005 inside 10.1.1.110 60005
 nat server protocol tcp global current-interface 60006 inside 10.1.1.110 60006
 nat server protocol tcp global current-interface 60007 inside 10.1.1.110 60007
 nat server protocol tcp global current-interface 60008 inside 10.1.1.110 60008
 nat server protocol tcp global current-interface 60009 inside 10.1.1.110 60009
 nat server protocol udp global current-interface 1194 inside 10.1.1.201 1194
 nat server protocol udp global current-interface 11940 inside 10.1.1.50 1194
 dhcp server apply ip-pool vl10
 ip address 172.20.20.252 255.255.224.0
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface SSLVPN-AC1
 ip address 10.1.10.1 255.255.255.0
object-policy ip pass
 rule 0 pass
security-zone name Local
security-zone name Trust
 import interface GigabitEthernet1/0/2
 import interface SSLVPN-AC1
security-zone name DMZ
 import interface GigabitEthernet1/0/3
security-zone name Untrust
 import interface GigabitEthernet1/0/1
security-zone name Management
 import interface GigabitEthernet1/0/0
 scheduler logfile size 16
line class aux
 user-role network-operator
line class console
 user-role network-admin
line class vty
line aux 0
line con 0
 authentication-mode scheme
line vty 0 63
 ip route-static 0.0.0.0 0 GigabitEthernet1/0/1 1.1.1.65
 undo info-center logbuffer
 ssh server enable
acl basic 2000
 rule 0 permit
acl advanced 3000
 rule 0 permit ip source 0.0.0.0 255.255.255.0
domain system
 aaa session-limit ftp 16
 aaa session-limit telnet 16
 aaa session-limit ssh 16
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group sslvpn
 authorization-attribute acl 2000
 authorization-attribute vlan 10
 authorization-attribute sslvpn-policy-group zyz
 identity-member user test1
user-group system
 identity-member user test2
local-user admin class manage
 password hash $h$6$UbIhNnPevyKUwfpm$LqR3+yg1IjNct39MkOR0H0iQXLkYB3jMqM4vbAeoXOhbabIIFnjJPEGR00YiYA1Sz4LiY3FmEdru2fOLMb1shQ==
 service-type ssh telnet terminal http https
 authorization-attribute user-role level-3
local-user test1 class network
 password cipher $c$3$5dm1dcOjdETTNKWXO1ZWMvsASMwig1Qzpg==
 service-type lan-access
 service-type sslvpn
 identity-group sslvpn
local-user test2 class network
 password cipher $c$3$DquS8FsEg8s7HvaJtYTDj6X1TCY15qCf5g==
 service-type sslvpn
 group sslvpn
 identity-group system
pki domain sslvpndomain
 certificate request entity zs
 public-key rsa general name sslvpnrsa
 undo crl check enable
pki entity zs
 common-name 1.1.1.66
ssl server-policy sslvpncl
 pki-domain sslvpndomain
 ciphersuite rsa_des_cbc_sha rsa_rc4_128_md5 rsa_rc4_128_sha rsa_3des_ede_cbc_sha exp_rsa_rc4_md5 exp_rsa_rc2_md5 exp_rsa_des_cbc_sha dhe_rsa_aes_128_cbc_sha dhe_rsa_aes_256_cbc_sha
 client-verify optional
 ip http port 8899
 ip http acl 2000
 ip http enable
 ip https port 4430
 ip https enable
 webui log enable
inspect block-source parameter-profile ips_block_default_parameter
inspect block-source parameter-profile url_block_default_parameter
traffic-policy
 rule name 爬虫
  action qos profile 爬虫
  source-address address-set 爬虫
 profile name 爬虫
  bandwidth downstream guaranteed 5000
