AC+ap,瘦ap的无线服务连不上
2020-08-01提问
  • 1收藏,2634浏览
adong 零段
icg3000f当ac和wa5530同时挂在路由的lan口,路由开启了dhcp,路由lan口都划为vlan1,ac和ap都能获得正确的ip地址,但是ap发射的无线信号无线客户端连接不上,一直显示正在连接, 无线不加密也是一样。ac的console口在手机连接无线时候显示如下信息:请帮忙分析一下原因,谢谢!%Aug 1 08:05:50:614 2020 H3C STAMGR/6/STAMGR_CLIENT_ONLINE: Client a20d-18f5-4a29 went online from BSS 703d-158b-4380 with SSID 测试H3C on AP 5530-2 Radio ID 1. State changed to Run. %Aug 1 08:05:50:616 2020 H3C STAMGR/6/STAMGR_ROAM_SUCCESS: Client a20d-18f5-4a29 roamed from BSSID 703d-158b-4390 on AP 5530-2 Radio ID 2 of AC IP 127.0.0.1 to BSSID 703d-158b-4380 on AP 5530-2 Radio ID 1 of AC IP 127.0.0.1 successfully. %Aug 1 08:06:26:686 2020 H3C STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a20d-18f5-4a29 went offline from BSS 703d-158b-4380 with SSID 测试H3C on AP 5530-2 Radio ID 1. State changed to Unauth. Reason:Received disassociation frame in Run state: reason code=3 %Aug 1 08:06:27:702 2020 H3C STAMGR/6/STAMGR_CLIENT_ONLINE: Client a20d-18f5-4a29 went online from BSS 703d-158b-4390 with SSID 测试H3C on AP 5530-2 Radio ID 2. State changed to Run. %Aug 1 08:06:27:705 2020 H3C STAMGR/6/STAMGR_ROAM_SUCCESS: Client a20d-18f5-4a29 roamed from BSSID 703d-158b-4380 on AP 5530-2 Radio ID 1 of AC IP 127.0.0.1 to BSSID 703d-158b-4390 on AP 5530-2 Radio ID 2 of AC IP 127.0.0.1 successfully. %Aug 1 08:07:03:780 2020 H3C STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a20d-18f5-4a29 went offline from BSS 703d-158b-4390 with SSID 测试H3C on AP 5530-2 Radio ID 2. State changed to Unauth. Reason:Received disassociation frame in Run state: reason code=3
粉丝:124人 关注:6人
需检查下有线网络是否可用,如果有线网络可用,说明是无线的配置问题了。
如果AC和AP都能拿到IP地址了,说明基础网络已经完成。
关于WIFI无法连接上,主要是检查以下几点:
1、服务模板的配置。
2、射频的配置。
3、无线的接入配置。
以下是ICG3000的用户手册链接,请参考:
https://www.h3c.com/cn/Service/Document_Software/Document_Center/ICG/Catalog/ICG_3000/ICG_3000/
以下是WA5500的用户手册链接,请参考:
https://www.h3c.com/cn/Service/Document_Software/Document_Center/Wlan/WA/H3C_WA5500/
粉丝:3人 关注:2人
icg3000f当ac和wa5530同时挂在路由的lan口//没有icg3000 就正常?
你好,现在存在icg3000情况下,有线网络是正常的,现在就是无线网不正常!
adong 发表时间:2020-08-01
adong 知了小白
主要是这句不知道什么情况造成的:State changed to Unauth. Reason:Received disassociation frame in Run state: reason code=3
zhiliao_qkcLg 知了小白
那个本地 或者集中转发哪里搞下
谢谢,昨天搞过了,确实是集中转发改为本地转发就可以了!
adong 发表时间:2020-08-03
这个原因是啥啊?能不能解释一下?
zhiliao_ElQio2 发表时间:2022-03-14
