有没有大神帮我看看这台华三路由器有没有对我无线做什么影响?
2020-07-27提问
  • 1收藏,936浏览
H3C>dis cu
 version 5.20, Release 2105P12
 sysname H3C
 domain default enable system
 bridge enable
 telnet server enable
 dar p2p signature-file flash:/p2p_default.mtd
acl number 2000
 rule 0 permit source 192.168.1.0 0.0.0.255
 rule 1 permit source 192.168.2.0 0.0.0.255
 rule 2 permit source 192.168.3.0 0.0.0.255
 rule 4 permit source 192.168.102.0 0.0.0.255
acl number 3969
 rule 0 permit ip source 192.168.1.22 0
acl number 3970
 rule 0 permit ip destination 192.168.1.22 0
acl number 4000
vlan 1
radius scheme system
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
traffic classifier AdvWeb3970 operator and
 if-match acl 3970
traffic classifier AdvWeb3969 operator and
 if-match acl 3969
traffic classifier macdeny operator and
 if-match acl 4000
traffic behavior AdvWeb3970
 car cir 3000 cbs 187500 ebs 0 green pass red discard
traffic behavior AdvWeb3969
 car cir 2000 cbs 125000 ebs 0 green pass red discard
traffic behavior macdeny
 filter deny
qos policy PolicyLimitInput-1048579
 classifier AdvWeb3970 behavior AdvWeb3970
qos policy PolicyLimit-1048579
 classifier AdvWeb3969 behavior AdvWeb3969
qos policy pmacdeny
 classifier macdeny behavior macdeny
dhcp server ip-pool vlan1 extended
 network ip range 192.168.1.2 192.168.1.250
 network mask 255.255.255.0
 gateway-list 192.168.1.1
 dns-list 218.2.135.1 114.114.114.114
dhcp server ip-pool vlan2
 network 192.168.2.0 mask 255.255.255.0
 gateway-list 192.168.2.1
dhcp server ip-pool vlan3
 network 192.168.3.0 mask 255.255.255.0
 gateway-list 192.168.3.1
user-group system
local-user admin
 password cipher HM/\H!X@D]J'4QR4*WP[M1!!
 authorization-attribute level 3
 service-type telnet
cwmp
 undo cwmp enable
interface Aux0
 async mode flow
 link-protocol ppp
interface Dialer10
 nat outbound 2000
 link-protocol ppp
 ppp chap user 02510533603
 ppp chap password cipher ]0BaQWZ#:aSQ=^Q`MAF4<1!!
 ppp pap local-user 02510533603 password cipher ]0BaQWZ#:aSQ=^Q`MAF4<1!!
 ppp ipcp dns admit-any
 ppp ipcp dns request
 mtu 1492
 ip address ppp-negotiate
 tcp mss 1024
 dialer user username
 dialer-group 10
 dialer bundle 10
interface NULL0
interface Vlan-interface1
 dhcp server apply ip-pool vlan1
 qos apply policy PolicyLimitInput-1048579 inbound
 qos apply policy PolicyLimit-1048579 outbound
 ip flow-ordering internal
interface GigabitEthernet0/1
 port link-mode route
 nat outbound 2000
 pppoe-client dial-bundle-number 10
interface GigabitEthernet0/2
 ip address 192.168.102.2 255.255.255.0
interface GigabitEthernet0/3
 ip address 192.168.3.1 255.255.255.0
interface GigabitEthernet0/0
 port link-mode bridge
 ip route-static 0.0.0.0 0.0.0.0 Dialer10
 dhcp enable
 arp static 192.168.1.22 001f-d04e-2f2e
 dialer-rule 10 ip permit
 ip flow-ordering stat-interval 10
 load xml-configuration
 load tr069-configuration
user-interface con 0
user-interface aux 0
user-interface vty 0 4
 authentication-mode scheme
return
无线终端显示有时候连不上网!
粉丝:124人 关注:6人
配置上没有什么问题。
如果无线网络确实慢的话,可以先把QOS限速去掉看下。
同时建议无线网络和有线网络使用不同的VLAN或不同的IP地址段进行分开看下。
另外可以通过修改无线设备的信道、功率来进行优化。
你好工程师,qos运用到我的无线接口上了吗,g0/2口
知了猴 发表时间:2020-07-27
您好,在G0/2口没有看到QOS的应用。
得闲饮茶013 发表时间:2020-07-27
对的,那qis的话,应该没有影响到我的无线吧。
知了猴 发表时间:2020-07-27
您好,看了下没有使用全局应用的QOS,仅应用到了端口,理论上不影响的。
好的工程师
知了猴 发表时间:2020-07-27
粉丝:111人 关注:1人
没有特殊的配置,只是做了个限速,其余都是正常的路由转发
限速吗,我那边无线确实有点慢
知了猴 发表时间:2020-07-27
这个限速还好的,不至于导致无线慢,可以对无线进行优化!
漓离原上谱 发表时间:2020-07-27
好的
知了猴 发表时间:2020-07-27