  bandwidth downstream maximum 10000
  bandwidth upstream guaranteed 500
  bandwidth upstream maximum 1000
  remark dscp default
sslvpn ip address-pool sslvpnpool 10.1.10.10 10.1.10.254
sslvpn gateway sslvpngw
 ip address 1.1.1.66 port 4433
 service enable
sslvpn context sslvpn
 gateway sslvpngw
 ip-tunnel interface SSLVPN-AC1
 ip-tunnel address-pool sslvpnpool mask 255.255.255.0
 ip-route-list lyb
  include 10.1.1.0 255.255.255.0
  include 10.1.10.0 255.255.255.0
 policy-group q
 policy-group zyz
  filter ip-tunnel acl 3000
  ip-tunnel access-route force-all
  ip-tunnel access-route ip-route-list lyb
 default-policy-group zyz
 service enable
uapp-control
security-policy ip
 rule 0 name GuideSecPolicy
  action pass
  counting enable
  source-zone Trust
  source-zone Local
  source-zone DMZ
  source-zone Untrust
  source-zone Management
  destination-zone Untrust
  destination-zone Local
  destination-zone Trust
  destination-zone DMZ
  destination-zone Management
 rule 1 name dmz
  action pass
  counting enable
  source-zone Trust
  source-zone DMZ
  source-zone Local
 rule 2 name 审核
  action pass
  counting enable
  source-zone Untrust
  service ssh
 rule 3 name 数据库
  action pass
  counting enable
  source-zone Untrust
  service 数据库
 rule 4 name spc-cd
  action pass
  counting enable
  source-zone Untrust
  source-zone DMZ
  service 应用
 rule 5 name 临时
  action pass
  counting enable
  source-zone Untrust
  destination-zone vpn
  service 远程桌面
 rule 6 name te
  action pass
  counting enable
  source-zone Untrust
return
粉丝:124人 关注:6人
以下是SSL VPN的配置要点,请参考:
[SSL_VPN]acl advanced 3000
[SSL_VPN-acl-ipv4-adv-3000]rule 0 permit ip source any
[SSL_VPN-acl-ipv4-adv-3000]quit
[SSL_VPN]sslvpn ip address-pool weijianing 172.16.1.2 172.16.1.254
[SSL_VPN]int SSLVPN-AC 1
[SSL_VPN-SSLVPN-AC1]ip address 172.16.1.1 24
[SSL_VPN-SSLVPN-AC1]quit
[SSL_VPN]sslvpn gateway james
[SSL_VPN-sslvpn-gateway-james]ip address 192.168.200.200
[SSL_VPN-sslvpn-gateway-james]service enable
[SSL_VPN-sslvpn-gateway-james]quit
[SSL_VPN]sslvpn context james
[SSL_VPN-sslvpn-context-james]gateway james
[SSL_VPN-sslvpn-context-james]ip-tunnel address-pool weijianing mask 24
[SSL_VPN-sslvpn-context-james]ip-tunnel interface SSLVPN-AC 1
[SSL_VPN-sslvpn-context-james]ip-route-list james
[SSL_VPN-sslvpn-context-james-route-list-james]include 10.0.0.0 24
[SSL_VPN-sslvpn-context-james-route-list-james]quit
[SSL_VPN-sslvpn-context-james]policy-group ip
[SSL_VPN-sslvpn-context-james-policy-group-ip]filter ip-tunnel acl 3000
[SSL_VPN-sslvpn-context-james-policy-group-ip]ip-tunnel access-route ip-route-list james
[SSL_VPN-sslvpn-context-james-policy-group-ip]quit
[SSL_VPN-sslvpn-context-james]service enable
[SSL_VPN-sslvpn-context-james]quit
需注意下[SSL_VPN-sslvpn-context-james-route-list-james]include 10.0.0.0 24这条命令,相当于从SSL VPN网关配置路由的指向。确认已指向到位,同时内网也有路由指向到SSL VPN分配的IP地址段
以下是F1000-AK的用户手册连接,请参考:
https://www.h3c.com/cn/Service/Document_Software/Document_Center/IP_Security/FW_VPN/F1000-AK/
以下是基于IP的SSL VPN的典型组网配置案例的连接,请参考:
https://zhiliao.h3c.com/theme/details/102210
https://zhiliao.h3c.com/theme/details/102211
