M9K+l2tp
2020-08-25提问
  • 1收藏,1058浏览
L2TP配置完成,终端拨入提示
到底是终端问题,还是配置问题
配置是按照
配置的
粉丝:124人 关注:6人
在防火墙上部署的L2TP VPN,VT接口也需要加入安全域。
以下是防火墙部署L2TP VPN的客户LAC模式案例连接及管件配置点,请参考:
https://zhiliao.h3c.com/theme/details/102845
FW1:
<H3C>sys
[H3C]sysname FW1
[FW1]int gi 1/0/3
[FW1-GigabitEthernet1/0/3]ip address 10.0.0.2 30
[FW1-GigabitEthernet1/0/3]des <connect to SW1>
[FW1-GigabitEthernet1/0/3]quit
[FW1]acl basic 2000
[FW1-acl-ipv4-basic-2000]rule 0 permit source any
[FW1-acl-ipv4-basic-2000]quit
[FW1]int gi 1/0/2
[FW1-GigabitEthernet1/0/2]des <connect to R1>
[FW1-GigabitEthernet1/0/2]ip address 202.1.100.2 30
[FW1-GigabitEthernet1/0/2]nat outbound 2000
[FW1-GigabitEthernet1/0/2]quit
[FW1]ip route-static 0.0.0.0 0.0.0.0 202.1.100.1
[FW1]security-zone name trust
[FW1-security-zone-Trust]import interface GigabitEthernet 1/0/3
[FW1-security-zone-Trust]quit
[FW1]security-zone name Untrust
[FW1-security-zone-Untrust]import interface GigabitEthernet 1/0/2
[FW1-security-zone-Untrust]quit
[FW1]acl basic 2001
[FW1-acl-ipv4-basic-2001]rule 0 permit source any
[FW1-acl-ipv4-basic-2001]quit
[FW1]
[FW1]zone-pair security source trust destination untrust
[FW1-zone-pair-security-Trust-Untrust]packet-filter 2001
[FW1-zone-pair-security-Trust-Untrust]quit
[FW1]
[FW1]zone-pair security source untrust destination trust
[FW1-zone-pair-security-Untrust-Trust]packet-filter 2001
[FW1-zone-pair-security-Untrust-Trust]quit
[FW1]
[FW1]zone-pair security source trust destination local
[FW1-zone-pair-security-Trust-Local]packet-filter 2001
[FW1-zone-pair-security-Trust-Local]quit
[FW1]
[FW1]zone-pair security source local destination trust
[FW1-zone-pair-security-Local-Trust]packet-filter 2001
[FW1-zone-pair-security-Local-Trust]quit
[FW1]
[FW1]zone-pair security source untrust destination local
[FW1-zone-pair-security-Untrust-Local]packet-filter 2001
[FW1-zone-pair-security-Untrust-Local]quit
[FW1]
[FW1]zone-pair security source local destination untrust
[FW1-zone-pair-security-Local-Untrust]packet-filter 2001
[FW1-zone-pair-security-Local-Untrust]quit
FW1 L2TP VPN LNS关键配置点:
[FW1]local-user weijianing class network
New local user added.
[FW1-luser-network-weijianing]password simple weijianing
[FW1-luser-network-weijianing]service-type ppp
[FW1-luser-network-weijianing]quit
[FW1]domain system
[FW1-isp-system]authentication ppp local
[FW1-isp-system]quit
[FW1]ip pool weijianing 172.16.1.2 172.16.1.254
[FW1]ip pool weijianing gateway 172.16.1.1
[FW1]int Virtual-Template 1
[FW1-Virtual-Template1]ip address 172.16.1.1 24
[FW1-Virtual-Template1]ppp authentication-mode chap domain system
[FW1-Virtual-Template1]remote address pool weijianing
[FW1-Virtual-Template1]quit
[FW1-security-zone-Untrust]import interface Virtual-Template 1
[FW1]l2tp enable
[FW1]l2tp-group 1 mode lns
