H3C S2126交换机如何恢复出厂设置?
  • 1收藏,2354浏览
忘记了console口的管理密码,现在还有什么办法恢复到出厂设置?CTRL+B选项无清楚的项?试过升级版本无效。。。
H3C>sys
Password:
% Wrong passwords!
<H3C>
*    H3C S2126 BOOTROM, Version 100                  *
Copyright(c) 2006 Hangzhou Huawei-3Com Technology Co., Ltd
All rights Reserved.
Creation Date : Dec 29 2006
CPU Type : Taifa331
CPU Clock Speed : 50MHz
Memory Size : 128KB
nitialize CPU ...........................OK!
Check flash checksum......................OK!
SRAM selftest ............................OK!
Switch chip selftest .....................OK!
Please check port leds..............finished!
The switch Mac is: 000f-e251-1144
Starting......
Press Ctrl-B to enter Boot Menu....... 2
Password :
                   BOOT MENU
1. Download application file with Xmodem
2. Modify bootrom password
3. Modify IP/Submask/Gateway address
4. Download application file with http
0. Reboot
Enter your choice(0-4):
H3C>sys
Password:
% Wrong passwords!
<H3C>
CPU Type : Taifa331
Memory Size : 128KB
Starting......
Password :
                   BOOT MENU
0. Reboot
粉丝:8人 关注:1人
选2进去试一下能不能改。
或者在web界面选择恢复出厂设置
能进WEB我就不用来这提问了。。2选项是设置bootromm密码,不是conslole的sys-view密码好吗。。。
zhiliao_3eO1A 发表时间:2018-04-14
打他们售后400问问吧
请叫我网络小雷锋....... 发表时间:2018-04-17
