V7的AP降级为V5版本
2020-08-23提问
  • 1收藏,1873浏览
粉丝:0人 关注:2人
AP型号为W2620I-AGN,之前在V7的无线控制器上线过,现在无法在WX3024E一体机上线,版本是V5的,现在想给AP重新刷版本,请问在哪里下版本和操作,无线有线一体机 WX3024E,版本是Version 5.20, Release 3507P22,
粉丝:6人 关注:5人
需要提前准备AP V5版本的软件
第一步:进入V7boot Ctrl+F
第二步:进入V7boot 通过网卡口,传入V5 AP bin文件,提示更新boot版本的时候选择Y
第三步:再次Crtl+F格式化AP flash
第四步:导入V5 AP版本(从AC V5版本中获取,建议使用最新版本)
第五步:重启,降级完成
第一步:进入V7boot Ctrl+F
Copyright (c) 2004-2015 Hangzhou H3C Technologies Co., Ltd.
Compiled Date       : Aug 17 2015
CPU Type            : ATHEROS AR9563
CPU L1 Cache        : 32KB
CPU Clock Speed     : 775MHz
Memory Type         : SDRAM
Memory Size         : 128MB
Memory Speed        : 560MHz
BootWare Size       : 512KB
Flash Size          : 16MB
PCB Version         : Ver.A
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Skip Authentication for Console Login                                 |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Enter your choice(0-9):
第二步:
Enter your choice(0-5): 5
|Note:       '.' = Clear field.                                            |
|            '-' = Go to previous field.                                   |
|         Ctrl+D = Quit.                                                   |
Protocol (FTP or TFTP) :tftp
Load File Name         :wa4300_fit.bin
Target File Name       :wa4300_fit.bin
Server IP Address      :192.168.21.1
Local IP Address       :192.168.21.2
Subnet Mask            :255.255.255.0
Gateway IP Address     :0.0.0.0
|Note:the operating device is flash                                        |
|<1> Download Image Program To SDRAM And Run                               |
|<2> Update Main Image File                                                |
|<3> Update Backup Image File                                              |
|<4> Download Files(*.*)                                                   |
|<5> Modify Ethernet Parameter                                             |
|<0> Exit To Main Menu                                                     |
Enter your choice(0-5): 1
Loading.....................................................................
........Done.
7715840 bytes downloaded!
The image is self-decompressing.............................................
Done.
Extended BootWare Version is not equal,updating? [Y/N]
Updating Extended BootWare..........Done.
BootWare updated,System is rebooting now.
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing..............................Done!
|<1> Download Application Program To SDRAM And Run                         |
|<2> Update Main Application File                                          |
|<3> Modify Ethernet Parameter                                             |
Enter your choice(0-3): 3
|          Ctrl+D = Quit.                                                  |
Load File Name         :host
                       :wa4300_fit.bin
Target File Name       :target
                       :wa4300_fit.bin
Server IP Address      :192.168.1.1 192.168.21.1
Local IP Address       :192.168.1.253 192.168.21.2
Enter your choice(0-3): 2
........Done!
Updating File flash:/wa4300_fit.bin.........................................
..Done!
第五步:重启,降级完成
我现在没有V7设备了
划水一号 发表时间:2020-08-23
回复划水一号:
从官网上下载wx3024E的升级包,从中找出该型号ap的版本文件,按照如上步骤,上传至AP
聆听聆听 发表时间:2020-08-23
粉丝:124人 关注:6人
以下是WA2620i-AGNde 软件版本下载链接:
https://www.h3c.com/cn/Service/Document_Software/Software_Download/IP_Wlan/AP/WA2610E-GNP_WA1208E-GNP_WA2610i-GN_WA2620i-AGN_WA2/
用户名:yx800
密码:01230123
升级前请仔细查看软件版本说明书,里面有适配说明和升级指导!棒!