[FW1-l2tp1]undo tunnel authentication
[FW1-l2tp1]tunnel name LNS
[FW1-l2tp1]allow l2tp virtual-template 1
[FW1-l2tp1]quit
测试:
物理机填写IP地址:
物理机能PING通FW1的外网地址,PING不通私网地址:
打开iNode智能客户端,点击连接右边的小三角,设置LNS服务器的IP地址:
输入用户名、密码,点击连接:
连接成功:
查看获取到的IP地址:
此时物理机已经可以PING通FW1的私网地址:
同时也可以打开SW1的WEB服务:
查看FW1的L2TP显示信息:
查看已分配的IP:
另外建议使用官网的inode拨号软件来进行拨号。
可以试试inode拨号
vt1需要放入安全域吗
zhiliao_gIJ4T 发表时间:2020-08-25
粉丝:95人 关注:1人
配置需求及说明
1.1  适用的产品系列
本案例适用于软件平台为Comware V7系列防火墙:F100-X-G2F1000-X-G2F100-X-WiNetF1000-AKF10X0等。
注:本案例是在F100-C-G2Version 7.1.064, Release 9510P08版本上进行配置和验证的。
1.2  配置需求及实现的效果
防火墙采用固定IP地址的方式部署在公司互联网出口,运营商提供的IP地址为198.76.28.30/30,网关为198.76.28.29DNS地址为221.228.255.1。初步规划防火墙使用3接口接入运营商,使用4接口连接内部网络,内部网络使用192.168.10.0网段。
需求:
1)要求内网终端可以自动获取到地址并可以访问互联网。
2)公司外部办公人员需要通过拨号VPN连入公司内网。
组网图
配置步骤
配置步骤
3.1  配置外网接口
#1/0/3设置为外网接口并设置IP地址。
<H3C>system-view
[H3C]interface GigabitEthernet 1/0/3
[H3C-GigabitEthernet1/0/3]ip address 198.76.28.30 255.255.255.252
[H3C-GigabitEthernet1/0/3]quit
3.2  配置内网接口
#配置内网接口为1/0/4接口并指定IP地址为192.168.10.1
[H3C]interface GigabitEthernet 1/0/4
[H3C-GigabitEthernet1/0/4] ip address 192.168.10.1 255.255.255.0
[H3C-GigabitEthernet1/0/4] quit
3.3  配置NAT地址转换
#进入1/0/3接口配置NAT动态地址转换。
[H3C-GigabitEthernet1/0/3]nat outbound
3.4  配置到外网网关的静态路由
#配置默认路由到外网网关。
[H3C]ip route-static 0.0.0.0 0 198.76.28.29
3.5  建立VPN拨号账户
#创建本地PPP用户vpdnuser,设置密码为HelLo
[H3C]Local-user vpdnuser class network
[H3C-luser-network-vpdnuser]password simple HelLo
[H3C-luser-network-vpdnuser]service-type ppp
[H3C-luser-network-vpdnuser]quit
3.6  开启L2TP功能
[H3C]l2tp enable
3.7  配置L2TP用户地址池
#创建用于给L2TP拨号用户分配地址的地址池。
[H3C] ip pool aaa 192.168.100.2 192.168.100.254
[H3C] ip pool aaa gateway 192.168.100.1
3.8  创建L2TP接口
#创建接口Virtual-Template1PPP认证方式为CHAP,并使用地址池aaaClient端分配IP地址。
[H3C]interface virtual-template 1
[H3C -Virtual-Template1]ppp authentication-mode chap domain system
[H3C -Virtual-Template1]ip address 192.168.100.1 24
[H3C-Virtual-Template1]remote address pool aaa
[H3C-Virtual-Template1]quit
3.9  创建L2TP1
创建LNS模式的L2TP1,配置隧道本端名称为LNS,指定接收呼叫的虚拟模板接口为VT1
[H3C]l2tp-group 1 mode lns
[H3C-l2tp1]tunnel name LNS
[H3C-l2tp1]allow l2tp virtual-template 1
[H3C-l2tp1]undo tunnel authentication
[H3C-l2tp1]quit
3.10  配置外网接口、VT接口加入Untrust安全区域
#1/0/3外网接口加入Untrust区域。
[H3C]security-zone name Untrust
[H3C-security-zone-Untrust]import interface GigabitEthernet 1/0/3
[H3C-security-zone-Untrust]import interface Virtual-Template 1
[H3C-security-zone-Untrust]quit
3.11  配置内网接口加入Trust安全区域
#1/0/4内网接口加入Trust区域。
[H3C]security-zone name Trust
[H3C-security-zone-Trust]import interface GigabitEthernet 1/0/4
[H3C-security-zone-Trust]quit
3.12  配置安全策略将TrustUntrust域内网数据放通
#创建对象策略pass
[H3C]object-policy ip pass
[H3C-object-policy-ip-pass] rule 0 pass
[H3C-object-policy-ip-pass]quit
