怎么确定交换机支持光模块类型?
2020-07-15提问
  • 1收藏,2641浏览
粉丝:0人 关注:2人
型号 H3C S5500-28C-EI      V5,  现在用了下面模块报错,怎么确定交换机支持光模块类型? H3C-S5500 OPTMOD/4/MODULE_IN: GigabitEthernet1/0/27: The transceiver is 1000_BASE_LX_SFP. %Apr 26 12:16:32:596 2000 H3C-S5500 OPTMOD/4/MODULE_IN: GigabitEthernet1/0/25: The transceiver is UNKNOWN_SFP_PLUS. %Apr 26 12:16:32:597 2000 H3C-S5500 OPTMOD/5/CHKSUM_ERR: GigabitEthernet1/0/25: The checksum of transceiver information is bad! %Apr 26 12:16:32:623 2000 H3C-S5500 OPTMOD/3/CFG_ERR: GigabitEthernet1/0/25: The transceiver type does not match port configuration! %Apr 26 12:16:33:250 2000 H3C-S5500 OPTMOD/4/MODULE_IN: GigabitEthernet1/0/28: The transceiver is UNKNOWN_SFP_PLUS. %Apr 26 12:16:33:251 2000 H3C-S5500 OPTMOD/5/CHKSUM_ERR: GigabitEthernet1/0/28: The checksum of transceiver information is bad! %Apr 26 12:16:33:277 2000 H3C-S5500 OPTMOD/3/CFG_ERR: GigabitEthernet1/0/28: The transceiver type does not match port configuration! %Apr 26 12:16:33:822 2000 H3C-S5500 OPTMOD/4/MODULE_IN: GigabitEthernet1/0/26: The transceiver is UNKNOWN_SFP_PLUS. %Apr 26 12:16:33:823 2000 H3C-S5500 OPTMOD/5/CHKSUM_ERR: GigabitEthernet1/0/26: The checksum of transceiver information is bad! %Apr 26 12:16:33:850 2000 H3C-S5500 OPTMOD/3/CFG_ERR: GigabitEthernet1/0/26: The transceiver type does not match port configuration!
欣欣 九段
粉丝:18人 关注:7人
如果确定交换机支持的光模块,可以在官网对应安装手册中查找,比如,S6800支持的光模块在如下手册中查询。
http://h3c.com/cn/d_201912/1250748_30005_0.htm
附录中有支持的模块列表,其他交换机查找方法类似
粉丝:124人 关注:6人
1、可以取出光模块查看。
2、也可以使用如下命令查看,但是不一定能查出来:
dis transceiver interface gi 1/0/26
3、根据如图所示,为10公里传输距离单模光模块,波长1310
4、关于如何辨别光模块的真伪,可使用dis transceiver interface gi 1/0/26查看。需注意正常的光模块的vendor显示的是H3C。vendor显示为OEM可以判断为假冒模块。
你这是在千兆口插了万兆模块吧。
sfp plus = sfp +
这个是万兆模块的规格
