wa2612开机调试口进去无法配置
2020-08-01提问
  • 1收藏,831浏览
saney 零段
粉丝:0人 关注:2人
目前设备开机从调试口进去显示情况如下:Copyright (c) 2004-2010 Hangzhou H3C Technologies Co., Ltd. Compiled Date : Dec 6 2010 CPU Type : AR9132 CPU L1 Cache : 32KB CPU Clock Speed : 400MHz Memory Type : DDR SDRAM Memory Size : 128MB Memory Speed : 400MHz BootWare Size : 511KB Flash Size : 16MB PCB Version : Ver.D BootWare Validating... Press Ctrl B to enter extended boot menu... Starting to get the main application file--flash:/wa2600a_fit.bin! The main application file does not exist--flash:/wa2600a_fit.bin! Starting to get the backup application file--flash:/backup.app! The backup application file does not exist--flash:/backup.app! Starting to get the secure application file--flash:/secure.app! The secure application file does not exist--flash:/secure.app! Booting App fails! Trying to get the IP address from the DHCP server......
然后我敲什么都没反应!无法配置设备!
粉丝:12人 关注:1人
如果没有办法输入命令,尝试关闭一下CRT的流控
看设备报出的信息,设备是瘦ap无法单独使用的需要结合ac才可以
