H3C WA4320H-ACN BootWare, Version 7.09
Compiled Date : Mar 21 2017
CPU Type : ATHEROS AR9557
CPU L1 Cache : 32KB
CPU Clock Speed : 720MHz
Memory Type : DDR2 SDRAM
Memory Size : 256MB
Memory Speed : 560MHz
BootWare Size : 512KB
Flash Size : 128MB
PCB Version : Ver.B
**************************************************************************** * * * H3C WA4320H-ACN BootWare, Version 7.09 * * * **************************************************************************** Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. Compiled Date : Mar 21 2017 CPU Type : ATHEROS AR9557 CPU L1 Cache : 32KB CPU Clock Speed : 720MHz Memory Type : DDR2 SDRAM Memory Size : 256MB Memory Speed : 560MHz BootWare Size : 512KB Flash Size : 128MB PCB Version : Ver.B BootWare Validating... Press Ctrl+B to access EXTENDED-BOOTWARE MENU... Password recovery capability is enabled. Note: The current operating device is flash Enter < Storage Device Operation > to select device. ==========================<EXTENDED-BOOTWARE MENU>========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Skip Authentication for Console Login | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+Z: Access EXTENDED ASSISTANT MENU Ctrl+F: Format File System Ctrl+C: Display Copyright Enter your choice(0-9): 4 ===============================<File CONTROL>=============================== |Note:the operating device is flash | |<1> Display All File(s) | |<2> Set Image File type | |<3> Set Bin File type | |<4> Set Configuration File type | |<5> Delete File | |<0> Exit To Main Menu | ============================================================================ Enter your choice(0-5): 1 Display all file(s) in flash: "M" = MAIN "B" = BACKUP "N/A" = NOT ASSIGNED ============================================================================ |NO. Size(B) Time Type Name | |1 11062272 Aug/08/2008 20:00:00 N/A flash:/wa4300_fat.bin | |2 11078656 Aug/08/2008 20:00:00 N/A flash:/wa4300a_fat.bin | ============================================================================ ===============================<File CONTROL>=============================== |Note:the operating device is flash | |<1> Display All File(s) | |<2> Set Image File type | |<3> Set Bin File type | |<4> Set Configuration File type | |<5> Delete File | |<0> Exit To Main Menu | ============================================================================ Enter your choice(0-5): 0 ==========================<EXTENDED-BOOTWARE MENU>========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Skip Authentication for Console Login | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+Z: Access EXTENDED ASSISTANT MENU Ctrl+F: Format File System Ctrl+C: Display Copyright Enter your choice(0-9): 1 Loading the main boot and system image files... The system image does not exist! Loading the backup boot and system image files... The image does not exist! Booting image fails! Trying to get the IP address from the DHCP server......========= |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Skip Authentication for Console Login | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+Z: Access EXTENDED ASSISTANT MENU Ctrl+F: Format File System Ctrl+C: Display Copyright Enter your choice(0-9): 1 Loading the main boot and system image files... The system image does not exist! Loading the backup boot and system image files... The image does not exist! Booting image fails! Trying to get the IP address from the DHCP server......
(0)
你这个是V7 的AP 不能直接升级到V5 FAT 需要先降级bootware。进入ctrl+D传入btw文件把 文件不需要改名字
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
要像说的这样,就好了。不行;现在问题出在版本问题和启动问题上,我现在不能确定,这个版本是不是好的,我的版本是:WA4300-CMW520-R1509P03-FAT
能进CTRL+B 吗 进CTRL+B 之后你应该就会操作了 如果进不了CTRL+B 那只能进入CTRL+D 然后把FAT 版本中的btw文件传进去更新bootrom版本 再看看ctrl+B是否ok
两个都能进
传apwa4300_v1.15.btw,要更名不?
