S7506 S5500 VLAN间路由
2020-08-09提问
  • 1收藏,754浏览
display current-configuration
version 5.20, Release 2202
 sysname SPS-DIS-5500-MZL
undo info-center enable
irf mac-address persistent timer
 irf auto-update enable undo
irf link-delay
 domain default enable system #  telnet server enable # undo ip ttl-expires # vlan 1 # vlan 106 # vlan 108 to 109 # vlan 900  # radius scheme system  server-type extended  primary authentication 127.0.0.1 1645 primary accounting 127.0.0.1 1646  user-name-format without-domain # domain system  access-limit disable  state active  idle-cut disable  self-service-url disable # user-group system # local-user h3c  password cipher G`M^Bdisplay current-configuration  %Apr 6 05:30:00:596 2000 SPS-DIS-5120-JGST SHELL/5/LOGOUT:- 1 - Console(aux0) in unit1 logout  #  sysname SPS-DIS-5120-JGST # radius scheme system # domain system # local-user h3c password cipher @0:TT&Q_LLKQ=^Q`MAF4<1!!  service-type telnet # vlan 1 # vlan 108 to 109 # interface Vlan-interface108  ip address 10.110.108.4 255.255.255.0 # interface Vlan-interface109  description "port link to 8#"  ip address 10.110.109.2 255.255.255.0 # interface Aux1/0/0 # interface Ethernet1/0/1  port access vlan 109 # interface Ethernet1/0/2  port access vlan 109 # interface Ethernet1/0/3  port access vlan 109 #interface Ethernet1/0/4  port access vlan 109 # interface Ethernet1/0/5  port access vlan 109 # interface Ethernet1/0/6  port link-type trunk  port trunk permit vlan all#interface Ethernet1/0/7  port access vlan 109 # interface Ethernet1/0/8  port access vlan 109 #  interface Ethernet1/0/9  port access vlan 109 # interface Ethernet1/0/10  port access vlan 109 # interface Ethernet1/0/11 # interface Ethernet1/0/12  port link-type trunk  port trunk permit vlan all# interface Ethernet1/0/13  port access vlan 109 # interface Ethernet1/0/14  port access vlan 109 # interface Ethernet1/0/15  port access vlan 109 # interface Ethernet1/0/16  port access vlan 109 #  interface Ethernet1/0/17  port access vlan 109 # interface Ethernet1/0/18  port access vlan 109 # interface Ethernet1/0/19 # interface Ethernet1/0/20 # interface Ethernet1/0/21 # interface Ethernet1/0/22  port access vlan 109 # interface Ethernet1/0/23 # interface Ethernet1/0/24 # interface GigabitEthernet1/1/1 # interface GigabitEthernet1/1/2# interface GigabitEthernet1/1/3 # interface GigabitEthernet1/1/4 # undo irf-fabric authentication-mode # interface NULL0 #  voice vlan mac-address 0001-e300-0000 mask ffff-ff00-0000 # ip route-static 0.0.0.0 0.0.0.0 10.110.108.2 preference 60 # user-interface aux 0 7 user-interface vty 0 4  user privilege level 3  set authentication password simple h3c # return
拓扑图s5500还连接vlan999 连接正常,没有画!VLAN108 S5500连接7506都正常!VLAN109 S5120 ping不通10.110.108.2S5500 ping不通10.110.108.4            ping不通10.110.109.X排除连线问题,按说上连线也没有插错接口!还可能是哪里出现问题!求大神解答!
4 个回答
粉丝:95人 关注:1人
排版太乱了,拓扑没看到
10.110.108.2 是哪台设备的地址?5500的配置中没有看到有vlan108和vlan109的地址。5500和5120是通过trunk口直连的吗?
粉丝:14人 关注:0人
你这个问题连个拓扑图也没一个, interface Ethernet1/0/6  和 interface Ethernet1/0/12口,哪个连7506,哪个连S5120都不知道,更别说那两个交换机是什么设置更不知道。这个问题没法回答啊。
粉丝:124人 关注:6人
关于VLAN间无法路由互通的问题,以下是排查要点,请参考:
1、如果网关都在同一台交换机上:
 (1)、在相关的设备上创建相关的VLAN。网关设备上配置好VLAN IP。
 (2)、做好相关设备的trunk互联,并trunk相应的VLAN通过。
 (3)、在接入交换机配置好VLAN划分到接口。
2、如果是跨设备的VLAN间路由:
 (1)、配置好设备间的三层互联。
 (2)、配置好设备间的路由发布或指向。
 (3)、配置好各自的VLAN部署。
