S5110不能正常启动。
2020-07-20提问
  • 1收藏,917浏览
粉丝: 关注:
如题。S5110启动后会提示如下
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Backup Extend BootWare The Extend BootWare is self-decompressing........................Done!
*                      H3C S5110-28P-PWR BootWare, Version 1.08                  *
Copyright (c) 2004-2014 Hangzhou H3C Technologies Co., Ltd.
Compiled Date : Jan 26 2014 17:37:16
CPU Type : MIPS4kec
CPU L1 Cache : 16KB
CPU Clock Speed : 500MHz
Memory Type : DDR3 SDRAM
Memory Size : 128MB
Memory Speed : 300MHz
BootWare Size : 3MB
Flash Size : 32MB
Check net params crc error, use the default value
BootWare Validating...
Backup Basic BootWare not exist
Begin to Update the Backup Basic BootWare............Done!
Application program does not exist.
BootWare password: Not required. Please press Enter to continue.
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
=========<EXTEND-BOOTWARE MENU>==========
|<1> Boot System        |
|<2> Enter Serial SubMenu                                                     |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control        |
|<5> Restore to Factory Default Configuration                      |
|<6> Skip Current System Configuration                               |
|<7> BootWare Operation Menu                                           |
|<8> Clear Super Password                                                    |
|<9> Storage Device Operation                                             |
|<0> Reboot        |
Ctrl+Z: Access EXTEND-ASSISTANT MENU
Ctrl+F: Format File
System Enter your choice(0-9):
粉丝:11人 关注:1人
更新过程中,提示flash空间不够用
The space is not enough
Failed!
可以尝试把版本传进SDRAM里面试试,传进去后看是否可以进入系统,如果能进入系统,可在系统界面再把版本传进flash里,如果传进flash后系统重启系统文件再次丢失,或者无法传进flash,那说明flash可能已经损坏,可联系4008100504故障报修
|<1> Download Application Program To SDRAM And Run |
传到SDRAM是可以启动的,但启动后使用dir 命令查看不了内容。提示未知的文件格式。已确认是flash坏了。
发表时间:2020-07-21
5 个回答
感谢,使用此方法,救活了一台超保机。[坏笑]
粉丝:5人 关注:0人
应该是版本丢失了,重新加载一下,应该就可以了。
知了小白
粉丝: 关注:
我重新上传了版本固件也不能启动。提示如下
=========<Enter Ethernet SubMenu>===========
|Note:the operating device is flash |
|<2> Update Main Application File |
|<3> Update Backup Application File |
|<4> Update Secure Application File |
|<5> Modify Ethernet Parameter |
|<0> Exit To Main Menu |
|<Ensure The Parameter Be Modified Before Downloading!> |
Enter your choice(0-5): 2
Loading.....................................................................
..............................Done!
12725248 bytes downloaded!
Updating File flash:/S5110_10P.bin
Failed!
就算我ctrl + f 格式化也是这个提示
在主菜单选择第4项查看过设备上的文件,提示没有任何文件。
粉丝:124人 关注:6人
The space is not enough   //空间不足。
可选择 <4> File Control 看下有哪些文件,可将不用的日志文件、诊断信息文件删除看下。如果还不行,删除旧的软件版本后再试试。
第4项进去,看不到任何文件。已经确定是flash坏了。
发表时间:2020-07-21
zhiliao_W5uNNx 知了小白
s5110变砖,求一个s5110-28P-D 能用的.btm文件,
