1号主AP型号为:H3C WA2620-AGN-S 2号次AP型号为:H3C WA2620E-F 这个桥接1号的无线网络(但是找不到正确的MAC地址)有2个无线AP,已胖刷。都能正常使用,但是上网查询很多的资料没有关于H3C的AP的无线桥接文字教程及视频教程。特来求助1号AP做主要AP发射端,这个正常使用手机连接2号AP用来桥接1号无线信号,在网络不好的地方使用。特来求助,希望哪个技术大神能给与指点一下,万分感谢!赠人玫瑰,手有余香。
(0)
胖胖桥接案例如下
配置:
<WA2220-AG>dis cu
version 5.20, Release 1115P09
sysname WA2220-AG
radius trap authentication-server-down
radius trap accounting-server-down
domain default enable system
telnet server enable
port-security enable
vlan 1
vlan 2 to 3
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
user-group system
local-user admin
password simple h3capadmin
authorization-attribute level 3
service-type telnet
wlan mesh-profile 1
mesh-id outdoor
bind WLAN-MESH 1
mesh-profile enable
wlan mp-policy 1 //由于实验用的WA2220X-AG无外置天线,信号较弱。导致桥接不稳定。故创建策略降低门限值。
link-hold-rssi 5
wlan rrm
dot11a mandatory-rate 6 12 24
dot11a supported-rate 9 18 36 48 54
dot11b mandatory-rate 1 2
dot11b supported-rate 5.5 11
dot11g mandatory-rate 1 2 5.5 11
dot11g supported-rate 6 9 12 18 24 36 48 54
wlan service-template 1 clear
ssid mesh1
service-template enable
interface NULL0
interface Vlan-interface1
interface Vlan-interface3
ip address 192.168.3.254 255.255.255.0
interface Ethernet1/0/1
port link-type trunk
port trunk permit vlan all
interface WLAN-MESH1
port-security port-mode psk
port-security tx-key-type 11key
port-security preshared-key pass-phrase cipher wrWR2LZofLzlEY9ZdYsidw==
interface WLAN-BSS32
port link-type hybrid
port hybrid vlan 1 untagged
interface WLAN-BSS33
interface WLAN-Radio1/0/1
channel 153
mp-policy 1
mesh-profile 1
mesh peer-mac-address 000f-e27d-8e00
interface WLAN-Radio1/0/2
service-template 1 interface wlan-bss 33
load xml-configuration
user-interface con 0
user-interface vty 0 4
authentication-mode scheme
Return
<WA2220X-AG>
<WA2220X-AG>dis cu
sysname WA2220X-AG
vlan 1
domain system
state active
idle-cut disable
user-group system
local-user admin
service-type telnet
wlan mesh-profile 1
mesh-id outdoor
bind WLAN-MESH 1
mesh-profile enable
wlan rrm
ssid mesh2
interface NULL0
ip address 192.168.1.2 255.255.255.0
interface Ethernet1/0/2
channel 153
mesh-profile 1
mesh peer-mac-address 000f-e2f2-0340
arp-snooping enable
authentication-mode none
user privilege level 3
return
(0)
(0)
你好,请问一下可以直接在IE窗口界面调试吗?因为那些配置命令参数我是真的不会与不懂,也看不明白啊。还请指教
大神啊,非常感谢你的回复。问题是我没有console数据线。请问一下在IE管理界面怎么调试呢? 还有就是,我的电脑基础知识,装系统与配置家用路由器局域网基本的都懂,但是你的这些命令之类的,我是真的没有接触过。想请问一下用网线连接AP的那个ETHERNET接口,在IE管理界面能直接调试吗?命令参数之类真的不懂,你们是技术大拿,能看到这些参数怎么改,怎么调试。我想的就是IE窗口界面修改一下而已。还请回复一下,谢谢
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
