WA2620i-AGN
2018-04-16提问
  • 1收藏,1716浏览
Ap无法注册成功,而且反复重启,查看重启过程,一直卡在获取地址阶段;
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare....
The Extend BootWare is self-decompressing.........................Done!
*                 H3C WA2620i-AGN BootWare, Version 3.03                   *
Copyright (c) 2004-2014 Hangzhou H3C Technologies Co., Ltd.
Compiled Date       : Sep  1 2014
CPU Type            : AR9350
CPU L1 Cache        : 32KB
CPU Clock Speed     : 560MHz
Memory Type         : SDRAM
Memory Size         : 128MB
Memory Speed        : 480MHz
BootWare Size       : 512KB
Flash Size          : 32MB
CPLD Version        : 004
PCB Version         : Ver.E
BootWare Validating...
Press Ctrl+B to enter extended boot menu...
Starting to get the main application file--flash:/wa2600a_fit.bin!
The main application file does not exist--flash:/wa2600a_fit.bin!
Starting to get the backup application file--flash:/wa2600a_fat.bin!
The backup application file does not exist--flash:/wa2600a_fat.bin!
Starting to get the secure application file--flash:/wa2600a_fit.bin!
The secure application file does not exist--flash:/wa2600a_fit.bin!
Booting App fails!
Trying to get the IP address from the DHCP server......
Getting IP Address Failed, the system will reboot.
 [State : Idle] Reset request, rebooting the AP
Rebooting......
上联的路由器做DHCP server,检查了配置没有发现问题:且连接上AP的接口始终在up,down切换,换了其他接口后还是这样:
上联路由器配置(AP直连路由器):
[H3C] dis cu
version 7.1.059, Release 0304P15
sysname H3C
password-recovery enable
vlan 1
vlan 257
dhcp server ip-pool apmanage
gateway-list 10.0.35.254
network 10.0.32.0 mask 255.255.252.0
expired day 0 hour 0 minute 30
option 43 hex 8007000001b6307505
controller Cellular0/0
controller Cellular0/1
interface Aux0
interface NULL0
interface Vlan-interface257
ip address 10.0.35.254 255.255.252.0
interface GigabitEthernet0/0
port link-mode route
combo enable copper
ip address dhcp-alloc
interface GigabitEthernet0/2
interface GigabitEthernet0/1               //接AP的接口
port link-mode bridge
port access vlan 257               //网关vlan
scheduler logfile size 16
line class aux
user-role network-admin
line class tty
user-role network-operator
line class vty
line aux 0
line vty 0 63
domain system
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
return
[H3C]
debug dhcp server无输出,但是接AP的接口会频繁UP,down,换接口依旧:
启动过程没有debug信息输出
<H3C>debugging dhcp server all
<H3C>t m
<H3C>t d
The current terminal is enabled to display debugging logs.
<H3C>%Apr 16 15:25:53:148 2018 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet0/1 changed to down.
%Apr 16 15:25:53:149 2018 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet0/1 changed to down.
%Apr 16 15:25:53:151 2018 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface Vlan-interface257 changed to down.
%Apr 16 15:25:53:151 2018 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface Vlan-interface257 changed to down.
<H3C>
<H3C>%Apr 16 15:26:20:148 2018 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet0/1 changed to up.
%Apr 16 15:26:20:149 2018 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet0/1 changed to up.
%Apr 16 15:26:20:153 2018 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface Vlan-interface257 changed to up.
%Apr 16 15:26:20:153 2018 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface Vlan-interface257 changed to up.
%Apr 16 15:26:24:148 2018 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet0/1 changed to down.
%Apr 16 15:26:24:149 2018 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet0/1 changed to down.
%Apr 16 15:26:24:151 2018 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface Vlan-interface257 changed to down.
%Apr 16 15:26:24:151 2018 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface Vlan-interface257 changed to down.
%Apr 16 15:26:31:148 2018 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet0/1 changed to up.
%Apr 16 15:26:31:149 2018 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet0/1 changed to up.
%Apr 16 15:26:31:153 2018 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface Vlan-interface257 changed to up.
%Apr 16 15:26:31:153 2018 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface Vlan-interface257 changed to up.
<H3C>
ap(WA2620I-acn)----路由器(dhcp server)
粉丝:47人 关注:4人
AP如何供电?有没有电源适配器直接给AP供电,或者将AP连接到其他路由器或交换机测试一下啊。
路由器全局开启了DHCP了吗
开启了DHCP后问题依旧
请原谅一个网络小白 发表时间:2018-04-16
粉丝:2人 关注:1人
我怀疑是AP的bootware版本太老了,注册到路由器上不识别,手动把AP刷个新版本,在插到路由器上。这样也可以在AP上debug,看AP发了dhcp 的discovery了么。
