ping命令
2020-08-02提问
  • 1收藏,1506浏览
在交换机上ping2个地址是否通讯,所命令是什么呢?谢谢?比如用190.168.1.1与192.168.231.1
<H3C>ping 190.168.1.1   测试到190.168.1.1的连通性
<H3C>ping -a 190.168.1.1 192.168.231.1  用交换机上的地址190.168.1.1作为源地址 来测试到  192.169.231.1的连通性
你还弄懂状况
懵懂小白 发表时间:2020-08-02
粉丝:124人 关注:6人
直接使用PING命令即可。
如果是直接PING 190.168.1.1。参考命令如下:
ping 190.168.1.1
如果是将190.168.1.1作为源 来ping 192.168.231.1,参考命令如下:
更多的PING参数如下,请参考:
<H3C>ping ?
-a Specify the source IP address
-c Specify the number of echo requests
-f Specify packets not to be fragmented
-h Specify the TTL value
-i Specify an outgoing interface
-m Specify the interval for sending echo requests
-n Numeric output only. No attempt will be made to lookup host
addresses for symbolic names
-p No more than 8 "pad" hexadecimal characters to fill out the
sent packet. For example, -p f2 will fill the sent packet with
000000f2 repeatedly
-q Display only summary
-r Record route. Include the RECORD_ROUTE option in the
ECHO_REQUEST packets and display the route
-s Specify the payload length
-t Specify the wait time for each reply
-tos Specify the TOS value
-v Display the received ICMP packets other than ECHO-RESPONSE
packets
-vpn-instance Specify a VPN instance
STRING<1-253> IP address or hostname of remote system
ip IP information
ipv6 IPv6 information
mpls MPLS ping
trill TRansparent Interconnection of Lots of Links (TRILL) module
