s7003的console口密码忘记了,如何恢复?还有web页面管理的默认密码是什么?
2020-07-25提问
  • 1收藏,801浏览
对齐方式 靠左 居中 靠右 我的BOOT MENU菜单如下:1. Download application file to device2. Select application file to boot3. Display all files in device4. Delete file from device5. Restore to factory default configuration0. RebootCtrl+F: Format File SystemCtrl+P: Skip Super PasswordCtrl+J: Download application to SDRAM and RunCtrl+U: Access BootRom update menuCtrl+Z: Access EXTEND-ASSISTANT MENU选择Ctrl+P,无法跳过console密码,请问如何处置
粉丝:4人 关注:0人
解决方法:
如果用户设置的console登录口令丢失,又不能通过telnet方式修改口令,可以使用以下解决方法:删除启动文件。具体操作步骤如下:
1.   进入BOOTROM菜单
Press Ctrl+B to enter Boot Menu...4
Please input BootRom password:
   BOOT MENU
5. Modify BootRom password
0. Reboot
Enter your choice(0-5):
键入Ctrl+B组合键进入BOOTROM菜单。
2、导出设备配置文件到外部TFTP/FTP服务器
BOOT MENU
0. Reboot
Enter your choice(0-5):                   //此处输入CTRL+Y键后敲击ENTER
Please select application file upload choices:
1. Upload file from Flash via TFTP protocol
2. Upload file from CF card via TFTP protocol
0. Return to boot menu
Enter your choice(0-2): 1           //选择1,使用TFTPF方式导出配置文件
Load File name           :sda startup.cfg
Switch IP address        :192.168.0.36 172.16.0.1
Server IP address        :192.168.0.30 172.16.0.2
 //根据实际情况输入配置文件名称,设备地址、TFTP服务器地址
Are you sure to upload file to server? Yes or No (Y/N):Y
//选择Y
Load file from flash to sdram...done!
Uploading...done!
BOOTROM菜单下,按CTRL+Y键后敲击ENTER,按照提示设置TFTP服务器,导出用户配置。
3、删除当前启动配置文件
Enter your choice(0-2): 0                             //回到Bootrom菜单
   BOOT MENU
0. Reboot
Enter your choice(0-5): 4                       //删除当前启动配置文件
Flash:/
Number.    Size(B)   Time                 Name
1          4588      Nov/05/2014 08:08:27 private-data.txt
2          864024    Jul/19/2012 09:23:35 io_mon.txt
3          12610     Aug/13/2012 13:46:44 patch_mpu.bin
4          970       Aug/09/2013 09:07:44 patchstate
5          62930     Nov/05/2014 08:08:51 config.cwmp
6          4         Oct/12/2014 11:47:27 snmpboots
7          33367493  Oct/15/2014 10:06:24 s7500e-cmw520-r6708p09.app
8          21413     Nov/05/2014 08:09:19 startup.cfg
9          735       Aug/07/2012 10:17:45 hostkey
10         4843      Dec/06/2010 17:15:40 config.cfg
11         591       Aug/07/2012 10:17:53 serverkey
12         2954      Sep/11/2012 07:03:21 irf.cfg
13         7918      Jun/20/2000 04:37:39 triple.cfg
14         3807      Nov/05/2014 08:09:09 system.xml
15         1411      Feb/24/2010 15:07:49 startupwangchen.cfg
16         16413     Nov/05/2014 08:08:37 qosindex
17         429436    Sep/22/2014 13:30:03 lsqsrp2xb05301.btw
18         6524      Nov/01/2012 15:58:55 mplstest.cfg
19         7345      May/15/2012 12:21:26 iccrunning.cfg
Free space: 29672448 bytes
The current application file is:cfa0:/s7500e-cmw520-r6708p08.app
The backup application file is:cfa0:/s7500e-cmw520-r6105.app
Please input the file number to delete :8       //启动配置文件对应序号8
The file you selected is flash:/startup.cfg, delete it? Yes or No(Y/N)Y
Deleting.....done!                                            //选择Y
在导出用户配置之后,此步骤用以删除启动文件,让设备重新以空配置启动(如果设备配置无需保存,可以直接删除设备启动文件,无需进行第二步的配置备份)。
   4、重启设备
           BOOT MENU
0. Reboot
Enter your choice(0-5): 0                             //选择0,重启设备
Starting......
RAMLine.....OK
System is booting...............
      设备将以空配置重启,使用console口成功登陆设备后可以设置新的的console密码,如需要刷回原来的配置,切记先删除console口登陆的相关设置。
