MSR3640
2020-07-22提问
  • 1收藏,1362浏览
MSR3640路由器的3G信号是如何配置(SIM卡是联通3G),用的4G-LTE模块,有配置说明手册吗查看了MSR3640的系统是V7版本的
粉丝:6人 关注:3人
H3C>system-view
[H3C]dialer-group 1 rule ip permit
[H3C]controller Cellular 0/0
[H3C-Cellular0/0]serial-set 0
[H3C-Cellular0/0]quit
[H3C]interface Serial 0/0:0
[H3C-Serial0/0:0]ip address ppp-negotiate
[H3C-Serial0/0:0]ppp pap local-user card password simple card
[H3C-Serial0/0:0]ppp chap user card
[H3C-Serial0/0:0]ppp  chap password  simple card     //这三条配置联通和电信使用,移动不用配置
[H3C-Serial0/0:0]ppp ipcp dns request
[H3C-Serial0/0:0]ppp ipcp dns admit-any
[H3C-Serial0/0:0]dialer circular enable
[H3C-Serial0/0:0]dialer-group 1
[H3C-Serial0/0:0]dialer timer autodial 5
[H3C-Serial0/0:0]dialer number *99# autodial  //联通为*99#,电信为#777,移动无需配置拨号串
[H3C-Serial0/0:0]nat outbound
[H3C-Serial0/0:0]quit
## 查看Cellular0/0对应的TTY接口,通过命令display user-interface可以看到Cellular0/0对应的TTY接口。
[H3C]display user-interface
  Idx  Type     Tx/Rx      Modem Auth  Int          Location
+ 0    CON 0    9600       -     N     -            0/0
  1    TTY 1    9600       -     N     Ser0/0:0     0/0
  81   VTY 0               -     A     -            0/0
[H3C]line tty 1
H[3C-line-tty1]modem enable both
[H3C-line-tty1]quit
[H3C]ip route-static 0.0.0.0 0 Serial 0/0:0  //配置指向外网的默认路由
zhiliao_pSTYi 发表时间:2020-07-22
回复zhiliao_pSTYi:
什么意思
非同小可 发表时间:2020-07-22
我使用display user-interface 查询不到TTy,是要配置完Cellular 4/0,才能查询到吗
回复zhiliao_pSTYi:
按照4G的配置: <H3C>system-view [H3C]controller Cellular 1/0 //进入Cellular接口视图 [H3C-Cellular1/0]eth-channel 0 //将Cellular接口通道化出以太网通道接口 [H3C-Cellular1/0]quit [H3C] dialer-group 1 rule ip permit [H3C]interface eth-channel 1/0:0 [H3C-Eth-channel1/0:0] dialer circular enable [H3C-Eth-channel1/0:0]dialer-group 1 [H3C-Eth-channel1/0:0]dialer timer idle 0 [H3C-Eth-channel1/0:0]dialer timer autodial 60 [H3C-Eth-channel1/0:0]dialer number *99# autodial //联通移动,拨号串采用*99#,电信的拨号串为#777 [H3C-Eth-channel1/0:0]ip address cellular-alloc //配置接口通过Modem私有协议获取IP地址 [H3C-Eth-channel1/0:0]nat outbound [H3C-Eth-channel1/0:0]quit [H3C]ip route-static 0.0.0.0 0 Eth-channel1/0:0 //配置默认路由,指向4G出接口 <H3C>system-view [H3C]controller Cellular 1/0 //进入Cellular接口视图 [H3C-Cellular1/0]eth-channel 0 //将Cellular接口通道化出以太网通道接口 [H3C-Cellular1/0]quit [H3C] dialer-group 1 rule ip permit [H3C]interface eth-channel 1/0:0 [H3C-Eth-channel1/0:0] dialer circular enable [H3C-Eth-channel1/0:0]dialer-group 1 [H3C-Eth-channel1/0:0]dialer timer idle 0 [H3C-Eth-channel1/0:0]dialer timer autodial 60 [H3C-Eth-channel1/0:0]dialer number *99# autodial //联通移动,拨号串采用*99#,电信的拨号串为#777 [H3C-Eth-channel1/0:0]ip address cellular-alloc //配置接口通过Modem私有协议获取IP地址 [H3C-Eth-channel1/0:0]nat outbound [H3C-Eth-channel1/0:0]quit [H3C]ip route-static 0.0.0.0 0 Eth-channel1/0:0 //配置默认路由,指向4G出接口
我使用display user-interface 查询不到TTy接口,是要配置完 controller Cellular 4/0,才能查询到吗
回复zhiliao_pSTYi:
你可以试试
4G模块,能兼容联通 3G卡,对吗
应该可以向下兼容
回复非同小可:
好的,谢谢
回复zhiliao_pSTYi:
不客气,望采纳
粉丝:125人 关注:6人
以下是MSR3600的用户手册链接,请参考3G 4G modem部分:
https://www.h3c.com/cn/Service/Document_Software/Document_Center/Routers/Catalog/MSR/MSR_5600/Configure/Operation_Manual/H3C_MSR_CG(V7)-E0302-6W104/05/
