4330 fat 配置完了5g的正常了2.4的没有,各位大神帮忙看看
2020-09-02提问
  • 1收藏,743浏览
hanhao 零段
[WA4330-ACN]dis cur
 #version 5.20, Release 1509P03
# sysname WA4330-ACN
# domain default enable system
 # telnet server enable
# port-security enable
# password-recovery enable
 # undo attack-defense tcp fragment enable
# vlan 1
# domain system access-limit disable state active idle-cut disable self-service-url disable
# user-group system group-attribute allow-guest
# local-user admin password cipher $c$3$6MfzUxX+9hCeB6Gn/HOztujkMQ2qZEPmeZfY authorization-attribute level 3 service-type telnet service-type web
# wlan rrm dot11a mandatory-rate 6 12 24 dot11a supported-rate 9 18 36 48 54 dot11b mandatory-rate 1 2 dot11b supported-rate 5.5 11 dot11g mandatory-rate 1 2 5.5 11 dot11g supported-rate 6 9 12 18 24 36 48 54
 # wlan service-template 1 clear ssid H3C
 # wlan service-template 2 crypto ssid cisco-5g cipher-suite tkip cipher-suite ccmp security-ie rsn security-ie wpa service-template enable
 # wlan service-template 3 crypto ssid cisco cipher-suite tkip cipher-suite ccmp security-ie rsn security-ie wpa service-template enable
# cwmp undo cwmp enable
# interface NULL0 # interface Vlan-interface1 ip address 192.168.0.50 255.255.255.0
# interface GigabitEthernet1/0/1
# interface GigabitEthernet1/0/2
# interface WLAN-BSS2 port-security port-mode psk port-security tx-key-type 11key port-security preshared-key pass-phrase cipher $c$3$G7Gs9dgognb/1jEUkfungDAn/xonPDP6VkmA
# interface WLAN-BSS3 port-security port-mode psk port-security tx-key-type 11key port-security preshared-key pass-phrase cipher $c$3$UiHUhTlUKCojbMFhZYKZG1dSG8v3dHGZqOYZ
# interface WLAN-BSS32 port link-type hybrid port hybrid vlan 1 untagged
# interface WLAN-BSS33 port link-type hybrid port hybrid vlan 1 untagged
# interface WLAN-Radio1/0/1 service-template 3 interface wlan-bss 3
 # interface WLAN-Radio1/0/2 service-template 1 interface wlan-bss 33 service-template 2 interface wlan-bss 2
# interface WLAN-Radio1/0/3
# arp-snooping enable
 # load xml-configuration
# load tr069-configuration
# user-interface con 0 user-interface vty 0 4 authentication-mode scheme
粉丝:149人 关注:3人
你有3个服务模板 服务模板1 信号叫H3C  服务模板2叫cisco-5G 服务模板3叫cisco
5G radio用了3
2.4G radio用了1和2
并且服务模板没有使能
 # wlan service-template 1 clear ssid H3C  这个没有 service-template enable
添加服务模板enable 你就能找到一个叫H3C的xin"hao
