一、如何设置快照保留时间,希望快照只保留两周;二、快照计划里的保留时间和到期时间的区别,保留时间是否是快照数据的保留时间,到期时间是否指到期不再记录对原始卷的修改;三、快照到期后,是否后自动清理;四、快照使用的管理空间是否占用系统容量,是否是与系统数据共用空间,是否有容量限制谢谢
(0)
-exp <time>{d|D|h|H|m|M}
Specifies the relative time from the current time that volume will expire. <time> is a positive integer value
and in the range of 1 minute - 1825 days. Specify time using d or D for days, h or H for hours, and m or M
for minutes following the entered time value.
-retain <time>{d|D|h|H|m|M}
Specifies the amount of time, relative to the current time, that the system retains the volume. <time> is a
positive integer value in the range of 1 minute - 1825 days. Use d or D for days, h or H for hours, and m or
M for minutes following the entered time value.
If the volume is not in any domain, then its retention time cannot exceed the value of the
VVRetentionTimeMax on the system. The default value for the VVRetentionTimeMax is 14 days.
If the volume belongs to a domain, then its retention time cannot exceed the value of the
VVRetentionTimeMax of the domain, if set. ou cannot remove or reduce the retention time once it is
set. If the volume has its retention time set, you cannot remove the volume within its retention time. If you
have specified both expiration time and retention time, the retention time cannot be longer than the
expiration time.
This option requires the HPE 3PAR Virtual Lock license. Contact your local service provider for more
information.
保留时间内(retain )对VV(快照可以看作VV)不能修改
到期后(exp)系统会自动清理过期的VV
所有的空间都占系统容量
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
老师,有三个问题确认一下,一个是这个保留时间不能修改的话,可以回滚吗,还是说只是不能删除,但可以正常使用?二是SSMC里面设置保留时间是在哪个选项里面?三是快照默认是不是永久保留?
保留的是快照,所以快照不能被修改删除,回滚是修改源卷,不矛盾。ssmc最好用英文界面,中文用的术语可能与平常口头说的不一致。retain不是默认配置,需要license的。
好的,感谢