#创建TrustLocal域的域间策略调用pass策略。
[H3C]zone-pair security source Trust destination Untrust
[H3C-zone-pair-security-Trust- Untrust]object-policy apply ip pass
[H3C-zone-pair-security-Trust- Untrust]quit
3.13  配置安全策略将TrustLocal域、LocalTrust域数据全放通策略
#创建trustLocal域的域间策略调用pass策略。
[H3C]zone-pair security source Trust destination Local
[H3C-zone-pair-security-Trust-Local]object-policy apply ip pass
[H3C-zone-pair-security-Trust-Local]quit
#创建Localtrust域的域间策略调用pass策略。
[H3C]zone-pair security source Local destination Trust
[H3C-zone-pair-security-Local-Trust]object-policy apply ip pass
[H3C-zone-pair-security-Local-Trust]quit
3.14  配置安全策略将UntrustLocal域目的端口为UDP1701端口放通。
#创建服务对象1701用于匹配L2TPUDP 1701端口。
[H3C]object-group service 1701
[H3C-obj-grp-service-1701]service udp destination eq 1701
[H3C-obj-grp-service-1701]quit
在对象策略中调用1701服务对象。
[H3C]object-policy ip 1701
[H3C-object-policy-ip-1701]rule pass service 1701
[H3C-object-policy-ip-1701]quit
#创建UntrustLocal域的域间策略调用1701服务对象策略。
[H3C]zone-pair security source Untrust destination Local
[H3C-zone-pair-security-Untrust-Local]object-policy apply ip 1701
[H3C-zone-pair-security-Untrust-Local]quit
#创建LocalUntrust域的域间策略调用1701服务对象策略。
[H3C]zone-pair security source Local destination Untrust
[H3C-zone-pair-security-Local-Untrust]object-policy apply ip 1701
[H3C-zone-pair-security-Local-Untrust]quit
3.15  配置安全策略将Untrusttrust访问内网资源的数据放通
#创建地址对象匹配到内网数据
[H3C]object-group ip address neiwang
[H3C-obj-grp-service-neiwang]network subnet 192.168.10.0 255.255.255.0
[H3C-obj-grp-service-neiwang]quit
在对象策略中调用到内网数据对象。
[H3C]object-policy ip neiwang
[H3C-object-policy-ip-neiwang]rule pass destination-ip neiwang
[H3C-object-policy-ip-neiwang]quit
#创建UntrustTrust域的域间策略调用neiwang地址对象策略。
[H3C]zone-pair security source Untrust destination Trust
[H3C-zone-pair-security-Untrust-Trust]object-policy apply ip neiwang
[H3C-zone-pair-security-Untrust-Trust]quit
3.16  配置DHCP服务
#开启DHCP服务并指定动态下发的地址以及网关等参数。
[H3C]dhcp enable
[H3C]dhcp server ip-pool  1
[H3C-dhcp-pool-1]network 192.168.10.0
[H3C-dhcp-pool-1]gateway-list 192.168.10.1
[H3C-dhcp-pool-1]dns-list 221.228.255.1
[H3C-dhcp-pool-1]quit
注:DNS服务器地址优先设置当地运营商提供的DNS服务器地址,如果没有提供可以设置114.114.114.1148.8.8.8DNS服务器地址。
3.17  保存配置
[H3C]save force
VPN客户端配置
4.1  Windows 7电脑拨号配置
#点击电脑右下角电脑图标,选择“打开网络和共享中心”选项。
#点击“设置新的连接或者网络”。
#点击“连接到工作区”。
#选择“使用我的Internet连接(VPN)”。
#点击“我将稍后设置Internet连接”
#Internet地址”置防火墙外网接口的IP地址。
#设置用于VPN拨号的用户名和密码
#再次单击电脑桌面右下角的电脑图标,鼠标右击点击“属性”按钮。
#在“安全”页签中选择VPN类型为“使用IPsec的第2层隧道协议(L2TP/IPSEC)”,数据加密选择“可选加密”,允许协议选择“质询握手身份验证协议(CHAP)”。
4.2  Windows 7电脑拨号常见问题
4.2.1  连接VPN后无法连接外网
#VPN拨号成功后会在电脑路由表中生成一条到VPN网关的默认路由,其优先级高于电脑自身网关的默认路由。如果即想访问VPN又想上网请参考下面配置。
去掉“在远程网络上使用默认的网关”勾选。
#在电脑添加到对端内网的明细路由。
#打开电脑命令提示图窗口,输入CMD命令。
#增加目的地址为192.168.10.0(防火墙内网地址段),掩码为255.255.255.0,网关地址为192.168.100.1的路由。
