3600交换机
2020-08-23提问
  • 1收藏,811浏览
25口作为上联口  报错信息如下  和上层网络ping不通
 %Jan 1 01:16:05:757 2010 muli-s3600-4daduan LLDP/5/LLDP_NEIGHBOR_AGE_OUT: Neighbor aged out on Port GigabitEthernet1/0/26 (IfIndex 9437209), Chassis ID is 74ea-c867-dd8c, Port ID is GigabitEthernet1/0/25.
%Jan 1 01:16:06:018 2010 muli-s3600-4daduan LLDP/5/LLDP_NEIGHBOR_AGE_OUT: Neighbor aged out on Port GigabitEthernet1/0/26 (IfIndex 9437209), Chassis ID is 74ea-c867-f574, Port ID is GigabitEthernet1/0/26.
粉丝:124人 关注:6人
%Jan 1 01:16:05:757 2010 muli-s3600-4daduan LLDP/5/LLDP_NEIGHBOR_AGE_OUT: Neighbor aged out on Port GigabitEthernet1/0/26 (IfIndex 9437209), Chassis ID is 74ea-c867-dd8c, Port ID is GigabitEthernet1/0/25.    //在本设备的26口发现了对端的25口的 4ea-c867-dd8c的邻居。
这是正常的LLDP邻居发现。
关于与上行设备不通,以下是排查要点,请参考:
1、确认物理链路没有问题。
2、确认本端和对端都已创建的VLAN。
3、确认本端和对端都已将VLAN划分到端口来进行透传。
4、以下是S3600的用户手册链接:
https://www.h3c.com/cn/Service/Document_Software/Document_Center/Switches/Catalog/S3600/S3600-SI/
物理线路 vlan都排查了 最后 把这条线 从核心交换 换到接入交换 (同样的vlan其他设备挂在这个口没问题) 故障恢复
幕至台中 发表时间:2020-08-23
多谢您写的很清楚
知了小白
粉丝: 关注:
LLDP是链路协议,超时,是不是链路有问题呀
上联设备间隔 不到3米 用的成品线 也换过
GigabitEthernet1/0/25 current state: UP IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 74ea-c867-e201 Description: GigabitEthernet1/0/25 Interface Loopback is not set Media type is twisted pair Port hardware type is 1000_BASE_T 1000Mbps-speed mode, full-duplex mode Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled The Maximum Frame Length is 10000 Broadcast MAX-ratio: 100% Unicast MAX-ratio: 100% Multicast MAX-ratio: 100% Allow jumbo frame to pass PVID: 131 Mdi type: auto Port link-type: access Tagged VLAN ID : none Untagged VLAN ID : 131 Port priority: 0 Last clearing of counters: Never Peak value of input: 532 bytes/sec, at 2010-01-01 00:25:06 Peak value of output: 67 bytes/sec, at 2010-01-01 01:19:16 Last 300 seconds input: 4 packets/sec 360 bytes/sec 0% Last 300 seconds output: 0 packets/sec 41 bytes/sec 0% Input (total): 14402 packets, 1210515 bytes 1571 unicasts, 8444 broadcasts, 4387 multicasts, 0 pauses Input (normal): 14402 packets, - bytes 1571 unicasts, 8444 broadcasts, 4387 multicasts, 0 pauses Input: 0 input errors, 0 runts, 0 giants, 0 throttles 0 CRC, 0 frame, - overruns, 0 aborts - ignored, - parity errors Output (total): 1392 packets, 144094 bytes 15 unicasts, 1120 broadcasts, 257 multicasts, 0 pauses Output (normal): 1392 packets, - bytes 15 unicasts, 1120 broadcasts, 257 multicasts, 0 pauses Output: 0 output errors, - underruns, - buffer failures 0 aborts, 0 deferred, 0 collisions, 0 late collisions 0 lost carrier, - no carrier
二层不通 要么就是链路 要么就是环路 设备正常可以启动应该没问题
发表时间:2020-08-23
