无线AP的Tunnel down reason都代表什么含义
2020-08-07提问
  • 5收藏,2372浏览
无线AP无线AP的Tunnel down reason都代表什么含义
粉丝:6人 关注:1人
您好:
关于Tunnel down reason参数含义如下:
CAPWAP隧道关闭的原因:
·          N/A:无
·          Failed to create timer:创建定时器失败
·          Neighbor dead timer expired:邻居报告定时器超时
·          Request wait timer expired:等待请求消息定时器超时
·          Data check timer expired:数据检测定时器超时
·          Failed to process data channel keep-alive message:处理数据隧道保活报文失败
·          Failed to process request:请求报文处理失败
·          AP was resetAP重启
·          AP was deletedAP被删除
·          Failed to come onlineAP上线失败
·          Serial number changedAPSerial ID改变
·          MAC address changedAPMAC地址改变
·          Number of APs exceeded the limitAP数量超出AC能力集
·          Processed join request in Run state:在Run状态处理join request
·          Failed to create AP context:创建AP上下文信息失败
·          Received failure result codeCAPWAP状态机状态变迁时收到错误结果码
·          Failed to retransmit message:报文重传失败
·          Failed to download image file:下载AP镜像失败
·          Image file downloaded successfullyAP下载镜像成功重启系统
·          File operation timer expired:文件操作定时器超时
·          Failed to add tunnel:添加隧道失败
·          Received WTP tunnel down event from APAC收到AP的隧道down事件
·          Backup AC closed the backup tunnel:备份AC关闭备份隧道
·          Master and backup tunnel switchover:主备隧道切换
·          Failed to inherit configuration:继承配置失败
·          AP authentication failedAP认证失败
·          Encryption status mismatch :加密运行状态和配置状态不一致
·          AP was reset due to inconsistent local and reported radio statistics Radio数据统计信息上报数据不一致
·          AP was reset due to inconsistent AP state on APMGR and libAPMGRlibAP状态不一致
·          AP was reset due to inconsistent BSS state on AC and APACAP上的BSS状态不一致
请问下这些一般都是什么原因导致的呢?有些比较明确,有些可能不是很明确
Rps_Cheers 发表时间:2022-08-26
