2620i-agn能否升级到v7?
2020-08-27提问
  • 1收藏,1043浏览
2620i-agn能否升级到v7?我使用的是wx2540h无线控制器,控制器版本是v7,我在配置里发现控制器是支持这个ap的,现在到哪儿能弄到ap升级包,官网找不到了。
粉丝:124人 关注:6人
以下是WA2620i-agn的下载连接,官网只有V5的,应该还不支持升级到V7。
下载连接如下:
https://www.h3c.com/cn/Service/Document_Software/Software_Download/IP_Wlan/AP/WA2610E-GNP_WA1208E-GNP_WA2610i-GN_WA2620i-AGN_WA2/
用户名:yx800
密码:01230123
注意查看软件版本说明书。
粉丝:95人 关注:1人
首先直接接入网络,看下AP是否可以自动升级到V7.如果没办法自动升级,可以按照以下方法,手动升级到V7,然后再上线。
*                 H3C WA4320i-ACN BootWare, Version 1.15                   *
Copyright (c) 2004-2017 New H3C Technologies Co., Ltd.
Compiled Date       : Mar 27 2017
CPU Type            : ATHEROS AR9550
CPU L1 Cache        : 32KB
CPU Clock Speed     : 720MHz
Memory Type         : SDRAM
Memory Size         : 256MB
Memory Speed        : 560MHz
BootWare Size       : 512KB
Flash Size          : 32MB
CPLD Version        : 002
PCB Version         : Ver.C
BootWare Validating...
Press Ctrl+B to enter extended boot menu...
BootWare password: Not required. Please press Enter to continue.
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Clear Super Password                                                  |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+C: Display Copyright
Ctrl+Y: Change AP Mode
Ctrl+F: Format File System
Enter your choice(0-9): 3
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash                                        |
|<1> Download Application Program To SDRAM And Run                         |
|<2> Update Main Application File                                          |
|<3> Modify Ethernet Parameter                                             |
|<0> Exit To Main Menu                                                     |
|<Ensure The Parameter Be Modified Before Downloading!>                    |
Enter your choice(0-3): 3
==========================<ETHERNET PARAMETER SET>==========================
|Note:       &#39;.&#39; = Clear field.                                            |
|            &#39;-&#39; = Go to previous field.                                   |
|          Ctrl+D = Quit.                                                  |
Protocol (FTP or TFTP) :ftp tftp
Load File Name         :wa4300_fat.bin
                                   :wa4300.ipe
Target File Name       :wa4300_fat.bin
                                   :wa4300.ipe
Server IP Address      :192.168.1.1 100.0.0.2
Local IP Address       :192.168.1.50 100.0.0.1
Gateway IP Address     :0.0.0.0
Enter your choice(0-3): 2
Loading.....................................................................
.............................Done!
16546816 bytes downloaded!
Something wrong with the file.
通过搜集过来的两台AP输出信息来看,成功升级AP的bootware版本为“Version 7.07”,这个是V7的bootware版本。升级失败的bootware版本为“Version 1.15”,这个是V5的bootware版本。所以导致这个问题的原因就是:V5的bootware无法识别V7的ipe版本文件。
首先将V5 AP的bootware升级至V7的bootware,然后格式化flash后再将AP版本升级至V7。
操作之前,先准备好wa4300_update.bin(用来升级bootware)和wa4300.ipe(V7软件版本)。AP的版本在V7的控制器上查看和下载,查看的命令:<ACV7>dir cfa0:/apimge/
具体操作过程如下:(以WA4320i-ACN为例)
第一步:进入V5 AP的bootware,并且按Ctrl+F格式化
CPU L1 Cache        : 32KB
Memory Type         : SDRAM
Memory Size         : 256MB
Flash Size          : 32MB
CPLD Version        : 002
PCB Version         : Ver.C
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Warning:All files on flash will be lost! Are you sure to format? [Y/N]Y.....
Format success.
第二步:进入V5 AP的bootware下,通过网口传入wa4300_update.bin文件,提示
更新bootware版本的时候选择Y
|          Ctrl+D = Quit.                                                  |
Protocol (FTP or TFTP) :tftp tftp
Load File Name         :wa4300.ipe.ipe
                       :wa4300_update.bin
Target File Name       :wa4300.ipe.ipe
                       :wa4300_update.bin
Server IP Address      :100.0.0.2 100.0.0.2
Local IP Address       :100.0.0.1 100.0.0.1
Enter your choice(0-3): 1
16260096 bytes downloaded!
Extend BootWare Version is not equal,updating? [Y/N]
Updating Extend BootWare...........Done!
BootWare updated,System is rebooting now.
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing...................................
........Done!
The system have been updated to ComwareV7.
第三步:再次Crtl+F格式化AP flash
格式化步骤如上,不在赘述。
第四步:导入V7 AP版本(wa4300.ipe)
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<8> Skip Authentication for Console Login                                 |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
|<1> Download Image Program To SDRAM And Run                               |
|<2> Update Main Image File                                                |
|<3> Update Backup Image File                                              |
|<4> Download Files(*.*)                                                   |
|<5> Modify Ethernet Parameter                                             |
Enter your choice(0-5): 5
|         Ctrl+D = Quit.                                                   |
Load File Name         :WA4300_FAT.bin
                                   :wa4300.ipe
Target File Name       :WA4300_FAT.bin
                                   :wa4300.ipe
Server IP Address      :10.0.0.2 100.0.0.2
Local IP Address       :10.0.0.1 100.0.0.1
Subnet Mask            :255.255.255.0
Enter your choice(0-5): 2
.............................Done.
Image file wa4300-boot.bin is self-decompressing...
Saving file flash:/wa4300-boot.bin ........................................
Done.
Image file wa4300-system.bin is self-decompressing...
Saving file flash:/wa4300-system.bin .......................................
第五步:重启,升级完成
<H3C>display  version
H3C Comware Software, Version 7.1.064, Release 2215P01
Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. All rights reserved.
H3C WA4320i-ACN uptime is 0 weeks, 0 days, 0 hours, 1 minute
V5 AP手工导入版本升级至V7时,由于V5的bootware无法正确识别V7的ipe版本文件,只能够识别.bin文件。所以需要先导入wa4300_update.bin将AP的bootware升级至V7,然后再导入ipe文件。
